Re: 1mx1m hot plate? June 21, 2016 07:54AM |
Re: 1mx1m hot plate? June 22, 2016 12:32AM |
rowow
If that's the best you guys can provide then im done. Again, half of what you said is completly bs and is not an issue. Adequate 5v power supply? My ramps board has NO issues running a full graphics display. Maybe you should quit paying $30 for a cheap broken board. And stepper driver cooling? Again, WHO HAS ISSUES WITH THAT??? I use drv8825, the most heat producing stepper controller, and all I need is a small heatsink and a fan on top and its fine. Yes I know your supposed to cool it from underneath. But in the end, IT DOESN'T MATTER.
You all remind me of managers in a meeting complaining about the most stupid things when in real life none of those exists and you have much greater problems to worry about. Have fun with your $150 ripoff board while for the same price ill have octoprint and 50v, 4a, 128step, stepper controllers.
aussiephil
I shouldn't be surprised that people are prepared to pay $10 for a controller then spend 10's of hours making it work or getting multiple return/refund cycles when an initial outlay on a more modern board (any 32 bit board) may have saved time and effort. This drive to save every cent with the cheapest capital outlay is not in any way unique to this hobby
I for one would rather spend the $$ upfront and be printing things but I understand not everyone has the money to do this.
Its $8 for a board... The reason people are not spending $150 for a junk board is because its a waste of money, not because people don't have money. The reprap community would rather save 5$ here and there and it all stacks up to hundreths of dollars. Your illogical reasons is why 3d printers costed at least $500, while you can make one yourself for $300. All because american manufacturers like you wasted money left and right while other people can build it for cheaper, and spend the rest of the money on upgrades and parts.
With the recent issue it at max took 4 hours of my time, not 10's, which is alot but this is a one time problem and in the dozens of printers I made I never had a issue like this. If you read the post you would understand the issue...
So please dont lie and spread bullshit. The least you can do is read the post as I have already explained the situation multiple times.
Re: 1mx1m hot plate? June 22, 2016 12:38AM |
rowow
Seems digital dentist was correct. This is yet agian very sad and depressing to me. To see the reprap community waste $150 solving issues which on paper look amazing, however in real life are only little setbacks and are easily solved. If someone can provide a ACTUAL reason to move to 32 bit then im glad to hear. However for $150 its not worth it and I will wait until other manufacturers lower the price down to $50 where it will actually be worth it.
Re: 1mx1m hot plate? June 22, 2016 07:17AM |
Re: 1mx1m hot plate? June 22, 2016 09:38AM |
rowow
Make forums.reprap.org great agian.
Re: 1mx1m hot plate? June 22, 2016 10:00AM |
Re: 1mx1m hot plate? June 22, 2016 11:02AM |
Re: 1mx1m hot plate? June 22, 2016 03:48PM |
rowow
Re: 1mx1m hot plate? June 22, 2016 03:57PM |
stephenrc
rowow
One reason RAMPS is cheap, it's open source. Which let's anyone produce it, even if they don't use the correct parts. When 1.4 was released, it was around $100 without the Mega, cheaper if you did all the soldering yourself. The specs called for it to be able to run on 24vdc, but practically all the cheap ones available today can't do that.
Most of the 32-bit hardware isn't opensource, since they want to control the quality of the product and not have it produced cheaply in China with their variable quality problems. Look what happened with the RAMPS-FD, a Chinese company started making them before the design was finalized and it's a fire hazard.
When someone is only looking at the price of something and it has to be cheap, they sure can make excuses to not use something. Those $200 3d printers are usually not able to print anything without a lot of work and they usually get the most "help my printer doesn't work" posts here, if they even get that far.
Re: 1mx1m hot plate? June 22, 2016 04:28PM |
Re: 1mx1m hot plate? June 22, 2016 05:12PM |
stephenrc
Re: 1mx1m hot plate? June 22, 2016 05:20PM |
Re: 1mx1m hot plate? June 22, 2016 06:02PM |
rowow
I really like the RADDS due to the 3 extruders and 24v capability.
rowow
Finally thanks for telling be about the Arduino Due! I dont understand why more people dont use it. Its compatible with ramps1.4 and is only a few dollars extra compared to the mega2560.
Re: 1mx1m hot plate? June 22, 2016 06:41PM |
dc42
rowow
As you are a cheapskate, you will find the cost of Arduino Due + RADDS + decent stepper driver modules far too expensive for your liking.
rowow
If you believe it is compatible with RAMPS 1.4, you are sadly mistaken.
Re: 1mx1m hot plate? June 22, 2016 07:06PM |
dc42
stephenrc
I am sorry, but you could not be more wrong. The original 32-bit electronics designs (Duet, Smoothieboard and now Gen 7 32-bit) are open source designs. It's the Chinese near-clones of Smoothieboard that are closed source.
Re: 1mx1m hot plate? June 22, 2016 07:54PM |
Re: 1mx1m hot plate? June 22, 2016 08:04PM |
frankvdh
Sheesh! Calm down folks! Name-calling isn't helping.
$150 is I think a fair price for dc42's board. You have to pay to be at the 'bleeding edge', because there's only a few people to share the design costs. It's not fair to expect dc42 to design a board for free so that the Chinese can make a profit by mass-producing it so that *I* can get it cheaply. OTOH, I won't be buying one, because (a) I can manage with an Arduino+RAMPS for now, and (b) I expect that a better design will become available soon, and (c) I can spend that money on something else.
