Introducing the Prism Mendel
Posted by Buback
Re: Introducing the Prism Mendel
August 16, 2012 10:39AM
rGlory Wrote:
> >Placing the rods under the the frame should
> provide additional Z - about 55mm compared to
> placing them on top
> I understand that. But if you would not let build
> stage and bed move over the extrusion then maximum
> work area for Y will be 250mm for 500mm extrusion
> (btw I missed moment when extrusions became 500mm
> instead of 400mm) or 200mm for 400mm extrusions
> maximum. But that in case if build stage exactly
> the same size as bed, usually it is bigger, that
> makes work area even smaller.
You are correct. The build stage will pass above the stepper and mount at Ymax.
Also, the machine I'm building uses 500mm extrusions because I wanted to make something that has a larger build envelope. 400mm extrusions and M8 axes are still the standard. A 400mm machine should be able to accommodate up to around ~ 300mm wide drive and build stages, providing plenty of room for leveling mechanisms and a standard PCB heated bed (215x215).
Once the larger machine is up and running I'm going to scrap my Prusa and upcycle it into a 400mm Prism.
Working on the wiring tonight. Once that's done it's really down to finishing the Y-axis drive and build stages - and the 300mm square heated bed. We'll see if I did my math right...
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
August 17, 2012 11:04AM
Hi everybody.
Can anyone tell me their opinion on prism vs mendelmax?
After far too long futzing, I have my prusa mendel almost functional. Sooo, next step, since there are 3 of us sharing it, is to build another one, right?
I have been investigating options, and since the frame pieces on the prusa, being allthread, have always been a bit flaky, I thought I would go extruded aluminum for the next one.
August 17, 2012 08:55PM
Idaholion Wrote:
> Hi everybody.
> mendelmax?
> one, right?
I don't think you can go wrong with either one. The MendelMax is nice and has good support (quite a few have been built), but the prism is a bit simpler using all the same length extrusions.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
September 12, 2012 04:04PM
Prism Mendel 1.5
Instructions and source files available.
Source files were generated with 123D.
First working Prism 1.5.
Oversize Prism 1.5 coming online soon.
6020
Edited 1 time(s). Last edit at 09/12/2012 04:05PM by akhlut.
- akhlut
September 13, 2012 06:50AM
Excellent work on the visual guide akhlut, thanks a lot.
Now I can recommend people to build a Prism even as their first reprap !
September 13, 2012 09:36AM
Thanks!
I wanted to include the X,Y and Z-axis setup, but didn't as there are so many variations. That and the fact that the Prism I'm building now is not a standard size and doesn't use standard parts - don't want to confuse anyone with oddball hardware.
Also, going back over the build guide I've spotted several minor errors, so there will be a v 0.2 coming out soon!
- akhlut
September 13, 2012 03:10PM
Great work! and feel free to add a link to the prism wiki page!
Edited 1 time(s). Last edit at 09/13/2012 03:12PM by Buback.
September 16, 2012 12:43AM
I finally got back to building my Prism... I have all the axis attached. Electronics are fully functioning. Need to make a case for the RAMPs with alum extrusion mounting options. The I will work on the Bowden extruder and the build surface. I hope to have it done by Thanksgiving... smileys with beer You can see pictures of the build at the following link:
[picasaweb.google.com]
Once I cleanup the OpenSCAD files for the Makerslide plastic parts, I will update my github prism branch (https://github.com/egenoup/Prism-Reprap)
September 22, 2012 04:33PM
akhlut,
the link to github is brocken.
[github.com]
what's problem ?
Edited 1 time(s). Last edit at 09/22/2012 04:33PM by paoparts.
blog Paoparts
September 26, 2012 08:25AM
Prism Mendel 1.5 github is back up.
New top option available.
- akhlut
September 28, 2012 04:54AM
Paoparts, when this happens, you can just navigate back up to the user github home and check his projects list : [github.com]
September 28, 2012 04:55AM
By the way, I'm going ahead and asking for a specific Prism Forum.
This post is going way too long now.
VDX
September 28, 2012 05:44AM
... should I move this complete thread into the Prism-forum?
Viktor
September 28, 2012 06:11AM
If it's easy, I'd say yes.
Otherwise we could just post a sticky in the newly created forum to point here.
September 28, 2012 05:41PM
I still can't view the github page - could that site be any crappier to navigate?
OK, works now - operator error smiling smiley
Edited 1 time(s). Last edit at 09/28/2012 06:03PM by Wired1.
_________________________________________________________________________________________
Richmond, New Zealand
Thingiverse ~ YouTube
October 02, 2012 07:50AM
I got 404-ed trying to follow the github link as well.
Thanks for the link to the top of the tree.
Edited 2 time(s). Last edit at 10/02/2012 07:52AM by a_shorething.
October 02, 2012 02:07PM
Sorry, I forgot to update the direct link!
[github.com]
> well.
> navigate
- akhlut
October 18, 2012 07:40AM
Has anyone got an assembly of this machine in something like step or iges format as I would love to modify my machine to an extruded frame?
October 18, 2012 09:07AM
martinp, the sources are in Autodesk 123D format, check on akhlut github.
If you really need step or iges you'll have to do the convert job.
October 18, 2012 09:16AM
Martin,
123D can export to those formats. Which would you prefer?
- akhlut
October 18, 2012 10:17AM
I think step format would be nice as it preserves the assembly structure better and seems to be the new standard for higher end CAD systems.
An upload in .step format to grabcad would certainly raise the profile of this printer.
edit. I downloaded and installed 123D and now have a copy in .step format. It doesn't convert exactly, but there is sufficient to get me going. Thanks
Edited 1 time(s). Last edit at 10/18/2012 12:52PM by martinprice2004.
