Re: Precision Piezo Z-probe Now available. February 13, 2018 04:33AM |
o_lampe
I'm wondering why you didn't put the piezos in series?
Re: Precision Piezo Z-probe Now available. February 13, 2018 10:50AM |
Re: Precision Piezo Z-probe Now available. February 13, 2018 11:33AM |
Re: Precision Piezo Z-probe Now available. February 13, 2018 12:32PM |
Re: Precision Piezo Z-probe Now available. February 13, 2018 07:47PM |
Re: Precision Piezo Z-probe Now available. February 14, 2018 01:38AM |
Re: Precision Piezo Z-probe Now available. February 14, 2018 12:38PM |
Re: Precision Piezo Z-probe Now available. February 14, 2018 01:05PM |
Re: Precision Piezo Z-probe Now available. February 14, 2018 02:23PM |
Chowa
Simon
As I understand the second piezo is mounted to the carriage to act as a noise source(microphone) for the main signal and is 180 out of phase with the sensor signal thus providing a noise cancelling function.and it is not mounted touching the actual build plate?
Stef
Re: Precision Piezo Z-probe Now available. February 15, 2018 11:13AM |
Re: Precision Piezo Z-probe Now available. February 15, 2018 12:58PM |
Re: Precision Piezo Z-probe Now available. February 15, 2018 06:11PM |
Re: Precision Piezo Z-probe Now available. February 16, 2018 02:39AM |
Re: Precision Piezo Z-probe Now available. February 16, 2018 03:23AM |
Re: Precision Piezo Z-probe Now available. February 16, 2018 05:53AM |
Re: Precision Piezo Z-probe Now available. February 16, 2018 06:03AM |
whosrdaddy
Why not bond the piezos to the bed?
no drilling, less hassle
Re: Precision Piezo Z-probe Now available. February 16, 2018 06:46AM |
Re: Precision Piezo Z-probe Now available. February 16, 2018 07:03AM |
Re: Precision Piezo Z-probe Now available. February 18, 2018 05:53PM |
Re: Precision Piezo Z-probe Now available. February 18, 2018 06:09PM |
Re: Precision Piezo Z-probe Now available. February 18, 2018 09:20PM |
Moriquendi
Are you using a PP20 board (single piezo connection) or a universal board (three piezo connections)?
The Universal v2 kit board is active low output, that means that when triggered the output drops to a logic low voltage, somewhere around 2v IIRC. The output pulse is very brief, around 0.3 seconds long, it's very unlikely that you will be able to see a triggered output with M119. If you need to check whether the firmware is registering triggers, turn VR2 so that the blue LED is lit and the red LED is not lit, then call M119, then re-tune the board for normal use. Pull ups need to be turned off for both piezo boards.
Idris
Re: Precision Piezo Z-probe Now available. February 19, 2018 04:12AM |
Re: Precision Piezo Z-probe Now available. February 20, 2018 07:20AM |
Moriquendi
Hi Phil,
It would appear that you've found an issue with the PP20 and the MKSbase, 3.1v should register as a logic high but perhaps there's more hysteresis on that pin or some form of protection that's interfering. I haven't used an MKSbase but I have been using a Smoothieboard for a couple of years and it doesn't have this issue.
Idris
Re: Precision Piezo Z-probe Now available. February 20, 2018 08:03AM |
Re: Precision Piezo Z-probe Now available. February 22, 2018 09:23AM |
Re: Precision Piezo Z-probe Now available. February 22, 2018 10:50AM |
Re: Precision Piezo Z-probe Now available. February 22, 2018 12:12PM |
Re: Precision Piezo Z-probe Now available. February 22, 2018 12:40PM |
Re: Precision Piezo Z-probe Now available. February 22, 2018 01:38PM |
Re: Precision Piezo Z-probe Now available. February 22, 2018 02:46PM |
