Re: Cherry Pi III Is Available February 27, 2015 02:12PM |
Re: Cherry Pi III Is Available February 27, 2015 02:44PM |
Re: Cherry Pi III Is Available March 01, 2015 08:17PM |
Re: Cherry Pi III Is Available March 01, 2015 08:27PM |
Re: Cherry Pi III Is Available March 02, 2015 02:29AM |
Re: Cherry Pi III Is Available March 02, 2015 10:12AM |
Re: Cherry Pi III Is Available March 02, 2015 02:45PM |
Re: Cherry Pi III Is Available March 02, 2015 05:50PM |
r1zlah
HELP !!!
I bought a Cherry Pi III off Andy about 10 days ago. Been having great success with it, printing out parts i am very happy with. Until today that is !
Earlier today i started the next part of the tricopter i am printing - all went well, printed fine. I then swapped out the filament to a different color and stared the next print, a few brief seconds after it had warmed up i hear this god awfull scratching noise as the extruder head is scrapping along the print bed. I stopped the print, checked all my settings (everything looked fine) and tried printing something else that has been succesfull in the past. Exactly the sam thing happened, scratching the bed further.
As far as i can tell i have changed nothing,all i did was to change the filament to another color. Settings all look fine.
Help ! I am now paranoid to try printing anything in fear of breaking something permanantly. Any ideas as what may have happend ?
Thanks in Advance.
Re: Cherry Pi III Is Available March 02, 2015 05:55PM |
Re: Cherry Pi III Is Available March 02, 2015 06:14PM |
All good man.Quote
AndyCart
Hi Guys
I still can't get the file to fail on my setup??? Give the alternative file on my Thingiverse Cherry Pi IIIS 'thing' a go.
[www.thingiverse.com]
EDIT: I've now found the problem file and uploaded a new, fixed version. Sorry. I don't know how that slipped through.
Andy
The work you've done with the Cherry Pi is amazing and I'm sure you've had a million different versions of some parts. We all appreciate what you've done.
Re: Cherry Pi III Is Available March 02, 2015 06:20PM |
gowen
[attachment 50289 IMG_20150302_140231.jpg]
Re: Cherry Pi III Is Available March 03, 2015 08:43AM |
Re: Cherry Pi III Is Available March 03, 2015 09:17AM |
Re: Cherry Pi III Is Available March 03, 2015 11:30AM |
Re: Cherry Pi III Is Available March 03, 2015 12:29PM |
AndyCart
Not sure why you are short of screws? I counted them out twice before I shipped them to you.
Re: Cherry Pi III Is Available March 03, 2015 06:12PM |
Re: Cherry Pi III Is Available March 04, 2015 01:29AM |
mrorange26
Why does my cherry pi keep skipping like this in prints.
Re: Cherry Pi III Is Available March 04, 2015 02:50AM |
Re: Cherry Pi III Is Available March 04, 2015 02:51AM |
Re: Cherry Pi III Is Available March 04, 2015 03:08AM |
AndyCart
mrorange26
What are your slicing settings? Speed, flow, infill, retraction, temps, etc
This is normally caused by the head either moving too fast or the nozzle hitting artefacts from the last layer
Increasing motor current (gradually) sometimes helps. Also check your drive belts are not too slack.
Re: Cherry Pi III Is Available March 04, 2015 03:49AM |
Re: Cherry Pi III Is Available March 04, 2015 04:03AM |
mrorange26
0.2 height,print speed 50,flow 95%,temp 200c,infill 70%,retraction 40mms 4.5mm,travel speed 80,bottom layer 20,infill speed 40,top/bottom speed 40,outershell 40,innershell 40
Im using cura 15.02.1
Re: Cherry Pi III Is Available March 04, 2015 07:15AM |
Re: Cherry Pi III Is Available March 04, 2015 09:28AM |
Re: Cherry Pi III Is Available March 04, 2015 09:45AM |
gowen
Day 8
Today, I soldered up the micro switches. Due to the company clean desk policy, by the time I had got my soldering station out and then put it away again, there wasn't time for much else.
[attachment 50429 IMG_20150304_134639.jpg]
I've soldered the switches as normally open, push to close. I hope this is correct.
After reading vreihen's comment in the previous post I did check my stepper motors as I couldn't remember seeing a flat spot on the shafts, which turned out to be the case. Do I need to grind a small flat or is there enough grip from the grub screws?
Once final question. What would people recommend as good filament to get started with? Something that extrudes well, without breaking the bank, as I imagine a lot of my early attempts may end in failure.
Re: Cherry Pi III Is Available March 04, 2015 09:58AM |
dougal1957
No you really should have them as NC that way they will always Fail ( god forbid) in a safe way if wired as NO as you have and a wire breaks then the carriages won't know when they hit the endstop and will try and keep going.
Doug
Re: Cherry Pi III Is Available March 04, 2015 10:07AM |
gowen
dougal1957
Doug
Bugger! I'll take them home and re-solder them this evening. Shouldn't take long.
Thanks for the correction.
Re: Cherry Pi III Is Available March 04, 2015 12:35PM |
Re: Cherry Pi III Is Available March 04, 2015 12:40PM |
Re: Cherry Pi III Is Available March 04, 2015 05:12PM |
