Re: Precision Piezo Z-probe Now available. October 15, 2017 04:41AM |
Re: Precision Piezo Z-probe Now available. October 15, 2017 05:32AM |
Re: Precision Piezo Z-probe Now available. October 15, 2017 05:48AM |
Re: Precision Piezo Z-probe Now available. October 15, 2017 06:55AM |
Re: Precision Piezo Z-probe Now available. October 15, 2017 10:00AM |
Moriquendi
It's not clear from the pictures exactly how you're mounting that assembly to your printer but it looks like you're mounting it via four holes on the second plate. If that's the case, unless you're doing something clever where the motor screws to the mount, you're unlikely to get the best signal as there's nothing to bend the piezo.
Re: Precision Piezo Z-probe Now available. October 15, 2017 02:41PM |
Re: Precision Piezo Z-probe Now available. October 15, 2017 05:34PM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 05:06AM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 06:26AM |
coredump
Do you have better pictures with the detailing on how you assemble that brackeT? I may be missing something.
Re: Precision Piezo Z-probe Now available. October 16, 2017 06:32AM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 08:18AM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 08:36AM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 12:21PM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 01:36PM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 02:02PM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 02:12PM |
OutcastZeroOne
so, here is my basic idea for the mount on my set up. pardon the crudeness of the design as this is just a concept i drew up in about 5 min to get the idea viewable. The piezo would be mounted the same distance from the pivot point as the center of the hotends shaft, so a 1/1 ratio of force being transfered by the lever.
Re: Precision Piezo Z-probe Now available. October 16, 2017 02:50PM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 03:03PM |
Re: Precision Piezo Z-probe Now available. October 16, 2017 06:12PM |
OutcastZeroOne
also, can anyone give me accurate dimensions of the 20mm piezo disk's so that i can make a propper sized recess in my design?
Re: Precision Piezo Z-probe Now available. October 16, 2017 06:34PM |
DjDemonD
OutcastZeroOne
Murata 7BB-20-6
diameter 20.00mm
thickness 0.41mm (excluding solder)
thickness 0.95mm with solder
Re: Precision Piezo Z-probe Now available. October 17, 2017 04:04AM |
Re: Precision Piezo Z-probe Now available. October 17, 2017 04:37AM |
Re: Precision Piezo Z-probe Now available. October 17, 2017 03:35PM |
Re: Precision Piezo Z-probe Now available. October 17, 2017 03:42PM |
Re: Precision Piezo Z-probe Now available. October 18, 2017 03:56PM |
Re: Precision Piezo Z-probe Now available. October 18, 2017 04:49PM |
Re: Precision Piezo Z-probe Now available. October 18, 2017 08:31PM |
Re: Precision Piezo Z-probe Now available. October 19, 2017 06:26AM |
Send: M48 Recv: M48 Z-Probe Repeatability Test Recv: Finished! Recv: Mean: -0.015469 Min: -0.017 Max: -0.014 Range: 0.003 Recv: Standard Deviation: 0.001298 Recv: Recv: X:200.00 Y:200.00 Z:1.00 E:50.00 Count A:32000 B:0 Z:640 Recv: ok
Re: Precision Piezo Z-probe Now available. October 19, 2017 06:34AM |
Re: Precision Piezo Z-probe Now available. October 19, 2017 08:12AM |
