Best way to make use of these Powdered Bronze Bushings? May 10, 2019 12:13PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Best way to make use of these Powdered Bronze Bushings? May 13, 2019 12:57AM |
Re: Best way to make use of these Powdered Bronze Bushings? May 13, 2019 04:37AM |
Diggrr
I noticed some time ago, the original corexy epoxied the bushings to the carriage plate instead of trying to constrain them in a holder. It would seem smarter to let gravity do the perfect alignments (assuming the rods are perfectly parallel).
I've also built an X axis trying this method, and it glides so smooth and fast, it's quite ridiculous. Soon I'll be getting back to that project.
Edit: Here's a pic of my solution, epoxied while oriented vertically above one side's bushings, then to the other side's bushings. The carriage was modeled with 1mm extra clearance for the epoxy.
Re: Best way to make use of these Powdered Bronze Bushings? May 13, 2019 06:53PM |
Re: Best way to make use of these Powdered Bronze Bushings? May 15, 2019 01:14AM |
Ohmarinus
Did you mount the bushings with the rods flat on a table or did you mount the rods in the machine first and only then glued it? I also notice your bushings are longer than mine, maybe that makes them less bindy.
Re: Best way to make use of these Powdered Bronze Bushings? May 15, 2019 01:37AM |
Re: Best way to make use of these Powdered Bronze Bushings? May 23, 2019 03:27AM |
Re: Best way to make use of these Powdered Bronze Bushings? May 23, 2019 04:06AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Best way to make use of these Powdered Bronze Bushings? May 24, 2019 04:34AM |
Re: Best way to make use of these Powdered Bronze Bushings? May 24, 2019 04:50AM |
Re: Best way to make use of these Powdered Bronze Bushings? May 24, 2019 08:20AM |
VDX
... "non-parallel" binding can be avoided by designing one rail "fixed" and the other with some "play" towards the fixed one (evantually supported with springs for heavy masses) ...
Re: Best way to make use of these Powdered Bronze Bushings? May 24, 2019 08:51PM |
Re: Best way to make use of these Powdered Bronze Bushings? May 26, 2019 05:07AM |
Re: Best way to make use of these Powdered Bronze Bushings? May 29, 2019 08:22AM |
