Extruder drive/Cold End Suggestions with higher force capability? October 16, 2015 01:58PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 16, 2015 07:23PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 18, 2015 04:51PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 18, 2015 05:05PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 19, 2015 02:48PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 19, 2015 02:54PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 19, 2015 03:34PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 19, 2015 09:55PM |
patrickrio
I am using a custom hot end that has the heated filament path going the long way through the block, like the Volcano. It seems to be able to melt much faster than I can extrude. I may have increased surface tension holding back my speed a bit though. Currently I am using a Peek heatbreak with teflon liner. I will hopefully someday switch to a metal or ceramic path from teflon.
When doing max extrusion tests, I try to increase layer height and width. With the 0.4 nozzle I do 0.5 width and 0.25 height. It is hard to get this layer and width setting to go above 200mm/sec.
I never really got close to a maximum using the 1.2mm nozzle, as I just can't get close to extruding fast enough.
Re: Extruder drive/Cold End Suggestions with higher force capability? October 28, 2015 11:20AM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 29, 2015 09:20AM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 29, 2015 09:35AM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 29, 2015 10:46AM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 29, 2015 03:30PM |
Re: Extruder drive/Cold End Suggestions with higher force capability? October 29, 2015 03:35PM |
