Re: Threadless Leadscrew ??? April 07, 2014 04:52PM |
Re: Threadless Leadscrew 4 bearing ?? April 10, 2014 06:48PM |
Re: Threadless Leadscrew 4 bearing ?? April 10, 2014 07:36PM |
Re: Threadless Leadscrew 4 bearing ?? April 13, 2014 06:41PM |
Re: Threadless Leadscrew ??? April 24, 2014 06:08PM |
Re: Threadless Leadscrew ??? April 24, 2014 10:44PM |
Re: Threadless Leadscrew ??? April 24, 2014 10:45PM |
Re: Threadless Leadscrew ??? April 24, 2014 11:46PM |
Re: Threadless Leadscrew ??? April 24, 2014 11:52PM |
Re: Threadless Leadscrew ??? April 25, 2014 12:07AM |
Re: Threadless Leadscrew ??? April 25, 2014 12:35AM |
cozmicray
I noticed when I put Red 3 rider on that two of the bearings were not rotating
so I reworked bearing mounts and added washers between bearings and PLA.
I have black marks on outer race of all bearing to show rotation.
cozmicray
I also notice compression by bolt on top
does not provide even pressure on all bearings.
The ultimate rider may need independent tensioning on each bearing
but that is individual tension and angle on each bearing set.
Have to work on that design.
cozmicray
Might be easier to just laser measure where the hot end really is?
Re: Threadless Leadscrew Duel Rider April 28, 2014 04:25PM |
Re: Threadless Leadscrew Duel Rider April 28, 2014 04:28PM |
Re: Threadless Leadscrew New Design Rider April 28, 2014 04:52PM |
Re: Threadless Leadscrew Duel Rider April 28, 2014 07:06PM |
Re: Threadless Leadscrew Duel Rider April 28, 2014 08:06PM |
Re: Threadless Leadscrew ??? April 28, 2014 08:58PM |
Re: Threadless Leadscrew ??? April 28, 2014 09:04PM |
Re: Threadless Leadscrew ??? April 28, 2014 09:05PM |
Re: Threadless Leadscrew ??? April 28, 2014 09:07PM |
Re: Threadless Leadscrew ??? April 28, 2014 09:13PM |
Re: Threadless Leadscrew ??? April 28, 2014 11:06PM |
Re: Threadless Leadscrew ??? April 28, 2014 11:16PM |
Re: Threadless Leadscrew ??? April 28, 2014 11:18PM |
cozmicray
3 compression splits would make the rider fall apart, at least very wobbly?
I suppose 2 or three compression bolts between each split?
Re: Threadless Leadscrew New Design nada May 01, 2014 08:22PM |
Re: Threadless Leadscrew ??? May 07, 2014 05:02AM |
Re: Threadless Leadscrew ??? May 12, 2014 09:42PM |
Re: Threadless Leadscrew ??? May 14, 2014 12:59PM |
Re: Threadless Leadscrew ??? May 14, 2014 02:35PM |
cozmicray
So you think if the rider were milled out of metal it would solve the problem?
Re: Threadless Leadscrew ??? May 14, 2014 04:45PM |
