Z calibration February 09, 2015 06:02AM |
Re: Z calibration February 09, 2015 08:05AM |
Re: Z calibration February 09, 2015 09:01AM |
G28 ; home all axes ; G1 Z5 F5000 ; lift nozzle
That's also why I have switched using the SD Card only, but now it seems difficult to check what happens exactly when asking for a Home…Quote
This sort of crap is why I try to avoid using a computer to control my printer. Printing requires enough messing around without adding computer problems to the mix.
Re: Z calibration February 11, 2015 08:24PM |
Re: Z calibration February 12, 2015 04:13AM |
Re: Z calibration February 12, 2015 08:21AM |
Re: Z calibration February 12, 2015 09:25AM |
Re: Z calibration February 12, 2015 09:36AM |
; generated by Slic3r 1.1.7 on 2015-02-09 at 17:59:06 ; perimeters extrusion width = 0.40mm ; infill extrusion width = 0.42mm ; solid infill extrusion width = 0.42mm ; top infill extrusion width = 0.42mm G21 ; set units to millimeters M107 M190 S60 ; wait for bed temperature to be reached M104 S220 ; set temperature G28 ; home all axes ; G1 Z5 F5000 ; lift nozzle / Remove the ; at the begining with machines with park area lower than the bed, and adjust the lift. ;G1 Z5 F-5000 ; Down nozzle to compensate the up of HOME ALL M300 S300 P1000 G4 P60000 G92 Z-3 M109 S220 ; wait for temperature to be reached G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000 G92 E0 G1 Z0.400 F7800.000 G1 X81.523 Y41.045 F7800.000 G1 E1.00000 F1800.000 G1 X82.276 Y39.848 E1.17794 F1080.000 G1 X82.930 Y39.017 E1.31108 G1 X84.053 Y37.894 E1.51087 G1 X84.884 Y37.240 E1.64401 G1 X86.081 Y36.487 E1.82194 G1 X87.056 Y36.009 E1.95860 G1 X88.236 Y35.562 E2.11748 G1 X89.314 Y35.267 E2.25818 G1 X90.488 Y35.055 E2.40828
; generated by Slic3r 1.1.7 on 2015-02-09 at 17:59:06 ; perimeters extrusion width = 0.40mm ; infill extrusion width = 0.42mm ; solid infill extrusion width = 0.42mm ; top infill extrusion width = 0.42mm G21 ; set units to millimeters M107 M190 S60 ; wait for bed temperature to be reached M104 S220 ; set temperature G28 ; home all axes G92 Z5.0 M109 S220 ; wait for temperature to be reached G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000 G92 E0 G1 Z0.400 F7800.000 G1 X81.523 Y41.045 F7800.000 G1 E1.00000 F1800.000 G1 X82.276 Y39.848 E1.17794 F1080.000 G1 X82.930 Y39.017 E1.31108 G1 X84.053 Y37.894 E1.51087 G1 X84.884 Y37.240 E1.64401 G1 X86.081 Y36.487 E1.82194 G1 X87.056 Y36.009 E1.95860 G1 X88.236 Y35.562 E2.11748 G1 X89.314 Y35.267 E2.25818 G1 X90.488 Y35.055 E2.40828
Re: Z calibration February 12, 2015 12:24PM |
Re: Z calibration February 12, 2015 12:42PM |
Re: Z calibration February 12, 2015 06:26PM |
Re: Z calibration February 12, 2015 06:47PM |
Re: Z calibration February 12, 2015 08:41PM |
Re: Z calibration February 13, 2015 04:46PM |
