Re: Circular 220mm heated bed for 220V? December 17, 2016 03:42PM |
Re: Circular 220mm heated bed for 220V? December 17, 2016 11:15PM |
Andreas15
I would surely go with the Duet elecs. So no problem there. For safety, I know I need to ground everything properly, including the frame. Any other things to take into consideration?
Re: Circular 220mm heated bed for 220V? December 18, 2016 03:25AM |
I use the fork MarlinKimbra4duo, and I need to recompile if I want to make changes!Quote
dc42
mdcompositi
dc42
I thought having to edit and recompile firmware to change parameters went out with the Ark - or at least with 8-bit electronics
Sorry .....what are you saying?? I don't understand.......
You said you have 32-bit controller electronics. I am saying that if you use one of the major 32-bit firmwares, which are RepRapFirmware and Smoothieware, you don't need to recompile and re-upload the firmware to make changes, such as changing thermistor type. You just edit the configuration file on the SD card, which is read when the firmware starts up. In RepRapFirmware, you can even do the editing in the web interface without having to remove the SD card, or change parameters such as thermistor type on the fly to see what effect they have.
