Re: RAMPS for Due! December 28, 2013 08:24PM |
Re: RAMPS for Due! December 28, 2013 09:41PM |
uncle_bob
Be careful of low voltage zeners. Below about 5V or so they can be very leaky / high slope. A clamp reference may be easier to do accurately with one of the cheap shunt regulators.
Re: RAMPS for Due! December 29, 2013 12:42PM |
Re: RAMPS for Due! December 29, 2013 01:03PM |
Cefiar
The reason 1K was chosen is that it gives a reasonable response around the critical area, but doesn't put too much current through the thermistor. They all have max power ratings, and putting too much current through them will kill them.
Re: RAMPS for Due! December 29, 2013 01:18PM |
uncle_bob
Which brings us back to the original departure point of reduction of noise on the Due board....
Is there a (practical) way to give the thermistor "empire" it's own dedicated ground going back to the Due? Have the thermistors floating unless the Due is plugged in. What ever performance you get that way, it's going to be the best you can get.
Re: RAMPS for Due! December 29, 2013 06:10PM |
Re: RAMPS for Due! December 29, 2013 07:20PM |
Re: RAMPS for Due! December 30, 2013 09:21PM |
Cefiar
I am wondering if perhaps we could relocate the thermistor header.
If we relocate the reset switch and reset header, there should be enough room to locate the thermistor header there.
The advantages are:
1. 2x ground pins right there.
2. Reduces trace clutter around the mounting hole near Due pin 21.
I also think it might be possible to provide a dedicated ground from the same area just to the thermistor components. There is also a ground pin near them (the centre header P106 provides a ground to the Due as well - one you missed in your analysis bobc), which could be connected as well. In fact, by distance this is the second closest ground pin to GNDANA (assuming a solid ground plane on the Due).
With the reset switch/header. the only thing I'd suggest is we try and keep the reset line away from the FETs. Last thing we want to do is induce a signal in the reset line and cause random issues.
bobc: If you say we should do it, and also put the thermistor protection circuit into the schematic, I'll happily do the layout side.
Re: RAMPS for Due! December 31, 2013 07:31PM |
Re: RAMPS for Due! January 01, 2014 02:27PM |
Re: RAMPS for Due! January 01, 2014 03:56PM |
Re: RAMPS for Due! January 01, 2014 06:50PM |
Re: RAMPS for Due! January 01, 2014 08:12PM |
Re: RAMPS for Due! January 01, 2014 08:52PM |
Re: RAMPS for Due! January 02, 2014 02:50AM |
bobc
Ok, I put in some proposed circuitry for the thermistor protection plus a couple of other small changes. [github.com]
I have put the circuit in for THERM0, and a couple of variants with Zener and TLV431. The TLV431 circuit I just copied from the datasheet. I am straying beyond my normal skill set here, so I am relying on you guys to tell me what I need to do!
It might be nice to test out the circuit on some stripboard first, I'll order some components shortly, I also need to fix my Due
Re: RAMPS for Due! January 02, 2014 07:00AM |
Re: RAMPS for Due! January 02, 2014 10:50AM |
Re: RAMPS for Due! January 02, 2014 05:21PM |
Re: RAMPS for Due! January 02, 2014 06:10PM |
Re: RAMPS for Due! January 02, 2014 10:03PM |
Re: RAMPS for Due! January 02, 2014 10:09PM |
Re: RAMPS for Due! January 03, 2014 12:15AM |
Re: RAMPS for Due! January 03, 2014 06:51AM |
Cefiar
I seem to remember changing the silk on the layout to say V1 Rev B a while ago.
I'm happy to have it be V2 Rev A.
Note: There's still a few labels that could be moved about to make a bit more sense, etc, but nothing ground breaking or huge.
I do notice that the ground plane fill isolation gaps seems to be slightly smaller. Did you alter the rules slightly? I say this because I now see ground fill on the bottom around E0-MOT, seeping in between the round pins on the motor connector. I'm not against the change, but the square pin on that connector seems to stop it being the same everywhere. Interestingly, if I remove the fill then re-apply it, they aren't there. Only if I load it from scratch.
There is also not a huge gap around the top layer 100uF caps under the stepper drivers. There could probably be a slightly bigger gap between the edge of the GND pads and the +V_MOTOR line. Not a huge thing to change though, just a matter of getting the track widths right. Note: This was most likely the same on the previous revision, so I doubt it's much of an issue.
Also notice that an extra thin ground (on the bottom layer) that I put around P802 (the endstop header) vanished, but there should be more than ample grounding in that area now (I was being VERY redundant when I did that, just to be sure).
Only other thing is the 5V rail between JP801 and P801 is thinner than the rest of the track along that area. The only way to fix that would be to re-arrange the tracks again around the hole near Due pin 21. Got an idea on how to do that btw(involves putting Z-MAX around the back of 5V_5, X-MIN between 5V_4 and 5V_5, running N-00000193 on top (like Z-MIN, but moving from top to bottom then back - adds 2 more vias), then moving some other bits around (mainly vias like FD_5V, D32, D43, UART2_RX_LV, and their associated tracks, etc).
Scratch that - Realised that we can move Z-MIN slightly nearer Due Pin 21, and then run N-00000193 around the left of the hole rather than the right. This allows us to move N-00000194 enough to widen the track at that end, but we still need to move a few other bits around (as before, mainly vias like D32, D43, UART2_RX_LV, and their associated tracks, etc).
Re: RAMPS for Due! January 03, 2014 07:24PM |
and I really dont want to order another one from china. since it took so long.. I really need one badly so I can keep going on my kossel mini build..|
Re: RAMPS for Due! January 06, 2014 01:02PM |
firehopper
never mind hopefully.. my package has been found in philly.. what the heck is it doing there..
now its in harrisburg..![]()
speaking of these ramps-fds. anyone got a spare one in the usa? I ordered one on 12/02/13 and it made it to a town 50 miles away on 1/2/14, and then it seems the postal service lost it.and I really dont want to order another one from china. since it took so long.. I really need one badly so I can keep going on my kossel mini build..
Re: RAMPS for Due! January 07, 2014 07:40PM |
Re: RAMPS for Due! January 08, 2014 05:33PM |
Re: RAMPS for Due! January 08, 2014 06:32PM |
Re: RAMPS for Due! January 08, 2014 07:09PM |
Re: RAMPS for Due! January 08, 2014 07:28PM |
bobc
I have updated the schematic and layout with some thermistor changes and other things Cefiar mentioned. I have routed a separate ground from the thermistor header to two of the ground pins on the Due header.
I wondered if we should be using AREF? It might be a cleaner reference for the thermistors, and I think it would be quite easy to route.
bobc
I've also been looking at the D102 crowbar diode. It's supposed to protect against reverse polarity by blowing the fuse. But the 1N4004 only has a continuous current rating of 1A, and a peak current of 30A for 8.3 ms. That does not seem nearly long enough to blow a fuse, which might take 0.5s.
So for that to even work, we would need to change it to something nearer 10A rating. Call that Option A. A possible part is : [uk.rs-online.com]
However I'm still not sure that provides much protection, since -12V is still applied for maybe 100-500 ms. It would seem to make more sense to use a blocking diode in series, which would need to be rated 10A+, there are some available at 15A in TO220 packages. (Option B ) We might be able to get by without a heatsink on it, there is also the voltage drop to consider.
I am fairly sure the 1N4004 is a waste of space though. I think we should at least change it to Option A. Thoughts anyone?
uncle_bob
I'm not a big fan of series diodes. You paid good money for that power and now you are just throwing it away.
