Re: Cherry Pi III Is Available July 21, 2014 10:06AM |
Re: Cherry Pi III Is Available July 21, 2014 11:58AM |
Re: Cherry Pi III Is Available July 21, 2014 12:25PM |
Re: Cherry Pi III Is Available July 21, 2014 12:28PM |
Re: Cherry Pi III Is Available July 21, 2014 07:44PM |
AndyCart
Not so fun when you are stuck in a hotel room in a strange town eating dinner alone! lol
Re: Cherry Pi III Is Available July 26, 2014 07:16PM |
Re: Cherry Pi III Is Available July 27, 2014 04:20AM |
KtB
Hi Andy
Printer is running well but I'm after a favour![]()
I am wanting to make some changes to the effector and the j-head clamp as i find the mounting holes for the fan and the spring system for the z-probe a bit fragile.
Is it possible to get a copy of your sketch up files for them so i can make some modifications please. I know i can import the stl files into sketch up but its a pain dealing with all the extra facets created that way.
Thanks in advance
Re: Cherry Pi III Is Available July 27, 2014 04:34AM |
AndyCart
KtB
Hi Andy
Thanks in advance
I've added it to the Thingiverse page
Andy
Re: Cherry Pi III Is Available July 27, 2014 04:51AM |
Re: Cherry Pi III Is Available July 27, 2014 12:08PM |
Re: Cherry Pi III Is Available July 28, 2014 09:15AM |
Re: Cherry Pi III Is Available July 28, 2014 09:44AM |
Re: Cherry Pi III Is Available July 28, 2014 09:03PM |
Re: Cherry Pi III Is Available July 28, 2014 09:42PM |
Re: Cherry Pi III Is Available July 29, 2014 11:07AM |
Re: Cherry Pi III Is Available July 29, 2014 11:12AM |
Re: Cherry Pi III Is Available July 29, 2014 03:49PM |
disneytoy
What size braided wire sleeving did you use? I need to order some. Thanks. Looks really good.
I used this [www.amazon.co.uk]
Re: Cherry Pi III Is Available July 31, 2014 01:42PM |
Re: Cherry Pi III Is Available July 31, 2014 01:58PM |
maso
The new string-spring plan looks like a good one!
Is the change due to some problem with the magnet plan, or is it more to simplify the design? I haven't quite finished my printer yet, so haven't had a chance to explore the limitations of the magnets.
Also, I see what you've done with the spring-loaded hotend--placing a cross bar to get both springs on there. I've been struggling with a good implementation for mine, and this new idea looks like a good one. Thanks!
Oh, and I like the coffee cup, too.
Re: Cherry Pi III Is Available July 31, 2014 02:01PM |
maso
A thought that occurred to me while I was building my printer was that if the pivot-points for the arms (was magnets, now balls) were located higher up on those carriages, it'd be possible to get some more height for a given frame size. I toyed with the idea of flipping the carriages upside down, but of course the hinge wasn't designed that way.
So my question: is there a reason, other than aesthetic, that the magnets are placed at the bottom of the carriages?
Re: Cherry Pi III Is Available July 31, 2014 02:04PM |
Re: Cherry Pi III Is Available July 31, 2014 05:41PM |
Re: Cherry Pi III Is Available July 31, 2014 07:23PM |
Re: Cherry Pi III Is Available August 01, 2014 02:08AM |
lines11
Ok, i'll Check this tomorrow.
Thank you for your fast answer.
I saw your last posts, maybe that will solve my
Problem, because I saw that one rod lost conntact with the magnet ball,
When I drive to a position far away from x0,y0, like y80 x30 or something like that.
I think I reassemble a line, but I like to use the magnet balls anyway.
Where are the endstop positions in marlin saved, when I adjust them with m666, sorry for my lot questions and for my english. I can't find the most informations in German.
Re: Cherry Pi III Is Available August 01, 2014 06:24AM |
Re: Cherry Pi III Is Available August 01, 2014 07:59AM |
Re: Cherry Pi III Is Available August 01, 2014 08:20AM |
Re: Cherry Pi III Is Available August 01, 2014 10:15AM |
Re: Cherry Pi III Is Available August 01, 2014 11:15AM |
lines11
Thank you,
i never used reptier till now, i think i have to. i readjusted my cp now with m666 its much easiear and safes a lot time i waste one week, if i have questions i ask you earlier.i print at the moment a cube, it looks like that the extruder make much steps (440) with the cherry pi III extruder. is it right that the disadvantage of eeprom is, when i upload another firmware to my arduino the configuration is lost or is my thinking wrong?
Re: Cherry Pi III Is Available August 01, 2014 11:38AM |
