Re: Cherry Pi III Is Available September 16, 2014 09:01AM |
Re: Cherry Pi III Is Available September 16, 2014 07:28PM |
Re: Cherry Pi III Is Available September 16, 2014 08:04PM |
Re: Cherry Pi III Is Available September 17, 2014 06:14PM |
Re: Cherry Pi III Is Available September 18, 2014 12:43AM |
Re: Cherry Pi III Is Available September 18, 2014 03:15PM |
Re: Cherry Pi III Is Available September 18, 2014 09:15PM |
AndyCart
That's very possible. They were designed for the Bosch/Rexroth compatible extrusion that I use from KJN in the UK.
Re: Cherry Pi III Is Available September 18, 2014 09:22PM |
Re: Cherry Pi III Is Available September 19, 2014 01:04AM |
maso
I used OpenBuild V-slot too, and for me it was more than a few mm. I was using 10-32 hardware, so that might affect things a bit. But I couldn't even fit the nut and washer in the slot, much less the plastic part too.
I wound up redesigning the t-nuts to fit some small-profile 10-32 nuts. Not the best design, but I superglued each one in and they are pretty sturdy.
Edit: Here's the nuts I designed. In case it proves helpful for anyone.
Re: Cherry Pi III Is Available September 19, 2014 01:20AM |
Re: Cherry Pi III Is Available September 19, 2014 02:28AM |
maso
I did find that I had to tighten those carriages down quite a bit. Come to think of it, I had to shave some plastic out of the slot in one of them so that I could get it tight enough.
But it really wasn't too bad. And the printer is working swell now. Maybe one of us should try to make a carriage that has the wheels closer together sometime.
Re: Cherry Pi III Is Available September 19, 2014 07:05PM |
pugzor
Hey maso... Did you also encounter the issue that OpenBuilds V Slot is not compatible with the carriage design? I'm finding that there's a fair bit of a gap between the mini V wheels and the extrusion. Along the lines of 3-4mm total (probably about 2mm each side?). Obviously this means there's a lot of play.
Re: Cherry Pi III Is Available September 20, 2014 04:45AM |
Re: Cherry Pi III Is Available September 20, 2014 09:06AM |
Re: Cherry Pi III Is Available September 20, 2014 11:44AM |
Re: Cherry Pi III Is Available September 20, 2014 06:00PM |
pugzor
Wow, thanks Andy! Without looking at the STLs, what was the modification? How much closer to each other did the wheels move? My guess would have been 3-4mm...
Re: Cherry Pi III Is Available September 20, 2014 07:57PM |
Re: Cherry Pi III Is Available September 21, 2014 05:24AM |
Re: Cherry Pi III Is Available September 21, 2014 09:43PM |
Re: Cherry Pi III Is Available September 22, 2014 02:52AM |
Re: Cherry Pi III Is Available September 22, 2014 05:40PM |
Re: Cherry Pi III Is Available September 22, 2014 08:34PM |
Re: Cherry Pi III Is Available September 22, 2014 08:37PM |
Re: Cherry Pi III Is Available September 25, 2014 12:02AM |
Re: Cherry Pi III Is Available September 25, 2014 12:08AM |
Re: Cherry Pi III Is Available September 25, 2014 02:41AM |
Re: Cherry Pi III Is Available September 29, 2014 06:34PM |
Re: Cherry Pi III Is Available October 03, 2014 01:35AM |
Re: Cherry Pi III Is Available October 03, 2014 08:57AM |
Re: Cherry Pi III Is Available October 03, 2014 06:54PM |
