300x300 ALU heatbed wiring April 16, 2017 01:05PM |
Re: 300x300 ALU heatbed wiring April 16, 2017 02:11PM |
Re: 300x300 ALU heatbed wiring April 16, 2017 02:40PM |
Re: 300x300 ALU heatbed wiring April 16, 2017 04:16PM |
Re: 300x300 ALU heatbed wiring April 17, 2017 06:49AM |
Re: 300x300 ALU heatbed wiring April 17, 2017 08:21AM |
Re: 300x300 ALU heatbed wiring April 17, 2017 08:24AM |
tgmorris99
My plan is to up the voltage to the full 24V so long as Marlin can control the power output so I don't exceed the PSU rating. For this test the bed was really a direct connect to the PSU so it was taking all the power it wanted, which was more than the PSU rating. I don't have any plans to do ABS I'm hoping I'll be OK since the bed hit's 90 C in under 6 minutes. Other than PLA & PETG the only other filament I'll likely be using is one of the flexible filaments like TPU, which also uses a relatively low bed temp.
If need be I can swap in a larger PSU or switch to an AC powered heat source.
Re: 300x300 ALU heatbed wiring April 17, 2017 09:58AM |
Re: 300x300 ALU heatbed wiring April 17, 2017 10:05AM |
Re: 300x300 ALU heatbed wiring April 17, 2017 12:30PM |
Re: 300x300 ALU heatbed wiring April 17, 2017 12:40PM |
tgmorris99
@newbob - Thanks for the suggestion. Do you have an example of how to attach the leads mechanically? I was thinking they should offer that on the aluminum beds by default but anything I can think of involves drilling which raises the possibility of shorting things out.
Re: 300x300 ALU heatbed wiring April 17, 2017 12:50PM |
Re: 300x300 ALU heatbed wiring April 17, 2017 01:07PM |
newbob
ElmoC
I'm curious where that 20% waste came from?
newbob
450W 24V bed will be performing same as 450W 'mains' bed (except that you are wasting about 20% of electricity).
I'm assuming 80% SMPS efficacy.
Re: 300x300 ALU heatbed wiring April 17, 2017 05:46PM |
Re: 300x300 ALU heatbed wiring April 17, 2017 06:35PM |
Re: 300x300 ALU heatbed wiring April 22, 2017 01:51PM |
Attach them the way the wires in your car are attached to the battery: bolted and with a ring cable shoe attached to the wire.Quote
tgmorris99
Re: 300x300 ALU heatbed wiring April 22, 2017 02:32PM |
Re: 300x300 ALU heatbed wiring April 22, 2017 02:41PM |
Re: 300x300 ALU heatbed wiring April 22, 2017 02:58PM |
ElmoC
I wouldn't trust the reading from an IR thermometer. They are not very accurate. Use a thermocouple based thermometer for better accuracy.
Re: 300x300 ALU heatbed wiring April 22, 2017 03:10PM |
Re: 300x300 ALU heatbed wiring April 22, 2017 07:10PM |
