Re: Precision Piezo Z-probe Now available. May 27, 2017 12:33AM |
, so I spent a little time today mounting it.
(Except for the Zesty Nimble ad, which was in such small font as to be unreadable to my aged eyes.)
I'm going to need something with the right thread attached to the top of the effector, or perhaps to the piezo "Upper Part".|
Re: Precision Piezo Z-probe Now available. May 27, 2017 03:22AM |
Re: Precision Piezo Z-probe Now available. May 27, 2017 03:34AM |
frankvdh
I'm not even sure what the Bowden connector thread is... maybe 10mm diameter, but I'm pretty sure it's not M10.
Re: Precision Piezo Z-probe Now available. May 27, 2017 04:07AM |
Re: Precision Piezo Z-probe Now available. May 27, 2017 04:28AM |
Re: Precision Piezo Z-probe Now available. May 27, 2017 09:11AM |
Re: Precision Piezo Z-probe Now available. May 27, 2017 09:13AM |
Re: Precision Piezo Z-probe Now available. May 27, 2017 12:52PM |
Re: Precision Piezo Z-probe Now available. May 27, 2017 02:30PM |
Re: Precision Piezo Z-probe Now available. May 29, 2017 01:07PM |
frankvdh
My piezo arrived during the week, so I spent a little time today mounting it.
I've got to say, I'm very impressed with the quality... a nice piece of kit! Instructions are clear and complete.(Except for the Zesty Nimble ad, which was in such small font as to be unreadable to my aged eyes.)
Without thinking about it too much, I got the screw-mount version, but would possibly have been better off with the groove-mount... I could have clamped that into my effector where the hot-end heatsink had been clamped. But, not to worry, a couple of 3mm holes through my effector and I had everything in place, except the filament feed. The red LED lit up with power, and the blue one with pressure
Now to attach the bottom end of the Bowden cable and away.... But my Bowden connector screws directly into the top of my hot-end heatsink (cheap Chinese E3D "clone" (I assume)
Any ideas/suggestions welcome!
Re: Precision Piezo Z-probe Now available. May 30, 2017 07:02AM |
Re: Precision Piezo Z-probe Now available. May 30, 2017 07:27AM |
Re: Precision Piezo Z-probe Now available. May 30, 2017 12:58PM |
o_lampe
frankvdh
But you can not use the coupler that came with the hotend. Its too big. Use PC4-M5 or PC4-M6. I made one for each thread.
Looks good, but you can't push the Bowden tube thru, unless you drill them open. Which is a bit creepy with a HSS drill...
Re: Precision Piezo Z-probe Now available. May 31, 2017 08:39PM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 04:03AM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 06:05AM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 06:10AM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 08:57AM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 09:30AM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 09:38AM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 06:51PM |
Re: Precision Piezo Z-probe Now available. June 01, 2017 07:33PM |
DjDemonD
1. Yes the capacitance of your finger will cause the PCB to "trigger" if you are touching the piezo disc or anything electrically connected to it, but under normal use this shouldn't be a problem. I take it you aren't seeing false triggers when you are not touching it? I chose to have the hole spacing as it is to ensure there is sufficient space between the edges of the part and the holes, it might be possible to tweak it slightly, I will look into that. One of the things I have already changed is to make the lip the piezo disc sits on slightly wider creating that more positive location. That part is available on thingiverse [www.thingiverse.com] if you wanted to try it instead of the one supplied.
2.Yes this probe operates in "normally open" logic i.e. goes High when triggered supplying 5v/3.3v (depending on supply voltage) to the signal pin. Most microswitches are configured as normally closed, and as such offer some fail-safe, which we are still working on. Inverting the logic in firmware is the least compromised solution.
3. Yes it was a difficult decision where to put the PCB, and I am the first to admit that this system might be less ideal if you frequently need to remove your hotend. You can relocate the PCB elsewhere by extending the piezo leads (carefully), but a very long wire can pick up interference. That being said I've yet to come across a hotend clamping system that allows for easy, quick change and yet holds the hotend firmly in place.
4.That is a possible clamp design worth looking into. Can you send me some files of that design, or point me in the direction of them, and I will have a look into it. I think what we tried to achieve was a very firm hotend clamp, partially to address the perpetual issue of groovemount being very unsatisfactory, so if this system can solidly clamp your hotend, and then screw mount to your printer you essentially are no longer relying on groovemount. But if it proves problematic then I will review it.
I suggest you align the screw underneath the PCB if you can.|
Re: Precision Piezo Z-probe Now available. June 02, 2017 02:02AM |
Re: Precision Piezo Z-probe Now available. June 02, 2017 02:08AM |
Re: Precision Piezo Z-probe Now available. June 02, 2017 05:17AM |
Re: Precision Piezo Z-probe Now available. June 02, 2017 05:24AM |
Re: Precision Piezo Z-probe Now available. June 02, 2017 08:33AM |
Re: Precision Piezo Z-probe Now available. June 02, 2017 08:41AM |
Re: Precision Piezo Z-probe Now available. June 02, 2017 10:03AM |
Re: Precision Piezo Z-probe Now available. June 02, 2017 10:12AM |
