Power Wiring December 27, 2017 05:22PM |
Re: Power Wiring December 29, 2017 03:49AM |
Re: Power Wiring December 29, 2017 09:16AM |
Re: Power Wiring December 29, 2017 10:47AM |
Re: Power Wiring December 29, 2017 11:12AM |
Re: Power Wiring December 29, 2017 11:20AM |
the_digital_dentist
3) 0.4-0.5W / cm^2 will heat it up quickly and allow the PID control to regulate it easily. That bed size is small and doesn't need a very high powered heater. You have 169 cm^2 so I'd look for a heater that's around 75W. With such a low powered heater you could just run it from the DC supply and save the messing around with line power. The controller board MOSFETs should easily handle switching power to that load.
Re: Power Wiring December 29, 2017 05:26PM |
Re: Power Wiring December 29, 2017 07:24PM |
Re: Power Wiring December 30, 2017 01:05PM |
The internal fuse will be rated for the maximum power the PSU can supply, you should add an own fuse for the heat bed that is rated for it, the internal fuse of the PSU might set in to late.Quote
FA-MAS
So, checking with Mean Well if that power supply has a fuse, if it does, I needn't add one correct? If it doesn't I'll add one.
Re: Power Wiring November 19, 2018 01:49PM |
the_digital_dentist
Re: Power Wiring November 19, 2018 05:26PM |
Re: Power Wiring November 19, 2018 06:13PM |
Re: Power Wiring November 20, 2018 03:09PM |
FA-MAS
You can reach abs temps too?
Looking at the Crydom D2425 or D2410
Seeing as though the bed will only take 3A @ 120V, the D2410 should be enough without a heatsink shouldn't it?
Re: Power Wiring November 20, 2018 06:21PM |
Re: Power Wiring November 21, 2018 02:44AM |
Re: Power Wiring November 30, 2018 06:15PM |
Re: Power Wiring November 30, 2018 07:02PM |
Re: Power Wiring December 01, 2018 09:29AM |
the_digital_dentist
It would be a good idea to connect the negative side of the power supply to the line input ground on the frame. That will help with protecting the electronics from static discharges, etc.
Re: Power Wiring December 01, 2018 09:54AM |
Re: Power Wiring December 01, 2018 11:43AM |
Re: Power Wiring December 02, 2018 02:05AM |
PDBeal
.... Beyond that, I wouldn't bother connecting 0V to ground.
Re: Power Wiring December 02, 2018 08:14AM |
Re: Power Wiring December 02, 2018 08:45AM |
Re: Power Wiring December 02, 2018 10:35AM |
Re: Power Wiring December 02, 2018 03:34PM |
Re: Power Wiring December 02, 2018 09:20PM |
MKSA
Note, it is the LAW to ground all metallic frames, parts ...
