Controller LCD contrast issue
Posted by drhender
December 28, 2014 11:44PM
I am working on a new Prusa/Graber i3 printer, but am having an issue with the LCD.
Here's what I am using:
Arduino Mega 2560
Ramps 1.4
RepRapDiscount Full Graphics Smart Controller (previous edition w/ potentiometer and red PCcool smiley
Marlin Firmware - Stable branch (downloaded this weekend)
I have been successful in building the Marlin firmware and downloading it to the Arduino. The controller boots up and the startup screen and then info screen display as expected, but I am having an issue with the contrast. The screen is almost entirely white, making it difficult to read. Looking at the display from an angle makes it readable, but obviously, I'd like to resolve the problem.
Changing the setting in the firmware's menu makes no difference. I've also changed the default value in the code and recompiled and downloaded it. The new default value shows up in the config menu, but the contrast is apparently the same.
I have also changed the potentiometer to see if that would effect the contrast, but the pot seems to make no difference at all. In fact, I even removed the pot from the board (desoldered it) and again, the contrast was identical.
Anyone have a suggestion as to what is going on?
I suspect one of the following:
* The Marlin firmware doesn't support the older version of the RepRapDiscount display board.
* The Display board is not functioning as expected
* There is something in the firmware code that I need to change to support the older board.
Any and all suggestions are welcome and appreciated!
-David.
Edited 1 time(s). Last edit at 12/28/2014 11:45PM by drhender.
Re: Controller LCD contrast issue
December 29, 2014 12:45AM
I had a similar issue with my full graphic LCD controller, but I could not even see anything from any angle. I resolved the problem by adding a 270R resistor from the contrast signal (trimpot) to the 5V line. I connected the resistor between second and third of the empty pin holes as shown on the photo.
open | download - lcd12864.jpg (122.7 KB)
December 29, 2014 02:26AM
Tell me a little bit more... Once you had added the resister, did the trimpot or software setting allow you to further adjust the contrast? Did you have to cut any traces?
( I ask because I might wire up a new trimpot if the existing one doesn't work.)
BTW, how did you know to do that?
Thanks for the info!
December 29, 2014 02:59AM
I have noticed that 12864 displays have a variety of options, determined by the presence or absence of components (including 0 ohm resistors) fitted to the board. There are some threads about this on the Displays section of the Arduino forum.
If the pot was fitted but not working, this suggests to me that there is a missing resistor on your board. Try following the PCB traces from the pot to see what they connect to. Posting a close up photo of the back of the display may get you some more help.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
December 29, 2014 10:35AM
No, I did not have to cut any traces on the board. I checked the voltage on the trimpot and saw that it would not go above 1V, regardless of the setting of the trimpot. So I tried with various resistors between those pin holes (3k, 820R, 270R, just holding it
without soldering) to raise the voltage and then soldered the one which worked best...
December 29, 2014 11:36AM
I soldered in a 270 ohm resister as you did, but it made no difference.
I am attaching a photo of my PCB as suggested by DC42-- it appears to be a similar board to yours. It appears that your board has a wider boarder than mine, but that may just be a difference in production runs.
I am going to try different resisters as you suggest. I also notice that there is a pair of spots near the trimpot that appear to be for a surface-mount component. (See photo - marked RV, 3K) Is there anything soldered into place on your board in that location?
December 29, 2014 12:07PM
Did you measure the variation of the voltage of the trimpot (3rd pin hole) when turning it from one end to the other?
Any change when in the voltage with the resistor?
Is the 2nd pin hole really at 5V, as mine is?
Have you checked that there is no short to ground?
December 29, 2014 07:02PM
After closer inspection, I realized that pins one and two were on the same trace. I confirmed this by removing power from the board and testing the resistance between the pins... there was no resistance. After powering back on,
I confirmed that 1 to ground and 2 to ground always showed a full 5VDC regardless of the position of the pot. So I cut the trace between them. After cutting the trace, the voltage on pin 2 ranges from 0 to 5V depending on position of the pot as expected.
But even after all of that, the display still has no contrast. I measured the voltage on pin 3 of the 12864-- the contrast control pin. That pin always shows 4.5VDC regardless of the voltage measurement on pin 2.
December 30, 2014 03:22AM
It was the back of the 12864 display that I wanted to see a photo of. Is that where the trimpot is, or were you referring to a trimpot on the controller board?
December 30, 2014 02:53PM
The trimpot is on the display controller board. The pins for that trimpot can be seen in the bottom right corner of the photo I posted previously. The display board is tightly daughtered and soldered to the display controller board-- there's no way to photograph the back of the 12864.
January 11, 2015 08:04AM
drhender, I have same LCD like you (without 3K resistor). Siple to fix - put 1K resistor into two pins
open | download - IMG_0275.JPG (283.6 KB)
January 13, 2015 09:16AM
I have a similar but not quite the same issue here [forums.reprap.org] and I have a slightly different board too, so although the resistor ideas may still work, I'm not sure where I would try putting them!?
January 13, 2015 01:08PM
I have checked how the trimpot and my additional resistor are connected to the 20x1 pin row which is also present on your board.
I tried to draw it on top of your photo:
This is just how the resistors are connected on my board - no idea whether this also works for your board...
Could it be that your board allows setting the contrast via the software? Marlin has a corresponding parameter, but in my case it had no effect.
January 13, 2015 01:28PM
Yes perfect, thank you enif! For me a 2k2 resistor between GND and Contrast has fixed the issue! smiling smiley
Same here.. the Marlin contrast setting has no effect.
