Using custom thermistor May 29, 2014 05:37AM |
Re: Using custom thermistor May 29, 2014 05:56AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Using custom thermistor May 29, 2014 09:45AM |
Re: Using custom thermistor May 30, 2014 03:50PM |
DaveX
See http://hydraraptor.blogspot.com/2012/11/more-accurate-thermistor-tables.html if you haven't already.
I think nophead uses a Fluke meter with a small thermocouple pushed down through the filament path into the melt chamber to do his calibrations. I use a thermocouple attached to a cheap PID controller, but I'm not tremendously confident in the controller's calibration. Still, measuring the temperatures is far better than extrapolating a Beta25C/75C curve out past 200C.
Re: Using custom thermistor May 30, 2014 10:11PM |
Ohmarinus
DaveX
If I understand it well, the thermistor is meant to go onto the heated bed. so I think it won't go over 110 degrees celsius
