Introducing the Prism Mendel December 23, 2011 01:00PM |
Re: Introducing the Prism Mendel December 24, 2011 05:40PM |
Re: Introducing the Prism Mendel December 25, 2011 12:02AM |
Re: Introducing the Prism Mendel December 25, 2011 10:05AM |
Re: Introducing the Prism Mendel December 25, 2011 11:05AM |
Re: Introducing the Prism Mendel December 25, 2011 12:11PM |
Re: Introducing the Prism Mendel December 25, 2011 12:55PM |
/\ / \ / \ / /[/b] \ --------The top "V" shape is the frame, and the bottom "V" in bold is the piece. the piece can only touch both sides of the frame at the very top, which is alligned right in the center of the bottom frame element. I think you understood that part, but i just wanted to clarify.
Cross section of Extrusion, with a screw in the channel: ===== ||===== Screw on right side of channel =====|| ===== Screw on left side of channel ===== || ===== Screw can only move 1mm to either side of center (6mm channel, 4mm screw)
Re: Introducing the Prism Mendel December 25, 2011 02:50PM |
Re: Introducing the Prism Mendel December 25, 2011 09:25PM |
Re: Introducing the Prism Mendel December 26, 2011 01:07AM |
Re: Introducing the Prism Mendel December 28, 2011 02:18PM |
Re: Introducing the Prism Mendel December 31, 2011 09:51AM |
Re: Introducing the Prism Mendel December 31, 2011 05:44PM |
Re: Introducing the Prism Mendel December 31, 2011 06:38PM |
Re: Introducing the Prism Mendel January 01, 2012 08:46AM |
Re: Introducing the Prism Mendel January 04, 2012 04:04PM |
Re: Introducing the Prism Mendel January 05, 2012 06:17AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Introducing the Prism Mendel January 05, 2012 10:42AM |
Re: Introducing the Prism Mendel January 13, 2012 08:31AM |
Re: Introducing the Prism Mendel January 20, 2012 04:27AM |
Re: Introducing the Prism Mendel January 20, 2012 11:36AM |
Re: Introducing the Prism Mendel January 29, 2012 04:12PM |
Re: Introducing the Prism Mendel January 30, 2012 10:55AM |
Re: Introducing the Prism Mendel January 31, 2012 04:35AM |
Re: Introducing the Prism Mendel January 31, 2012 10:35AM |
Re: Introducing the Prism Mendel February 03, 2012 04:37PM |
Re: Introducing the Prism Mendel February 04, 2012 02:47AM |
If you currently have a Mendel (particularly a Sells Mendel because of the belts and Z gears) this frame is quick, relatively cheap upgrade
Re: Introducing the Prism Mendel February 04, 2012 01:03PM |
Re: Introducing the Prism Mendel February 14, 2012 03:18AM |
Re: Introducing the Prism Mendel February 24, 2012 09:44AM |
