Are there X Y moving head printer designs?
October 24, 2013 06:50PM
This is a bit of a spin off from dragon-fly's posting about best 3D printer design.
I'd like to design and build a X Y carriage printer i.e where the bed moves up and down in the Z axis, rather than in Y as used in my MendleMax.
I want to design something that can still be home built, and envisage using Aluminium L sections, to fabricate an external cuboid frame (similar to used by the solidoodle).
However I can see some design challenges, especially the Z axis, bed and carriage arragement.
Can anyone point me in the direction of any plans for machines like the Solidoodle or Makerbot, or Ultimaker etc
Thanks
Roger
Re: Are there X Y moving head printer designs?
October 24, 2013 10:30PM
My printer and other h-bot designs do this. It is still kind of a "bleeding edge" printer geometry, but I am getting good prints.
If you're interested in development, you can join the fun: https://groups.google.com/forum/#!forum/h-bot-and-corexy-3d-printers
October 24, 2013 11:40PM
The old school Darwin is built like that.
October 25, 2013 08:42AM
If you're interested in development, you can join the fun: [groups.google.com]
Had no idea this existed. Joined.
October 25, 2013 09:24AM
Also the Wally.(maybe even more bleeding edge, i think he plans to do a kickstarter tho)
October 25, 2013 10:54AM
Awesome! Welcome to the group crispy. I'm glad you joined. smiling smiley
> can join the fun:
> [groups.google.com]-
> corexy-3d-printers
Edited 2 time(s). Last edit at 10/25/2013 10:54AM by iquizzle.
October 25, 2013 06:02PM
iquizzle Wrote:
> My
> printer
> the fun:
> [url=https://groups.google.com/forum/#!forum/h-bot
> -and-corexy-3d-printers]https://groups.google.com/
> forum/#!forum/h-bot-and-corexy-3d-printers[/url]
Thanks.
I'ved joined your google group, I'm not sure I want to go totally "bleading edge" ;-)
A2
October 25, 2013 11:46PM
Another option is to modify a delta robot.
Take a look at the Simpson printer.
Anchor the arms in one plane, and move the table up and down.
You can optimize the arms movement for the largest print area.
Video:
[www.youtube.com]
Wiki:
[reprap.org]
Grounded Experimental Delta Printer
[forums.reprap.org]
New arm design for Simpson style printer.
[forums.reprap.org]
Edited 1 time(s). Last edit at 10/25/2013 11:47PM by A2.
open | download - ScreenHunter_209 Oct. 25 23.39.jpg (36.9 KB)
October 26, 2013 01:19AM
@A2.
Thanks. That looks amazing, but I think I'd prefer to build something a bit more mainstream ;-)
October 26, 2013 01:30AM
How about an Ultimaker?
October 26, 2013 01:47AM
@iQuizzle
Thanks. I'll take a look at the UiltiMaker. I wasn't going to go for a bowden cable printer, but I guess I can adapt the design.
Re: H-Bot. I presume you've seen this prototype on YouTube. [www.youtube.com]
It looks impressive, albeit there is no bed or Z axis.
I'll checkout your google group, as I guess a H-Bot may be an option, but I'd prefer something that used belt and had a non-bowden extruder if possible.
October 26, 2013 10:37AM
@Roger
You should give bowden a try, it works very well after some basic tuning and has many advantages if you want to make a fast printer.
October 26, 2013 04:54PM
@crispy1
OK. I think a H-Bot with bowden would certainly be interesting.
Can you advise on where I can get a compatible extruder.
I found this one on eBay [www.ebay.com.au]
it seems a reasonable price for extruder + bowden.
But I've got very little knowledge of extruders. I built my MendelMax from a kit (from Blomker.com), but I've got no idea exactly what extruder it uses, apart from its an "All Metal Hot End (0.4mm nozzle diameter. 1.75mm filament)" ( [blomker.com] )
The extruder works fine, so I'd probably go for another All Metal extruder, even though it needs a fan.
But perhaps using All Metal, for a bowden setup, is counter productive, as it increases th weight of the print head (X Y Carriage)
October 26, 2013 06:13PM
The weight difference between an all-metal and traditional PEEK/PTFE hotend is negligible. Especially compared to the mass of the stepper motor that is now stationary instead of moving around on the print head.
I designed my own, because there was nothing I found that did not have obvious flaws. Some people use a design called airtripper.
October 26, 2013 06:54PM
im working on an upgrade for the wades reloaded that adds a second hobbed bolt, on the opposite side of the filament, but in a different spot so that it makes it nearly impossible for the filament to strip or slip. and the great thing is it only needs 3 printed parts and can fit on any hinged idler thats compatible with the wades reloaded. and since its based on the wades reloaded it can use a lot of different gear ratios.
October 26, 2013 07:30PM
I was thinking of the weight of the heat sink and fan, but as you say, the weight of these versus the weight of the stepper is definitely a lot less ;-)
As I'm relatively new to this all, I will probably go for a pre-built solution like the one on eBay, rather than attempt to design my own to start with.
Edited 1 time(s). Last edit at 10/26/2013 07:31PM by rogerclark.
October 26, 2013 09:10PM
I like this idea. It's something I've been kicking around for a while but haven't come up with a good, compact way to do it. I look forward to seeing your design!
> ratios.
