Re: New technique for ABS adhesion! December 23, 2016 05:45AM |
LoboCNC
Do you know what type of polyester is in the transparency film you are using? 3M transparencies claim to be made of PET. Maybe a different formulation?
Re: New technique for ABS adhesion! December 23, 2016 06:26AM |
JamesK
Did a few more tests today. ABS adhered well enough to pull the transparency off the glass again, so on to another glue...
Petg seems to work really well on this surface, and since it doesn't shrink much it's less inclined to rip the sheet off the glass. On the other hand, I couldn't get enough adhesion with nylon to stop it from curling away from the bed. I suspect nylon will need an extra treatment on top of the transparency which is a shame.
Re: New technique for ABS adhesion! December 23, 2016 10:43AM |
Re: New technique for ABS adhesion! December 23, 2016 11:57AM |
JamesK
For example, polyester is a family of chemicals that includes PET, and PET itself seems to come in multiple forms. I guess all you can do is test a particular product and hope that the manufacturer doesn't change the content.
Re: New technique for ABS adhesion! December 23, 2016 06:09PM |
LoboCNC
That's why I was wondering if it might be worth testing the McMaster PET/polyester adhesive backed film. If it works, the adhesive backing would be way more convenient than glue, and also, McMaster is pretty consistent with their sourcing.
Re: New technique for ABS adhesion! December 23, 2016 06:48PM |
JamesK
LoboCNC
For sure it's worth trying. A lot will depend on the temperature characteristics of the adhesive. I see some of the 3M transfer tapes are rated to 200C or so. I'm currently using 3M indoor carpet tape (it was available at home depot and cheap), but the glue visibly melts by around 90C, so it's not going to be any good at ABS temperatures. I think it was LeadingLights that suggested lamination pouches - that sounds like it's worth a go too, but once again, I don't know what temperature the glue they use softens at. I have a sinking feeling that I'll end up trying epoxy in the end!
Oh, and TPU is another resounding success on the transparency foil - almost too much adhesion at the moment, and that beautiful glossy surface with no clean up
Re: New technique for ABS adhesion! December 23, 2016 07:13PM |
Re: New technique for ABS adhesion! December 23, 2016 07:15PM |
Re: New technique for ABS adhesion! December 23, 2016 07:16PM |
Re: New technique for ABS adhesion! December 23, 2016 08:30PM |
JamesK
That's good to know - thanks for testing!
Re: New technique for ABS adhesion! December 23, 2016 08:55PM |
ECJ
I was tested to remove epoxy from aluminum using acetone. I poured some acetone and covered with pvc film to not evaporate and let it act for 5 minutes. Acetone obviously does not dilute the epoxy, but it soften and lose grip ability! Then it is possible to scrape easily with a plastic spatula or even with the nails.
Re: New technique for ABS adhesion! December 23, 2016 09:13PM |
Re: New technique for ABS adhesion! December 26, 2016 08:37AM |
Re: New technique for ABS adhesion! December 27, 2016 09:37AM |
JamesK
I'm pretty sure that last time I tried to order from them they declined to ship to Canada, but it sure looks like they can do it.
Due to the cost and complexity of shipping our products to Canada, we are only able to accept orders from businesses and schools. We’ve canceled your order.
Re: New technique for ABS adhesion! December 27, 2016 11:23AM |
JamesK
JamesK
Ah, I remembered right:
Why they can't make that clear on their website is beyond me.
Re: New technique for ABS adhesion! December 27, 2016 11:30AM |
