new guy in the deep end December 31, 2014 09:09AM |
Re: new guy in the deep end December 31, 2014 01:49PM |
Re: new guy in the deep end December 31, 2014 06:41PM |
Re: new guy in the deep end December 31, 2014 06:42PM |
Re: new guy in the deep end December 31, 2014 08:40PM |
Re: new guy in the deep end January 01, 2015 11:15PM |
Re: new guy in the deep end January 02, 2015 01:46AM |
Re: new guy in the deep end January 02, 2015 12:22PM |
Re: new guy in the deep end January 02, 2015 01:46PM |
Re: new guy in the deep end January 03, 2015 11:48AM |
Admin Registered: 11 years ago Posts: 3,096 |
solomondg
I'm gonna be completely honest: building a stock Prusa i3 is kinda a nightmare. I went for the Box Frame variant. It took me months, and I ended up with the wrong extruder, no method to level the bed, and a Y-Axis length of 100mm. I've since fixed it, and it's printing beautifully, but it was a pain. The number one kit that I'd recommend would be the Prusa i3v kit from Makerfarm. There's different sizes, but you shouldn't need anything above the 10" kit. If you're intent on building your own from scratch, I'd go with the Prusa i3 Rework, or, even better, the fully parametric Mendel90. There's a Python script for the 90 where you enter the dimensions and sizes you want, and the script spits out a full bill of materials and all the needed STL (3D model) files.
Re: new guy in the deep end January 08, 2015 05:50AM |
Re: new guy in the deep end January 11, 2015 05:46PM |
Re: new guy in the deep end January 12, 2015 10:59PM |
aparkin
when i do start now i need to look at software
i'm looking at free software to start off what's recommended any one found and use any nice programs out there yes i know i now get a lot more reading to do
Re: new guy in the deep end January 13, 2015 10:13AM |
Re: new guy in the deep end January 13, 2015 10:40AM |
One question I have (of many I'm sure) concerns the extruder assembly of the printed parts I purchased. I have attached some pictures of the part I'm referring to. It looks like I will have to cut the highlighted areas away in order to fit the idler assembly on the main extruder body. Is this correct?
Re: new guy in the deep end January 13, 2015 02:52PM |
Re: new guy in the deep end January 13, 2015 02:59PM |
Re: new guy in the deep end January 13, 2015 05:39PM |
Re: new guy in the deep end January 14, 2015 02:15AM |
Re: new guy in the deep end January 14, 2015 06:58AM |
GRAYWOLF
I'm just working my way through ooznest's Prusa i3 kit.
and so far I'm inputted as the wiring is all terminated in connectors that can only go in one way.
The only problem I have is that I am struggling to handle the hex socket M3 bolts as I'm struggling to hold the tiny allen key supplied (two thin for me to keep hold.)
Re: new guy in the deep end January 14, 2015 08:01AM |
Blue Ice
I started out with Slic3r as my slicer, Pronterface as my interface, and Marlin as my firmware. They have worked quite well for me. I would go and check out their websites to learn more about what they do. (Lots of explanation is probably better explained there.)
I enjoy the 3D modeling quite a bit, and I would surely recommend OpenSCAD as the CAD editor of choice. It took me very little time to pick up, it's intuitive, and I'd put money on it that your son could start to design things with it easily. If he's ever worked with programming it should come naturally, and otherwise it's still very simple.
Let me know what happens
Re: new guy in the deep end January 14, 2015 11:44AM |
Re: new guy in the deep end January 14, 2015 12:10PM |
aparkin
hi the slicer is great just what i was missing ive had a 5 minuet go on openSCAD but for me it seem very windows 98 style with its interface
aparkin
i do like the simplistic of [tinkercad.com] its very simply and child like so ill keep looking for a good C A D
aparkin
p.s ill sit down and spend a few hours going over openscad and see if gets any better but from what i have read its all type in commands hopefully ill find something more intuitive
aparkin
but thanks for the help ive found a stepper motor in germany for 48 quid (no import tax from with in the E,U there 1.7 amps and 40n so all should be good i do have 1 last question which is the easiest filament to start off with
Re: new guy in the deep end January 14, 2015 12:30PM |
psneddon
OOPS!! I think I messed up on the X-End idler assembly.
The bearing was putting too much outward pressure on the printed part and I didn't want it to split, so I removed the tapered inner rings. I had to do this for the Y-Axis idler to get it to fit, so I figured the same for this part.
Unfortunately, the bearing didn't sit centered like I thought it should. Back to the instructions and.... I thought a 608ZZ bearing went there! WRONG!
I was supposed to put a 624ZZ bearing there!! OKAY, let's try that then.... Uhhh.. it looks like the hardware kit I got doesn't have a 624ZZ bearing. Instead I have 2 623ZZ bearings.
In my searches I found that the different builds on the printed parts effected the rod length, but I thought the bearings would be the same throughout the different builds. My mistake again.
I went ahead and put both 623ZZ bearings in place of the one 624ZZ bearing and temporarily put one of the M3 screws on to see how well it fit. Both of the 623ZZ bearings seem to fit really good, however I don't have the right length M3 screw. Shouldn't be too hard to find one. Does anyone see a problem with using the two 623ZZ bearings in place of the one 624ZZ bearing. It seems that the main difference is the diameter of screw needed to hold it centered in place...
Re: new guy in the deep end January 14, 2015 12:55PM |
Re: new guy in the deep end January 14, 2015 06:14PM |
Re: new guy in the deep end January 14, 2015 06:31PM |
Re: new guy in the deep end January 14, 2015 09:10PM |
aparkin
thankyou blue ice
i did not even think about the glass ill ask my local glass cutter what he's got in stock i'm not rushing and most of my bits are on order from china and 28 postage days away ill keep you posted and keep reading and learning thanks for all your help to you and everyone that's answered my question
Re: new guy in the deep end January 14, 2015 10:18PM |
psneddon
Thanks again for the feedback. I'll have to see if the seller would sell me just that part. I'm getting a lot of good information and advice from your answers to everyone.
I'm still waiting for my smooth and threaded rods to come in the mail. As I mentioned in a previous post, I have the majority of the parts, however I still need to get a hot end, heated bed, glass (or painters tape) thermistors and end stops - not counting some PLA.
psneddon
The build calls for a J Head hot end. I know there are different hole sizes, but I'm at a loss as to which one or type/brand to buy. By my understanding, PLA is generally 1.75 mm in diameter and the hole in the hot end can be anywhere from 0.3mm to 0.5mm - correct?
psneddon
What hot end would you recommend for the first time builder and what size hole? I was expecting to pay around $30 to $40 - is that a reasonable expectation?
As an example, I saw one like this listed for sale :
[www.ebay.com]
I don't want to buy junk that will cause problems or something that won't fit.
aparkin
For me in the UK it has to be this 1[e3d-online.com]. I know its expencive but it has great reviews and this is the part that is going to make are break your machine don't skimp on motors are hot end the rest can be up graded as you work and learn I'm sure some 1 can point you at a good 1 on your side of the pond
Re: new guy in the deep end January 14, 2015 11:47PM |
