Re: DIY Tiny OLED I2C full graphics controller January 10, 2017 01:57AM |
Re: DIY Tiny OLED I2C full graphics controller March 25, 2017 03:21PM |
Re: DIY Tiny OLED I2C full graphics controller March 26, 2017 08:01AM |
Re: DIY Tiny OLED I2C full graphics controller March 26, 2017 09:09AM |
Re: DIY Tiny OLED I2C full graphics controller April 15, 2017 11:10PM |
Re: DIY Tiny OLED I2C full graphics controller April 16, 2017 02:16AM |
Re: DIY Tiny OLED I2C full graphics controller April 16, 2017 05:22AM |
enif
I still use an older version of Marlin, but from what I read, the blinking coordinates just mean that the corresponding axes have not been homed yet. So that part would be normal in your case.
As for the non responding rotary encoder, I assume that there is some problem in the pin assignment. Check out your values for BTN_EN1, BTN_EN2 and BTN_ENC (probably defined in pins_RAMPS.h) and verify them with your wiring.
Re: DIY Tiny OLED I2C full graphics controller May 18, 2017 02:59PM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 01:24AM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 01:54AM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 04:43AM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 11:20AM |
Arduino: 1.8.2 (Mac OS X), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" In file included from /Users/Twmaster/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/avr/include/avr/io.h:99:0, from /Users/Twmaster/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/avr/include/avr/pgmspace.h:90, from sketch/Marlin.h:32, from sketch/ultralcd.h:26, from sketch/ultralcd.cpp:23: sketch/ultralcd.cpp: In function 'void lcd_update()': ultralcd.h:84: error: 'BLEN_C' was not declared in this scope #define EN_C (_BV(BLEN_C)) ^ sketch/ultralcd.h:150:36: note: in expansion of macro 'EN_C' #define LCD_CLICKED (buttons & EN_C) ^ sketch/ultralcd.cpp:2724:9: note: in expansion of macro 'LCD_CLICKED' if (LCD_CLICKED) { ^ exit status 1 'BLEN_C' was not declared in this scope This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
#endif #if ENABLED(NEWPANEL) #elif defined(SSD1306_OLED_I2C_CONTROLLER) #define BTN_EN1 31 #define BTN_EN2 33 #define BTN_ENC 35 #define BEEPER 37 #define LCD_SDSS 53 #define SDCARDDETECT -1 #define KILL_PIN -1 #if ENABLED(REPRAP_DISCOUNT_SMART_CONTROLLER)
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 02:28PM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 02:33PM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 03:54PM |
% diff -p Configuration.h{.ori,} *** Configuration.h.ori 2017-05-19 19:56:42.864881489 +0200 --- Configuration.h 2017-05-19 21:47:15.481863054 +0200 *************** *** 1425,1430 **** --- 1425,1437 ---- // //#define OLED_PANEL_TINYBOY2 + // + // TinyOLED 128x64 OLED from [forums.reprap.org] + // + //#define U8GLIB_SH1106 // used for most 1.3" OLEDs (default) + //#define U8GLIB_SSD1306 // used for most 0.96" OLEDs (uncomment if needed) + #define TINYOLED + //============================================================================= //=============================== Extra Features ============================== //=============================================================================
% diff -p Conditionals_LCD.h{.ori,} *** Conditionals_LCD.h.ori 2017-05-19 20:22:08.937765646 +0200 --- Conditionals_LCD.h 2017-05-19 20:29:27.988815577 +0200 *************** *** 67,72 **** --- 67,82 ---- #endif + #if ENABLED(TINYOLED) + #ifndef U8GLIB_SSD1306 // define U8GLIB_SSD1306 in Configuration.h if not using SH1106 version + #define U8GLIB_SH1106 // SSD1306 and SH1106 are similar, but have slightly different horizontal shift + #endif + #define ULTIPANEL + #define NEWPANEL + #define REVERSE_ENCODER_DIRECTION + #define REVERSE_MENU_DIRECTION + #endif + #if ENABLED(OLED_PANEL_TINYBOY2) #define U8GLIB_SSD1306 #define ULTIPANEL ***************
% diff -p pins_RAMPS.h{.ori,} *** pins_RAMPS.h.ori 2017-05-19 20:03:18.576811985 +0200 --- pins_RAMPS.h 2017-05-19 21:35:10.588615329 +0200 *************** *** 327,332 **** --- 327,340 ---- // not connected to a pin #define SD_DETECT_PIN 49 + #elif ENABLED(TINYOLED) + #define BTN_EN1 31 + #define BTN_EN2 33 + #define BTN_ENC 35 + #define BEEPER_PIN 37 + #define LCD_SDSS 53 + #define SD_DETECT_PIN -1 + #define KILL_PIN -1 #else // Beeper on AUX-4
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 04:00PM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 06:06PM |
Arduino: 1.8.2 (Mac OS X), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" In file included from sketch/MarlinConfig.h:31:0, from /Users/Twmaster/Documents/Marlin/Marlin-RC/Marlin/Marlin.ino:37: Conditionals_LCD.h:28: error: unterminated #ifndef #ifndef CONDITIONALS_LCD_H // Get the LCD defines which are needed first ^ In file included from sketch/pins.h:63:0, from sketch/MarlinConfig.h:33, from /Users/Twmaster/Documents/Marlin/Marlin-RC/Marlin/Marlin.ino:37: pins_RAMPS.h:376: error: #endif without #if #endif // ULTRA_LCD ^ exit status 1 unterminated #ifndef
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 08:54PM |
Re: DIY Tiny OLED I2C full graphics controller May 19, 2017 11:37PM |
Re: DIY Tiny OLED I2C full graphics controller May 20, 2017 01:37AM |
Re: DIY Tiny OLED I2C full graphics controller May 20, 2017 01:23PM |
Re: DIY Tiny OLED I2C full graphics controller May 20, 2017 04:01PM |
Re: DIY Tiny OLED I2C full graphics controller June 19, 2017 07:23PM |
Re: DIY Tiny OLED I2C full graphics controller July 19, 2017 10:29PM |
Re: DIY Tiny OLED I2C full graphics controller August 02, 2017 05:34AM |
Re: DIY Tiny OLED I2C full graphics controller August 02, 2017 10:28AM |
Re: DIY Tiny OLED I2C full graphics controller December 10, 2017 04:58AM |
Re: DIY Tiny OLED I2C full graphics controller December 10, 2017 07:13AM |
Re: DIY Tiny OLED I2C full graphics controller December 10, 2017 09:23PM |
