Re: Is there any alternative to Teflon? October 17, 2013 08:18AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Is there any alternative to Teflon? October 17, 2013 09:01AM |
Re: Is there any alternative to Teflon? October 17, 2013 09:12AM |
Admin Registered: 11 years ago Posts: 1,063 |
>Quote
a jhead needs a fan...
Re: Is there any alternative to Teflon? October 18, 2013 06:38AM |
Re: Is there any alternative to Teflon? October 18, 2013 07:14AM |
Re: Is there any alternative to Teflon? October 18, 2013 07:54AM |
Re: Is there any alternative to Teflon? October 18, 2013 08:25AM |
Re: Is there any alternative to Teflon? October 18, 2013 09:06AM |
A2
Electropolishing:
Electropolishing the ID of a SS filament guides might work if you can direct a stream into the orifice.
You might be able to do this at home with a battery charger, and water pump.
Re: Is there any alternative to Teflon? October 18, 2013 10:01AM |
The sleeve is there just for lower friction than a drilled hole and also to allow a thin wall on the stainless steel tube, so cutting down heat loss.
Re: Is there any alternative to Teflon? October 18, 2013 11:50AM |
Re: Is there any alternative to Teflon? October 18, 2013 12:37PM |
Re: Is there any alternative to Teflon? October 18, 2013 12:59PM |
Re: Is there any alternative to Teflon? October 18, 2013 01:26PM |
A2
EDM = Electro Discharge Machining.
[en.wikipedia.org]
You can get a mirro finish with an EDM machine.
But I'm not sure if it's possible in a deep small ID pocket. I've only seen it done in shallow pockets.
Can you post a cross section of your extruder?
What did the machine shop quote you for the surface finish in RMS? 4 RMS is a mirror surface.
What SS are you using, did the machine shop make any recommendations, did you ask?
For some plastics an EDM surface works great as a mold release for injection molding.
This has got me thinking, I wonder if the stippled surface that the EDM typically leaves behind (32-64 RMS) would be beneficial?
The tiny pockets could act as an air cushion. To further this idea, electropolish the ID.
Re: Is there any alternative to Teflon? October 18, 2013 02:13PM |
Re: Is there any alternative to Teflon? October 18, 2013 03:30PM |
Re: Is there any alternative to Teflon? October 18, 2013 09:52PM |
Re: Is there any alternative to Teflon? October 19, 2013 11:27AM |
Also, I assumed that a steeper internal exit angle would promote more laminar (streamlined) flow of melted plastic exiting the nozzle
The 1.2mm land serves to protect the nozzle for damage if it accidentally crashes into the bed, and helps flatten out the extruded filament to prevent curling on the edges of the part.
Re: Is there any alternative to Teflon? October 19, 2013 11:39AM |
Re: Is there any alternative to Teflon? October 19, 2013 12:55PM |
Re: Is there any alternative to Teflon? October 19, 2013 02:33PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Is there any alternative to Teflon? October 23, 2013 10:36AM |
Re: Is there any alternative to Teflon? October 23, 2013 10:54AM |
Re: Is there any alternative to Teflon? October 23, 2013 11:18AM |
Re: Is there any alternative to Teflon? October 26, 2013 07:32PM |
Excalibur Hotend |
reprapzone.blogspot.de |
Re: Is there any alternative to Teflon? October 27, 2013 02:26AM |
Re: Is there any alternative to Teflon? October 27, 2013 12:05PM |
Re: Is there any alternative to Teflon? October 31, 2013 11:40PM |
Re: Is there any alternative to Teflon? November 01, 2013 05:43AM |
