Re: New MKS SBASE Smoothieware-compatible board from China June 19, 2015 07:12AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 19, 2015 09:33AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 23, 2015 10:20AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 27, 2015 12:08PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 27, 2015 01:23PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 27, 2015 08:22PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 27, 2015 08:48PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 27, 2015 08:52PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 27, 2015 09:16PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 28, 2015 10:48AM |
Wow I didn't think the ethernet would be so slow because the web interface pops up so quickly (although there isn't much to it). Uploading a 6MB file took five minutes, which is 21kbit/s.Quote
Dejay
I want to just use it over the web interface and without USB / SD card. Is that a bad idea? Can I even copy a gcode file over ethernet onto the board?
Re: New MKS SBASE Smoothieware-compatible board from China June 28, 2015 11:33AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 28, 2015 01:56PM |
If the SD card is even slower than this it would make this useless for me as I deal in 20's of megs of gcode.Quote
CapnBry
Dejay
Re: New MKS SBASE Smoothieware-compatible board from China June 28, 2015 05:24PM |
Dejay
Thanks for the info! If the SD card is the bottleneck then I guess the best way might be to use a raspberry and send via USB. If the SD card is faster on the raspberry lol.
Re: New MKS SBASE Smoothieware-compatible board from China June 28, 2015 10:55PM |
Which is the maximum of a SD card too I think. What is troublesome is not the SD card but saying the USB is so damn slow too. If it is that slow on USB, as CapnBry said, it is pure junk. What is it using USB 1.0, or 1.1, interface?Quote
dc42
Dejay
By the time you have added the RPi to the SBASE, you could have bought a Duet for the same or lower price. The Duet uses an SDHC interface to the SD card. The file upload speed from the web interface to SD card is a little over 170Kbytes/sec, or about 10Mb/minute.
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 02:19AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 04:11AM |
dc42
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 04:17AM |
Need for him to clarify and my SD card reader is USB 3.0 and 2.2 backwards compatible which on a standard older PC takes hardly anytime whatsoever to transfer files to and from it. So, if I am stuck without a SD card, or being able to have anything with modern decent speeds to transfer my gcode over, then even the smoothie would not be for me. I don't need the speed of USB 3.0 but I refuse the speeds of USB 1.1 for file transfering too.Quote
dc42
I thought CapnBry was talking about the upload speed to SD card using Ethernet, not USB. But I understand from elsewhere that the limitation on Smoothie based boards is the speed of the SD card interface; so if uploading to SD card over USB is also slow, that doesn't mean that the USB interface is slow.
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 04:31AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 06:30AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 08:41AM |
My numbers were transferring a file over ethernet. Uploading over USB to the SD card might be faster, I mean it's got to be faster than 21kbit.Quote
Dark Alchemist
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 02:12PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 03:49PM |
I don't think you're understanding what we're talking about. This is specifically about uploading a file to the SD card through the ethernet interface which is slow.Quote
Dark Alchemist
So, in my case, it would be really slow for me? USB should never be that slow for a decade, or more, now. USB 1.1 was a max of around 12mbits so it seems it is even slower than that which is not acceptable in today's world. Glad to know even Smoothie sucks in this department so I don't waste my money.
Re: New MKS SBASE Smoothieware-compatible board from China June 29, 2015 05:00PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 30, 2015 08:34AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 30, 2015 12:52PM |
CapnBry
Oh I totally agree. It is a shame it is so slow though because I'm sure a lot of code went into making it work. ... I think half of the problem is the UIP library they use for the networking. I used this on an Arduino many years back to add with). UIP is fine for sending small chunks of data at high latency but not at all for moderate throughput. A microcontroller needs, like a few hundred KB of RAM to be able to "fill the pipe" to get throughput up.
Re: New MKS SBASE Smoothieware-compatible board from China June 30, 2015 10:08PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 01, 2015 06:08AM |
Re: New MKS SBASE Smoothieware-compatible board from China July 01, 2015 06:52AM |
What, if anything, is worse than the Smoothie/Azteeg X5? Is there anything better?Quote
CapnBry
I guess I was speaking theoretically. TCP/IP can use a 64kB window and have multiple frames in flight at any given time (going and coming). Duet/LWIP might perform better than Smoothie/UIP, but they are coming nowhere near "filling the pipe" especially if supporting more than one connection at once with such limited resources. That said, in practical application it could be sufficient for low bandwidth multiple connections (2 or 3) or one moderate bandwidth connection.
Just to confirm something else, I hooked a 12864 "reprap GLCD" to the EXT1 and EXT2 headers and it works fully on the SBASE. Rotary encoder w/ push, buzzer, menus. The "stop" button is tied to the reset line though, so pressing STOP just reboots the SBASE. Icons for hotend, fan, and bed heating are shown below the text as well when they are on.
Re: New MKS SBASE Smoothieware-compatible board from China July 05, 2015 04:24PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 06, 2015 01:45AM |
