Re: Bed Auto Leveling.. check this out December 24, 2013 07:12PM |
Enlightx
any one finding they are getting lots of servo chatter?
iv tried shielding cable still get gitter. iv had to use an external 5v supply as the gitter is taking too much strain on the 5v line of the arudino and voltage regulator is getting too hot and crashing 5V line to atmega chip.
also what are people using for servos currently? would be interested in getting one that no one has issues with.
Re: Bed Auto Leveling.. check this out December 24, 2013 08:47PM |
jwd
Hi Everyone,
I have a RUMBA board and my servo voor the auto bed leveling feature is delivered tomorrow. Does anyone know how to connect the servo to the RUMBA board?
(I can find a ground and a 5 V pin on the board but where must i connect the third pin?
Re: Bed Auto Leveling.. check this out December 24, 2013 10:24PM |
Re: Bed Auto Leveling.. check this out December 24, 2013 10:29PM |
uncle_bob
I've tried several servos. None of them have created issues for the Mega 5V regulator.
Re: Bed Auto Leveling.. check this out December 25, 2013 01:46AM |
Re: Bed Auto Leveling.. check this out December 25, 2013 11:11AM |
Re: Bed Auto Leveling.. check this out December 25, 2013 03:38PM |
Re: Bed Auto Leveling.. check this out December 25, 2013 03:57PM |
Re: Bed Auto Leveling.. check this out December 25, 2013 05:13PM |
Re: Bed Auto Leveling.. check this out December 25, 2013 05:44PM |
Re: Bed Auto Leveling.. check this out December 26, 2013 08:04AM |
regpye
Yeah, looks pretty good stevenrc.
I am working on one specifically for the Prusa i3 and will upload when finished.
Re: Bed Auto Leveling.. check this out December 26, 2013 01:30PM |
Re: Bed Auto Leveling.. check this out December 26, 2013 08:35PM |
Re: Bed Auto Leveling.. check this out December 26, 2013 09:10PM |
momentum
When running G29, the z-probe drops into position, touches twice, then retracts the z probe, before pulling up 5 mm between measurement points. Typically in all the videos I've watched the z-probe stays down until its finished measuring all the points. My probe pulls up in between measurement points. This cause the corners of the microswitch to dig into my heatbed during the z-probe retract.
Re: Bed Auto Leveling.. check this out December 27, 2013 08:05AM |
Re: Bed Auto Leveling.. check this out December 27, 2013 09:49AM |
-DUS-
Thanks!
I applied the above modifications, and now the Z_raises work normally for G29. Howver, for G28 the issue remains. Is that described somewhere else in the code?
Re: Bed Auto Leveling.. check this out December 27, 2013 03:59PM |
Re: Bed Auto Leveling.. check this out December 27, 2013 06:20PM |
Re: Bed Auto Leveling.. check this out December 27, 2013 10:14PM |
Re: Bed Auto Leveling.. check this out December 28, 2013 01:18AM |
regpye
Try using this configuration. You will need to rename it.
Re: Bed Auto Leveling.. check this out December 28, 2013 02:15AM |
momentum
regpye
I made one change on the following line because it was throwing a bunch of errors in the font definition.
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
It now touches 3 (not 4) points during the G29 but still lifts the Z-probe between points.
I see some new lines of code in my version of the config.h. Maybe the lift between z-probes is a new "feature"??
Thank you for the help!!
Re: Bed Auto Leveling.. check this out December 28, 2013 10:08AM |
regpye
momentum
regpye
No worries for the help, glad to assist.
Where did you get your configuration file? I noticed the different lines of code, not seen that before.
Re: Bed Auto Leveling.. check this out December 28, 2013 10:15AM |
Re: Bed Auto Leveling.. check this out December 28, 2013 03:55PM |
regpye
Seems very strange. Not only is it lifting the probe between sensing, it is also probing in all four corners while everyone else probes in three corners only. How about showing us the start of your G-code so we can see what it is suppose to be doing?
Re: Bed Auto Leveling.. check this out December 29, 2013 06:21AM |
Re: Bed Auto Leveling.. check this out December 29, 2013 12:07PM |
Re: Bed Auto Leveling.. check this out December 29, 2013 12:11PM |
Re: Bed Auto Leveling.. check this out December 29, 2013 01:37PM |
Re: Bed Auto Leveling.. check this out December 29, 2013 09:56PM |
Re: Bed Auto Leveling.. check this out December 29, 2013 11:19PM |