January 28, 2015 01:05PM
Amother 12864 controller from Aliexpress and same problem. In this time 1K resistor was too big. 560 Ohm resistor was fix contrast smiling smiley Ofcourse between same pins 2-3
March 15, 2015 01:33PM
I just received a RRD GLCD for my Smoothieboard and found the contrast very low whether powered by USB or 12V supply. After checking a bunch of threads like this one I took a closer look at the GLCD module and found that there is a tiny pot on the back side of LCD board mounted near the edge near the backlight. Unfortunately the pot is designed to be adjusted from above, but above is where the controller board is sitting. Unless you're prepared to bend all the pins that connect the two boards together to get at the adjustment you're going to need some tweezers to grip the rotor of the pot and turn it. I did just that and got the display working perfectly regardless of being powered by the USB or 12V supply.
March 21, 2015 07:36PM
the_digital_dentist
Thank you for posting this! I just finished soldering the missing LCD interface headers and 1.0A 5V regulator on my Smoothieboard, and was pulling my hair out because the display looked like black letters on a dark blue background. The vendors who copied the genuine RRD GLCD 12864 made an improvement by adding a trim pot on their interface boards to adjust the contrast, but the genuine RRD article does not have that provision except for the inaccessible one on the back of the LCD module itself.
I was thinking about drilling a small hole through the interface board to get at the trim pot until I saw your post. I was hesitant to even try it with a Dremel, because the hole would need to be very close to one of the SD card shield's ground pads. I was able to grab the top of the trim pot with thin needle-nose pliers (power off, of course!), and made a few 1/8 turn swings until it powered on looking just as sharp as your pictures above.....
May 02, 2015 05:15AM
I have the same problem, and tried to adjust the pot grabbing it with a piler, but the contrast doesnt get better, it just varies between invisible and hardly visible. the same as when I adjust the pot on the top.
May 02, 2015 05:49AM
well, finally I soldered a 10ohm resistor and it works well.
June 24, 2015 11:26AM
I bought a 12864 LCD controller from banggood.I have complied with ‪#‎define‬ reprap discount full graphic smart controller. The screen powers up but displays nothing.is this same contrast issue?
Edited 1 time(s). Last edit at 06/24/2015 11:26AM by xxkrishxx.
June 24, 2015 02:19PM
Very possibly . . .
- Tim
July 05, 2015 09:45AM
issue solved by adding 560ohm resistor
August 16, 2015 12:21AM
Hi guys, to start with many thanks, so glad I found this information, otherwise would have thrown newly purchased GLCD into the bin.
Purchased from [www.ebay.com.au]
and his advice was "there is a potentiometer beside the LCD,it can adjust the contrast,please try,thanks." yes I had already tried this and makes very little difference.
I said to myself, I mean what can you expect for $13.80 it was a gamble.
I was told to send it back!, like yeah its going to cost as much as the purchase price, that realy is not an option.
Cutting a long story short I read the info here, tried a number of resistors and settled on 560 ohms.
Now the GLCD is very usable and as good as my other $69 GLCD from rerapdiscount.
Regards - bruce
Protective film is still on the GLCD screen.
open | download - GLCD & Rambo 1.2e (226.6 KB)
open | download - GLCD Rear 560 ohm.jpg (161.1 KB)
open | download - LCD after resistor.jpg (200.4 KB)
December 19, 2015 12:26PM
hey guys, i have the same issue with my LCD : it is a reprap discount smart controller, i don't know where to add the resistor
another thing, can someone explain me the three contrast pins located in top of the memory card reader ??? confused smiley
here is a picture of my LCD please tell me which resistor i should have and where to sold it and thanks
open | download - Sans titre-1.jpg (471.7 KB)
December 28, 2015 04:04PM
I had this same Issue with RobotLinking Full Graphic Smart Controller 12864. What I did is firs check with 470 ohm resistor as described above. It worked, but I decided to do the job as it should be - I unsold goldpin bar, then put there connector instead of soldering. Then experimentally set proper resistance with of the hidden pot. It worked VERY well :-) so thanks for advice !!!!
I had idea to drill hole id plate above but after unsoldering I measured, and calculated that it would be directly on the path on second side of plate. Uffff, it was real hazard ;-), So - DO NOT DRILL HOLE!!!
On the picture you can see pot, gold pins and gold pin connector. Remember that plate is both side so be careful with unsoldering, not to damage connection between sides.
Best Regards
glov
January 09, 2016 08:01PM
xxkirshxx
I have the same banggood display. Was your display totally white before your fix?
I have
A cross post to my detailed description of my issue.
[community.robo3d.com]
I'm still stuck. I'm not sure if my controller is bad or not.
Thanks
January 31, 2016 12:05PM
hi guys help please i cant get my rrd full graphics card to work im using a ch340 board with 1.4 ramps sprinter firmware with u8glib installed i have tried swopping round the ribbons nothing just blue screen any suggestions would be a help as this is slowly driving me crazy
February 09, 2016 02:46PM
Watch this
[www.youtube.com]
February 23, 2016 03:33AM
problem solved with 220R resistor
February 23, 2016 09:41AM
Hey there,
i also have an issue with the contrast of my Full Graphic Smart Controller. The contrast just doesn´t change. I soldered serveral different resistors between Pin 2 and 3 (between 10 and 15k ohm. also an 20k ohm Poti between Pin 1 and 3. It just stay bright as the sun. The only thing the changes is when i turn the poti on the front of the Controller fully clockwise. Within the last 1-5 degree it gets slightly darker. Has anybody a clue how i could fix it?
Greetings,
Simon
