Detailed questions regarding gcode (federate, acceleration, jerk) September 18, 2017 12:31PM |
M204S3000 M205X20 G1F1800X20.222Y18.834E0.01486 G1X20.87Y18.383E0.02971 G1X21.561Y17.999E0.04458 G1X22.286Y17.687E0.05943 ....
Re: Detailed questions regarding gcode (federate, acceleration, jerk) September 18, 2017 07:32PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Detailed questions regarding gcode (federate, acceleration, jerk) September 19, 2017 10:19AM |
In the wiki the S refers to 'normal moves' and a T to filament only moves. What are filament only moves?
Is the max value used for all moves??
Is the jerk actually the third derivative of the position value or is it a sort of minimum acceleration?
In line 3 the federate is set to 1800 mm/ for all following commands or just for the G1 command in line 3?
Re: Detailed questions regarding gcode (federate, acceleration, jerk) September 19, 2017 03:14PM |
Dust
Feed rates set the axis speed, when moving multiple axis in one command the lowest feed rate is used (normally E axis)
Re: Detailed questions regarding gcode (federate, acceleration, jerk) September 19, 2017 05:20PM |
Re: Detailed questions regarding gcode (federate, acceleration, jerk) September 19, 2017 06:11PM |
G1 X10Y10 E1 F500 G1 X10Y10 E10 F500
G1 X10 Y10 E0.56 F5000
[reprap.org]Quote
Re: Detailed questions regarding gcode (federate, acceleration, jerk) September 19, 2017 07:19PM |
