Re: RAMPS for Due! November 17, 2013 05:04AM |
I would be somewhat amazed if they built 2000 boards without checking for production readiness, but it is fair to say they must have a different business model to what I am used to.|
Re: RAMPS for Due! November 17, 2013 04:43PM |
Re: RAMPS for Due! November 17, 2013 05:50PM |
Re: RAMPS for Due! November 17, 2013 06:32PM |
Re: RAMPS for Due! November 17, 2013 10:30PM |
Re: RAMPS for Due! November 18, 2013 01:55AM |
Re: RAMPS for Due! November 18, 2013 12:39PM |
Re: RAMPS for Due! November 18, 2013 02:13PM |
Cefiar
They replied to my comment saying they're going to change them, which is a good thing. Once they do I'll amend my post above.
bobc: For the 11A rating, there are NO PTC fuses available from Bourns that have a rating greater than 16V, which is the whole problem - they simply don't go that high. And you can't run them in parallel or series easily to share the current or voltage rating, due to the way they work internally.
Re: RAMPS for Due! November 18, 2013 04:34PM |
Re: RAMPS for Due! November 18, 2013 06:04PM |
Re: RAMPS for Due! November 18, 2013 07:48PM |
Re: RAMPS for Due! November 18, 2013 10:55PM |
Re: RAMPS for Due! November 21, 2013 09:42PM |
Re: RAMPS for Due! November 22, 2013 02:43AM |
Re: RAMPS for Due! November 22, 2013 06:32PM |
Re: RAMPS for Due! November 22, 2013 09:56PM |
Re: RAMPS for Due! November 22, 2013 10:57PM |
Re: RAMPS for Due! November 23, 2013 07:35PM |
Re: RAMPS for Due! November 23, 2013 09:52PM |
Re: RAMPS for Due! November 23, 2013 11:16PM |
Re: RAMPS for Due! November 28, 2013 04:52PM |
I am waiting on a board from Geetech to see what they are like.|
Re: RAMPS for Due! November 28, 2013 05:51PM |
Re: RAMPS for Due! November 29, 2013 03:41PM |
Does your code use advantages of the arm?Quote
ambrop7
Oh, I've fixed the inverted heaters problem in APrinter. I don't think there's anything now preventing it from running on a real RAMPS-FD.
@bobc If you find some time could you give APrinter a test on your board? All the instructions are here, including building for Due/RAMPS-FD. You need Linux and the latest gcc-arm-embedded compiler (link in instructions).
Re: RAMPS for Due! November 29, 2013 07:49PM |
karabas
Why only 250000?
Re: RAMPS for Due! November 30, 2013 06:20AM |
ambrop7
With the board connected using the programming port, press the erase button, then the reset button, and finally run flash-rampsfd.sh to upload the firmware to your board.
Re: RAMPS for Due! November 30, 2013 09:58AM |
Re: RAMPS for Due! November 30, 2013 11:55AM |
bobc
The erase button is pretty much inaccessible with the RAMPS-FD attached, but the command "stty -F /dev/ttyACM0 1200" will erase the Due and put it into the bootloader.
uncle_bob
I have not used the AVR version of the ARM ADC. On other flavors of ARM, the ADC is quite good. Running it in 16 bit readout mode is well worth the effort on some ARM's. You can get ENOB's in the 13-14 bit range.
Re: RAMPS for Due! November 30, 2013 03:16PM |
Re: RAMPS for Due! November 30, 2013 03:43PM |
uncle_bob
When you fix the thermistor tables, think about some sort of "transparent" fix. There are vendors out there supplying tables for their thermistors, but not flowing them upstream. Why they do this - I have absolutely no idea. How to implement such a thing (or if it's worth it) - that's up to you.
Re: RAMPS for Due! November 30, 2013 09:36PM |
