Under extrusion after upgrade to bowden extruder May 13, 2015 09:35PM |
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 03:31AM |
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 02:17PM |
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 03:06PM |
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 03:30PM |
gabrielcr78
1. Are you using bowden configuration as well, and if so, using an MK8 gear too?
2. Do you have your DRV8825 an if so, configured for 1/32 microsteps on the extruder motor too?
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 05:51PM |
dc42
gabrielcr78
1. I am using a Bowden extruder, with the RepRap mini geared extruder that I received with my Mini Kossel kit from Think3DPrint3D. This is what it looks like:
The extruder works perfectly since I reduced the motor current.
2. I am not using DRV8825 drivers, I am using the A4982 drivers on my Duet electronics, with 1/16 microstepping.
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 05:52PM |
AndrewBCN
Unfortunately the E3D V6 has acquired a bad reputation for jamming as it warms up during print (note that I have no idea whether this reputation is deserved or not, as I do not own a genuine E3D hotend, V5 or V6). Could you post a couple of pictures of your print head and extruder setup? Are you providing proper cooling for the E3D aluminum fins?
Have you tried another brand of filament (I have also faced the case where a certain brand of PLA filament would print perfectly fine and another brand would systematically jam in the hotend)?
Also note that you should properly set the current for the direct drive extruder to something like 70% of the maximum current your stepper is rated for.
And to prevent the filament from slipping against the MK8 gear, the spring forcing the idler against the filament should be tightened as much as possible.
Check this video for a similar Bowden setup to yours: [www.youtube.com]
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 06:13PM |
Re: Under extrusion after upgrade to bowden extruder May 14, 2015 06:28PM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 12:39AM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 01:37AM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 04:50AM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 05:46PM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 05:56PM |
gabrielcr78
that's right tthetazzbot, one time I failed to connect the heatsink fan, i realized soon enought so i removed the PTFE tube and it was ruined, luckyly I learned my lesson with no more damage than that. but the thing is that i printed several stuff with this e3d v6 in pretty good quality before swaping to this new extruder... that's the reason it thought it was related to that change.. maybe it's just that i did not notice the jamming because the previous direct greg's extruder offeed much more power... one thing i noticed though is that the filament was stuck when the print finished and I tried to remove the filament.. a couple of ties i had to dissabemble the whole thing and clean the hotend (another reason to move to bowden as it's easier to dissasemble...)
ayhow.. do you also hear the clacking of the motor and have over extrusion after a few of the printing?
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 06:09PM |
thetazzbot
I was thinking my stepper motor was too wimpy for this, but if you're using a geared extruder and having similar issues, I'm not so sure. I have managed to print
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 06:23PM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 06:36PM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 06:59PM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 07:40PM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 08:04PM |
Re: Under extrusion after upgrade to bowden extruder May 15, 2015 08:56PM |
Re: Under extrusion after upgrade to bowden extruder May 17, 2015 12:16AM |
Re: Under extrusion after upgrade to bowden extruder May 18, 2015 01:53PM |
Re: Under extrusion after upgrade to bowden extruder May 22, 2015 05:28PM |
