Re: Precision Piezo Z-probe Now available. December 03, 2018 12:22PM |
Re: Precision Piezo Z-probe Now available. December 03, 2018 12:37PM |
Ed3D
Ok sounds good to me. If you could stop making me want to buy more printer related things that would be great though
Ed3D
I've only really briefly looked into the piezo - I assume there will be some good mount ideas kicking around on the internet. Ill be probing onto glass if that matters?
Re: Precision Piezo Z-probe Now available. December 03, 2018 12:39PM |
Re: Precision Piezo Z-probe Now available. December 03, 2018 12:58PM |
Re: Precision Piezo Z-probe Now available. December 03, 2018 02:11PM |
Re: Precision Piezo Z-probe Now available. December 03, 2018 02:50PM |
Re: Precision Piezo Z-probe Now available. December 03, 2018 05:22PM |
Re: Precision Piezo Z-probe Now available. December 04, 2018 03:01AM |
Moriquendi
Forgive me if this is stuff you already know
With the v1.2 Orions the output is open-drain. What this means is that the output can be pulled low by the Orion but it cannot be pulled up. When the Orion is plugged into a controller and the controller has pullups enabled there is a large value resistor (20-100k) between the signal line and V+ so the signal line is pulled up to V+. When the Orion is triggered it shorts the sig pin to GND.
There are three possible causes for the problem you're seeing that I can think of.
1, You don't have pullups enabled on the pin that the Sig pin is connected to
2, You've somehow damaged the pin on your controller (ramps?)
3, You've damaged the T2 transistor on the Orion so it's always closed.
Re: Precision Piezo Z-probe Now available. December 04, 2018 03:44AM |
Ed3D
I'm kind of concerned about the hot end wobbling / not being as rigid if its clamped through the piezo. My other concerns is how the fillament guide would no longer mount to the hot end and so is pushing through the piezo too so extrusion / retraction will trigger the sensor? Maybe I'm misunderstanding on this one!
Is the Orion better / more rigid than the simple disk? Could I integrate the Orion into my print head and are there mount point dimensions / a solid model / a dimensioned drawing available?
Is it recommended to use the hot end sensor instead of sensors under the build plate? The Andromeda looks great and it would make my wiring and print head packaging a lot easier. Can you quote some standard deviations between the different models?
I think I'm set on a piezo right now I'm just wondering what the best config is. I'm using a coreXY motion type if that makes any difference - apologies for the barrage of questions!
Re: Precision Piezo Z-probe Now available. December 04, 2018 06:55AM |
Re: Precision Piezo Z-probe Now available. December 04, 2018 01:47PM |
Re: Precision Piezo Z-probe Now available. December 05, 2018 05:29AM |
Re: Precision Piezo Z-probe Now available. December 05, 2018 07:56AM |
leadinglights
It is true that the bed must be stable for underbed sensors to work correctly but this stability is also needed even without a sensor. The traditional three point mounting allows the bed to move in the XY plane - constrained only by the friction of the adjusting nuts and often dubious screws to the build stage. I have previously used three sliding pillars between the build stage and the carriage - this works well but is obviously over-constrained if the build stage is out of true.
A printer that I am building at the moment will have a kinematic (Maxwell) mount for the build stage with piezos under the three ball components and nesting force provided by magnets set in repulsion. I hope to get the long striven for 1micron/1gram sensitivity along with a much more stable bed.
The sensitivity difference across the surface of the build stage with underbed sensors is not actually unavoidable. In fact, the method is inherently accurate if all else is equal: The sensors must all be equally sensitive and the stage design must be rigid and not have constraints other than the mountings to which the sensors are attached. On tests I have been able to indicate that the response is withing 10% across the whole build stage - including outside the triangle of sensors.
Mike
Re: Precision Piezo Z-probe Now available. December 05, 2018 10:13AM |
MKSA
Explain the benefits of this set up that is far more complex, has shortcomings (and you describe them), costs more than just ONE sensor in the nozzle mount.
No benefit, not worth it.
Re: Precision Piezo Z-probe Now available. December 05, 2018 10:49AM |
leadinglights
MKSA
I would explain the benefits and even discuss the relative values of different approaches but your saying "No benefit, not worth it" shows that any such discussion itself would have no benefit and not be worth it. I have long since given up unproductive debates on this or any other forum.
Mike
Re: Precision Piezo Z-probe Now available. December 05, 2018 11:10AM |
MKSA
leadinglights
MKSA
Mike
The meaning of my last sentence is: If there is no benefit, then it is not worth it !
So, explain the benefits because so far, you just raised issues. Issues that are known, even obvious BTW. Yet you plan to implement it ? Puzzling isn't ?
Re: Precision Piezo Z-probe Now available. December 05, 2018 11:20AM |
MKSA
.................. Issues that are known, even obvious BTW. Yet you plan to implement it ? Puzzling isn't ?
Re: Precision Piezo Z-probe Now available. December 05, 2018 12:01PM |
I'm pretty sure that I said that you can get "close enough" but percentage isn't a measurement, unless you state what it is a percentage of. So what does that mean in real terms?Quote
leadinglights
Re: Precision Piezo Z-probe Now available. December 05, 2018 01:38PM |
Re: Precision Piezo Z-probe Now available. December 05, 2018 03:48PM |
leadinglights
p.s., I am still waiting for MKSA to enlighten me about the issues with underbed piezo sensors so that I can engineer the issues into a good compromise.
Re: Precision Piezo Z-probe Now available. December 05, 2018 05:03PM |
All of the issues I found have been resolved to give very acceptable sensitivity, repeatibility, accuracy and reliability. This was done not by being certain that I already knew the answer but by trying to find solutions to each problem.Quote
MKSA
................................... Now, after all this time and all these experiments, you should be able to give the benefits of your choice compared to a hot end/carriage mounted unique sensor. .................................
Re: Precision Piezo Z-probe Now available. December 05, 2018 05:35PM |
Re: Precision Piezo Z-probe Now available. December 05, 2018 06:34PM |
SupraGuy
.................................................. because downward pressure on the other side of a fulcrum will result in upward pressure at another sensor location. This is the fundamental compromise in the system. .....................................
Re: Precision Piezo Z-probe Now available. December 10, 2018 08:07PM |
Re: Precision Piezo Z-probe Now available. December 11, 2018 04:41AM |
Re: Precision Piezo Z-probe Now available. December 11, 2018 11:15AM |
My problem with this is that it makes 2 assumptions, which aren't necessarily true.Quote
leadinglights
[attachment 108496 PiezoPositions.jpg]
Mike
Re: Precision Piezo Z-probe Now available. December 11, 2018 01:24PM |
Re: Precision Piezo Z-probe Now available. December 14, 2018 11:18PM |
Re: Precision Piezo Z-probe Now available. December 16, 2018 12:47PM |
Re: Precision Piezo Z-probe Now available. December 16, 2018 02:01PM |
