Re: 1 Meter bot project June 20, 2015 01:48PM |
garyhlucas
If you claim a positioning accuracy of 0.005" then the deflection had better be much less than that or combined with lots of other factors you can't possibly get that kind of accuracy. Note that deflection in the frame will produce a position error that will be huge for small parts and probably much less for very large parts.
Re: 1 Meter bot project June 20, 2015 04:30PM |
garyhlucas
Re: 1 Meter bot project June 25, 2015 12:11PM |
Re: 1 Meter bot project June 25, 2015 04:02PM |
Re: 1 Meter bot project June 30, 2015 11:26AM |
Re: 1 Meter bot project June 30, 2015 06:19PM |
Re: 1 Meter bot project June 30, 2015 07:22PM |
Re: 1 Meter bot project July 01, 2015 03:59AM |
Re: 1 Meter bot project July 01, 2015 10:14AM |
o_lampe
Had a nice party?
First thing I recon´d were the white balloons
Seriously:
Aren´t you afraid the long belts eventually start to swing, when they are unsupported all the way back?
I thought of a different way to mount the extruder assembly, where both sides of the belt are fixed/guided.
-Olaf
Re: 1 Meter bot project July 01, 2015 10:29AM |
Re: 1 Meter bot project July 01, 2015 02:32PM |
Thats why a lot of larger machines have a rack and pinion setup...Quote
o_lampe
-Olaf
Re: 1 Meter bot project July 02, 2015 06:41PM |
Re: 1 Meter bot project July 06, 2015 07:22PM |
Re: 1 Meter bot project July 08, 2015 06:17AM |
Re: 1 Meter bot project July 08, 2015 06:57AM |
Re: 1 Meter bot project July 08, 2015 08:16AM |
Re: 1 Meter bot project July 08, 2015 08:46AM |
Re: 1 Meter bot project July 08, 2015 06:43PM |
JamesK
I like the design for the belt tensioner. I've been making all sorts of a mess around that. Yours is much simpler and tidier. Time to hit the mill again!
Re: 1 Meter bot project July 10, 2015 09:46AM |
Re: 1 Meter bot project July 13, 2015 05:12PM |
Re: 1 Meter bot project July 13, 2015 08:05PM |
Re: 1 Meter bot project July 13, 2015 08:26PM |
garyhlucas
I'm only guessing, but it looks like you still don't understand the meaning of stiff.
Re: 1 Meter bot project July 14, 2015 05:19AM |
oak1477
If our design is not stiff enough we will be changing it.
Re: 1 Meter bot project July 14, 2015 08:19AM |
Re: 1 Meter bot project July 14, 2015 08:49AM |
JamesK
Just to offer a different opinion, I'm delighted to see this project discussed here. Everything I do is heavily cost constrained and I think it's fascinating to see a project undertaken with the resources of a printer manufacturer behind it.
I know there are always emotional and political issues at stake in the open vs closed arena, but I don't see any actual harm in this thread being here. And I can't help but feel that some of those issues may be colouring your response to the project itself. If I understand correctly this is an internship project conducted by a capable but less experienced person and likely within a limited time-span. Under that scenario some of your objections regarding approach and technique seem a little unreasonable.
I'm confused about your suggestion of 30cm as an upper limit for FDM. The use cases and characteristics may be different from smaller printers but I'm curious why you think it is "useless"?
Re: 1 Meter bot project July 16, 2015 07:24PM |
Re: 1 Meter bot project July 16, 2015 08:17PM |
Re: 1 Meter bot project July 18, 2015 11:49AM |
Re: 1 Meter bot project July 18, 2015 09:47PM |
Re: 1 Meter bot project July 21, 2015 10:41AM |
