Re: This engineer claims 100 grams direct extruder. I want one August 06, 2016 06:52AM |
Re: This engineer claims 100 grams direct extruder. I want one August 06, 2016 07:03AM |
dc42
What is the inductance of your Nema 11 motor? Can you get a variant that has a higher rated current but lower inductance?
Re: This engineer claims 100 grams direct extruder. I want one August 06, 2016 09:44AM |
Re: This engineer claims 100 grams direct extruder. I want one August 06, 2016 10:03AM |
o_lampe
The dodecahedron was printed at 60mm/s & travel at 150mm/s. I thought, the faster travel the less stringing.
Re: This engineer claims 100 grams direct extruder. I want one August 06, 2016 10:43AM |
o_lampe
IIRC, dc42 claims 15000Hz for the Due_RRF firmware for steps
o_lampe
BTW, the RAPS128 drivers at 16/1 microsteps can keep the stepper much colder than the A4988. I guess it's the faster current control loop?
Re: This engineer claims 100 grams direct extruder. I want one August 06, 2016 03:54PM |
o_lampe
We're getting there!
The suggestion to use less retraction length and speed helped a lot against stringing. But the blobs got worse...
I tried it one more time with 1mm retraction at 30mm/s, but the blobs didn't disappear.
If I find the time today I'll try 1.5mm at 35mm/s. There must be a sweet spot, still undiscovered.
E3D
Excessively long retractions will cause issues by dragging soft filament into cold areas. E3D-v6 hotends need less retraction than most hotends. For direct extrusion systems you should use anywhere from 0.5mm-1.0mm, for bowden systems you might want to go up to 2mm. Retraction beyond 2mm is likely to cause issues.
Re: This engineer claims 100 grams direct extruder. I want one August 07, 2016 02:20AM |
nebbian
I bet it's frustrating to trial something that, at first glance, should give amazing prints, but it doesn't perform as well as expected.
I tested the extruder on a RAMPS with the ramps-test code.Quote
dc42
It's much more likely that they are cooler because you are running them at a lower current.
Re: This engineer claims 100 grams direct extruder. I want one October 03, 2016 12:22PM |
Re: This engineer claims 100 grams direct extruder. I want one October 04, 2016 04:16PM |
Simon0362
Ping.........!
Anybody advanced any further with this project?
I heavily modified the casing drawings to arrive at something suitable for my Kossel where the E3d hangs underneath the spider but a load of other diversions mean that I don't yet have a fully operational unit - but I am interested to hear how others are getting along.
Having recently moved house, my workshop is slowly getting back to being operational again (the 03D stuff sits in the office!), and this included a CNC mill and lathe which I intend to use to try some of the components in aluminium - especially the outer gear casing and probably the pin carrier and shaft. Update will follow when I get somewhere closer!
Regards,
Simon
Re: This engineer claims 100 grams direct extruder. I want one October 05, 2016 05:00PM |