So, apparently, I am a cheapskate; I have a secondhand PrintrBot and a cheap-as-possible Chinese delta and a RAMPS/Mega2560 for my next printer and a bunch of other parts in my garage. That's fine. The reason I'm a cheapskate (apart from being a miserly character) is that this is a *hobby* to me. It just has to squirt some seratonin into my brain now and then. For me, that means it has to be fun and interesting and I learn stuff. Overcoming the limitations of whatever I have is important; if I had a printer that printed twice as fast and twice as reliably with twice the quality, I'd just want to make something 4 times as big and complex. My printer doesn't have to be the latest and greatest, although I want to at least be in sight of the leading edge. I don't have to put a dollar value on the hours I spend fiddling with a printer. It doesn't have to be value-for-money, except in comparison with buying a new couch or a bottle of wine or some other seratonin-producing activity.
Other people are different. Some people are treating this as a job. That's fine for them, but I already have a job, which involves deadlines and money and pressure and stuff like that. I don't want another job (unless it means I can ditch the first job). If this was a job, I'd weigh up the costs vs the benefits and maybe just buy the latest and greatest. If something broke, I'd pay someone like aussiephil to fix it for me, ASAP. Or maybe I'd buy 10 cheap Chinese printers, expect 2 to be good, 5 to be mediocre, 3 to be broken at any one time, and hire rowow to keep them running. Either way, I'd pass the costs onto my customers, and I wouldn't learn anything much about calibrating printers and driving steppers and a million other possibly-worthless things.
Let's just get some signal into this noise.
Re: 1mx1m hot plate? June 22, 2016 08:11PM |
rowow
As you are an ignorant user who cant read english you will find I already explained that the arduino due is only a few dollars more then the mega2560, and the radds is only 60$ vs your $150 board... And stepsticks cost $2 a pop...
Re: 1mx1m hot plate? June 22, 2016 09:11PM |
dc42
rowow
How much does a genuine Arduino Due cost in your country? $30? [except they have been discontinued now]. And if you only pay $2 for stepsticks, you can expect a lot of failures, so better budget for about twice the number you need. Add the RADDS and you've already exceeded $100, and you still don't have properly-cooled drivers, or software-controlled motor currents, or a web interface. Maybe you have a lot of free time on your hands to spend on getting things working, but to a lot of people, spending that extra $50 to avoid a lot of hassle is worth it.
Re: 1mx1m hot plate? June 22, 2016 10:10PM |
Re: 1mx1m hot plate? June 23, 2016 04:24AM |
frankvdh
Re: 1mx1m hot plate? June 23, 2016 06:25AM |
rowow
Found a cheaper and simpler option for a web interface on a radds board.
[forums.reprap.org]
Rather then spending $40 for a raspberry pi. You only need a $5 wifi module (ESP8266) and a few resistors.
Re: 1mx1m hot plate? June 23, 2016 06:42AM |
aussiephil
frankvdh
Been trying to, but as per the post two up the ranting and raving continues. There is only one side and that's rowow's side................
Rowow - show me a successful 24hr plus print from one of your dozen printers..... your continued ranting shows you to be just what you really are..... one of those fanboi zealots that can only see one way, they exist everywhere on all forums and you are the classic example, We have accepted that your a cheapskate (oh wait... frugal sensible person) that will never move past the cheapest option.... FINE but stop telling the rest of us we are stupid for choosing to use what WE consider a far better and professional set of components.
Re: 1mx1m hot plate? June 23, 2016 06:44AM |
dc42
rowow
[forums.reprap.org]
That will give you a web interface, but without gcode file upload to your SD card at anything resembling a reasonable speed. If you want that, you are back to spending $40 on a RPi. Add that to the ~$90 you've already spent, and you have now spent ~$130. You are only $20 short of the price of a Duet, with its properly-cooled drivers, adequate 5V power supply, software-settable stepper motor currents, and other features including configuration file editing and firmware updating in the web interface.
Re: 1mx1m hot plate? June 23, 2016 07:33AM |
rowow
dc42
rowow
[forums.reprap.org]
Reasonable speed?... Is waiting 5 seconds to much for you?
Re: 1mx1m hot plate? June 23, 2016 07:41AM |
dc42
rowow
dc42
rowow
[forums.reprap.org]
5 seconds upload time for a reasonable sized print file would be very acceptable. Let me know when you've achieved that. Hint: one of the posts in that thread mentions 3Kbytes/sec upload speed.
Re: 1mx1m hot plate? June 23, 2016 08:14AM |
Re: 1mx1m hot plate? June 23, 2016 08:23AM |
the_digital_dentist
Why waste money buying electronic components when you can easily make them yourself and get exact values that you need instead of being forced to use "standard" component values?
DIY resistors: [www.troelsgravesen.dk] and [www.instructables.com]
DIY capacitors: [www.youtube.com] and [www.instructables.com]
Connecting all those parts together is usually done using a printed circuit board. Thousands of hobbyists make thier own PCBs every day:
[www.youtube.com] [www.instructables.com]
Some people even make their own semiconductors. Imagine the savings if you could make the CPU and stepper drivers yourself!
Why leave semiconductor manufacturing to the poor quality processes used by big companies- if you DIY you have complete control over the quality!
Some would argue that a PCB is a total waste of money. All it does is replace cheap wires with expensive fiberglass and copper foil that has to be custom etched and drilled. How do you think they wired things before PCBs were invented? Everyone knows electronic stuff worked better and more reliably in "the good old days". That was because they used point to point wiring and vacuum tubes. I have radios made in the 1930's that still work. Show me anything made using semiconductors on PCBs that works even 20 years later...
[makezine.com]
Vacuum tubes are even easier/cheaper to make than semiconductors: [makezine.com]
Re: 1mx1m hot plate? June 23, 2016 08:43AM |
Re: 1mx1m hot plate? June 23, 2016 08:55AM |
