Heated bed issue - Solder point de-soldering when heating August 26, 2018 04:19PM |
Re: Heated bed issue - Solder point de-soldering when heating August 26, 2018 05:00PM |
Re: Heated bed issue - Solder point de-soldering when heating August 26, 2018 05:02PM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Heated bed issue - Solder point de-soldering when heating August 26, 2018 05:17PM |
Re: Heated bed issue - Solder point de-soldering when heating August 27, 2018 02:19PM |
Re: Heated bed issue - Solder point de-soldering when heating August 27, 2018 02:23PM |
SupraGuy
I'm not a fan of the wire that these things typically use. The same wire that manages the ~40W heater for the hot end is not adequate for the ~150W heated bed. I use 16AWG copper wire for mine (Or 14AWG if the wire run is going to be longer than 30cm.)
Re: Heated bed issue - Solder point de-soldering when heating August 27, 2018 02:47PM |
Re: Heated bed issue - Solder point de-soldering when heating August 27, 2018 03:34PM |
SupraGuy
It doesn't appear at all that the solder is actually melting through, since the blob on the end of the wire remains in the same shape as before, it's not softening at all.
Re: Heated bed issue - Solder point de-soldering when heating August 27, 2018 06:49PM |
Re: Heated bed issue - Solder point de-soldering when heating August 28, 2018 08:13AM |
