Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 04, 2014 01:22AM |
bobc
That is not how an inductor works. Flux is generated from the current. Even in an inductor, voltage generates the current. It does not just grow by itself.Quote
NoobMan
So again, its not a current sinusoid that is generated eslewhere than forced into the coil. Current just grows in the coil as result of playing with voltage, and that is the elemental law of the inducutor. Voltage across inductor builds the flux, to which the current is proportional. Now if you understand that, you will see previous statements differently and, even if most ppls dont see it, some other parts.
An inductor only generates current "by itself" when you remove the external voltage, and the flux collapses.
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 05, 2014 08:03AM |
uncle_bob
In the world of printers, we (hopefully) smoothly accelerate and decelerate the stepper. That means we have a varying frequency sine wave that's the drive in the high speed case that this all came out of. The discussion is revolving around a high rpm rather than a low RPM use case. In the low RPM case you do get steps in the current, but you are in what we are calling an "ohms law" region.
uncle_bob
We very much do generate a sinusoidal current to drive a stepper motor.
uncle_bob
The stepper is being operated as s synchronous AC motor when it's in micro stepping mode. The data sheets for the stepper chips show this very clearly.
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 05, 2014 04:52PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 05, 2014 08:43PM |
For example when the final value is lower than our setting. For example 12v and 24ohm resistor, then ohms law gives 0.5A final value, and current cant get higher than that. You can set in controller 1A, but ofc it can not get there - can it.Quote
In what cases does the current not reach the peak value set by the controller?
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 05, 2014 10:03PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 06, 2014 01:47PM |
Bob and his ultimate wisdom againQuote
bobc
NoobMan
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 07, 2014 05:31PM |
NoobMan
bobc
NoobMan
Please read again, what i said is this: "current just grows in the coil as result of playing with voltage". I didnt said the current "grows by itself", but as a result of "playing with voltage". E.g. voltage being applied. And if you read my entire post, you will see the reply was about uncle saying that stepper driver is making a current sinusoid and forces it into the coil. And in turn i said its the driver "plays with voltage", and hence the current is a result of the *driver* "playing with voltage".
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 07, 2014 09:29PM |
bobc
The bit I had issue with is: What you said
Voltage across the inductor generates current, and the current generates the flux.Quote
noobman
