Re: New Delta Printer - Look Ma, no rails! July 04, 2015 02:31AM |
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 11:41AM |
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 11:48AM |
Admin Registered: 12 years ago Posts: 730 |
Would you be able to post some pictures of this? I am curious what all the string routing looks like from underneath.Quote
LoboCNC
I've got the in-feed height of both the right and left strings for each pair located in the center of the shaft and as the shaft turns, one string winds up the shaft and the other winds down the shaft. There's a slight bias pulling the strings back towards the center so each string ends up with a tight, single layer wrap.
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 01:19PM |
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 01:28PM |
simspeed
You could also use dead weights on string line to replace the rubber hose for tension on the center post. That way the tension would remain constant regardless of effector position. Suspend the weights in the support posts and run the string line over v-groove pulleys up to the top of the center post where you have the hose mounted now.
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 01:43PM |
simspeed
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 01:51PM |
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 02:14PM |
MattMoses
Also, nice work!![]()
Re: New Delta Printer - Look Ma, no rails! July 04, 2015 02:34PM |
simspeed
Good idea Jeff, I'm planning to use CF springs to offset the weight for my X gantry (current build). The mass is still there of course but the motors won't have to support the weight and it won't fall in the event of power failure. Also...on your design, if you were to use equal weights for the pole and stepper motor pairs you would in effect create a CF spring condition because the two weight move opposite directions for a given leg of the delta. Mass would be there but with a correct torque value for the motors it shouldn't be an issue I don't think.
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 02:48AM |
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 10:51AM |
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 11:16AM |
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 11:43AM |
LoboCNC
simspeed's thoughts on using synchromesh cable got me to thinking about this possible method for cabling up a Delta-T type printer. (BTW, the "T" is for tensegrity.) This configuration should give near constant downward force on the tension post independent of the Z height. Note you would need tandem synchromesh cables as each motor needs to drive 2 cables in parallel - I've just shown one for clarity.
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 12:53PM |
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 01:33PM |
simspeed
Here is a representation of the cable routing for one leg. As the motor turns the effector and tension pole moves in conjunction with the other 2 legs throughout the desired path. Static line tension is created by having the tension pole length adjustable to put whatever load is necessary on the combined cables for all legs simultaneously. Mount the motor and pulleys at the base and top of a V-slot C channel extrusion and brace to a base plate accordingly.
Here is the 3 leg Delta-T configuration. Each of the top V groove pulleys would likely have to center pivot around the horizontal axis to follow the effector path without binding. I see that solution pretty easy to build using a pivot plate with a center post slipped down into one of the V-Slot end plate holes.
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 01:47PM |
Re: New Delta Printer - Look Ma, no rails! July 05, 2015 03:21PM |
Re: New Delta Printer - Look Ma, no rails! July 06, 2015 12:11PM |
Re: New Delta Printer - Look Ma, no rails! July 06, 2015 12:37PM |
o_lampe
Let´s say the stepper turns clockwise and moves the red line 1 inch. The "rear" pivot point of the effector would lift 1 inch.
But at the same time the red line would allow the front pivot point to drop 1 inch.
The green line would have to lift 2 inches, to make both pivots of the effector lift 1 inch.
Without extra spring force on the green line, the stepper movement would only make the effector turn on a vertical axis instead of moving up down
Re: New Delta Printer - Look Ma, no rails! July 07, 2015 02:41AM |
Re: New Delta Printer - Look Ma, no rails! July 07, 2015 06:11PM |
Re: New Delta Printer - Look Ma, no rails! July 07, 2015 07:57PM |
Re: New Delta Printer - Look Ma, no rails! July 07, 2015 08:33PM |
Re: New Delta Printer - Look Ma, no rails! July 08, 2015 07:42AM |
Re: New Delta Printer - Look Ma, no rails! July 08, 2015 08:09AM |
Re: New Delta Printer - Look Ma, no rails! July 08, 2015 08:53AM |
Re: New Delta Printer - Look Ma, no rails! July 08, 2015 10:15AM |
o_lampe
Absolutely amazing!
So quiet, fast and simple. I want one so bad now!
How many different machined parts do you count so far?
Is it important to have the three "springs" pulling exactly with the same force?
-Olaf
Re: New Delta Printer - Look Ma, no rails! July 08, 2015 12:33PM |
o_lampe
About the homing issue:
Can you add black tape marks on the fishing line, so when they run through an optical endstop, will trigger the home position?
Not very accurate, but a starting point
-Olaf
Re: New Delta Printer - Look Ma, no rails! July 08, 2015 01:32PM |
o_lampe
Now with the rearranged line feed a chance to add endstops? Mount them on the center post, below the rubber?
-Olaf
Re: New Delta Printer - Look Ma, no rails! July 08, 2015 02:59PM |
