Re: The Remoter November 13, 2013 01:25PM |
Re: The Remoter November 13, 2013 01:31PM |
Admin Registered: 15 years ago Posts: 730 |
Re: The Remoter November 13, 2013 01:33PM |
Re: The Remoter November 13, 2013 03:43PM |
Re: The Remoter November 13, 2013 03:52PM |
Re: The Remoter November 13, 2013 04:24PM |
Re: The Remoter November 13, 2013 05:18PM |
Re: The Remoter November 13, 2013 06:10PM |
Re: The Remoter November 13, 2013 06:49PM |
. So one gear set works for one turning direction and the other set works on the opposite, with the torsion spring keeping the contact all the time, eliminating backlash, if I understood. I like it, much better than the worm design I did. I will incorporate a version on the design of the remoter, as a module to add.|
Re: The Remoter November 13, 2013 07:07PM |
Re: The Remoter November 14, 2013 02:12AM |
Re: The Remoter November 14, 2013 11:51AM |
Re: The Remoter November 14, 2013 12:17PM |
Re: The Remoter November 14, 2013 02:01PM |
Re: The Remoter November 14, 2013 03:35PM |
Re: The Remoter November 14, 2013 06:27PM |
Re: The Remoter November 17, 2013 07:15PM |
Re: The Remoter November 19, 2013 09:19AM |
Re: The Remoter November 19, 2013 10:54AM |
Re: The Remoter November 19, 2013 11:07AM |
Re: The Remoter November 19, 2013 11:24AM |
Re: The Remoter November 19, 2013 04:16PM |
Re: The Remoter November 19, 2013 07:09PM |
Guizmo
EDIT: SPAL patent was re-examined in 1999, so it's still enforced.Anyway, it's good to learn and improve existing technology. Let's make it better!
Re: The Remoter November 19, 2013 07:30PM |
Re: The Remoter November 20, 2013 09:49AM |
Re: The Remoter November 27, 2013 08:54AM |
Re: The Remoter November 27, 2013 11:02AM |
Re: The Remoter November 27, 2013 11:15AM |
Guizmo
@tjb1: Thanks for the comment. Yes, the cables are "twisted" but that does not affect the system. If you analyze carrefully, you will see that there is no correct direction of turning, becasuse you can mount the driven mechanism anyway you want, and it is supposed you can drive the motor to any direction you want, so that's no problem. In fact, crossing the cables allows them to flex more easily than running them in parallel.
Re: The Remoter December 09, 2013 10:59AM |
Re: The Remoter December 11, 2013 04:56PM |
