Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 02:54AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 02:55AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 06:14AM |
Mylation
Well it's been two days since I got my kit. All the hardware is screwed together and I didn't blow it up when I adjusted the drivers. I am concerned still about adjusting the height because I put it at the maximum possible not knowing the precise place to put the rails with 250mm rods. I ended up having EXACTLY the number of T nuts that I needed which was disappointing because I was hoping to have at least 2 extra for mounting my screen - I guess I'll have to PRINT something!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 06:30AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 09:01AM |
hedgehogsmoker
Can anyone tell me how I find the radius?
Sorry I'm very new to this.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 09:06AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 09:18AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 01:06PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 01:14PM |
Koenig
thevisad
They are a direct replacement for the a4988 drivers; however, your 16 step will be 32 step with the jumpers in the current place.
Are you really sure?
looking at this: [www.geeetech.com]
I get the sense A and B corresponds to the two phases of the motor, and thus switching 1B and 2A will make the motor not do what it is supposed to...?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 02:26PM |
thevisad
Koenig
thevisad
BTW, I received my DRV8825 from geetech in the mail yesterday. I was really tired and didn't even think about it, popped out the a4988 drivers and in went the 8825, backwards. Make sure you pay attention, the POT goes on the OPPOSITE side of the RAMPS board, not in the same direction as the 4988. The 8825 handled the reversal without issue and once placed in the right direction and dialed in everything started working fine. You will need to adjust your MM per step as it will now take twice as many to move the same distance.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:22PM |
Koenig
thevisad
Koenig
thevisad
What Vref did you set?
Are the motors more quiet now? (I heard somewhere that this driver makes the motors run more quiet)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:26PM |
Deguello
The rails are swimming in gun oil, so I'll check the voltages after this print.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:29PM |
Flish
Deguello
What causes my taller prints to start "stepping" away from the Z tower like this?
Could be a loose set screw on one of your pulleys - there should be 2 screws per pulley.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:35PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:48PM |
Deguello
You're probably right. I was just thinking about adding fans underneath and maybe heatsink fins on the motors.Quote
thevisad
...motors are probably smoking hot...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 05:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 06:27PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 07:01PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 08:31PM |
Wittmason
When I've had this happen on my last 3d printer it was because the nozzle drug through the parts and the steps got offset when the belt slipped. If you set the z lift on layer change to something like 4-6 mm that should help.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 09:05PM |
Flish
I said a loose set screw because I had about the same problem... One screw was not tightened and slipped a couple times then 'reseated' itself. It wasnt continually loose. Had the same staggered layers result.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 09:23PM |
mmcginnis9272
Wittmason
Did you mean .4 to .6 mm? 4-6 is a huge raise for z change. I use .4 with good results.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 07, 2015 12:04AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 07, 2015 02:40AM |
thevisad
Something weird I just noticed and probably would not have until I started investigating why my printer is not exactly precise. All of my prints have been off by a minute amount and when I was tweaking the firmware for the drv8825 I found this line below. When you do the math, 189/2.25 = 84, not 80 which it should be for 1/16 on a 20 tooth pulley gt2 belt or 160 for 1/32. When I corrected this, I found that my build area increased beyond the 253.9 to 254.6, when it was configured in the firmware for 242.4. This is a massive difference and would account for the 1.4+ mm increase on the 15 cm ruler I printed.
At .4 I had issues with the motors jumping, I dialed them up to .5 and they don't jump as much. I have not been able to find the specs on the motors but I assume they are 1.5a so should be safe at .5 They are definitely smoother then they were before and way less of the musical notes while printing. I can actually hear the crunching in the bearings now, I wasn't sure of it before.
Incorrect!?!? Everything I see states 80, not 84 for 20 tooth.
#define DEFAULT_AXIS_STEPS_PER_UNIT {189/2.25, 189/2.25, 189/2.25, 100}
Correct
#define DEFAULT_AXIS_STEPS_PER_UNIT {160, 160, 160, 100}
I am currently streaming it on twitch with all of these updates/changes and I will link the video when I archive it. http://www.twitch.tv/thevisad/b/656835814
Update: Fail... had an issue with the hot end and it refused to feed and jammed up. After running them for a bit at .5 the motors seem to run about 40 c with the fans on (just barely pass the 3 second touch test). Skip to the 20 minute mark to bypass a lot of the screen shuffle and see it printing right at 20:38 or so it makes some weird noise, it sounded like it skipped, but it seemed ok. Shortly after that the hot end jams and I try to get it running again for the rest of the video with no luck. It seems... twitchy tbh, not sure I like it. The noise you hear is the bearings grinding, love me some chinese metal
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 07, 2015 09:33AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 07, 2015 10:11AM |
jculver09
I just checked out your video, loving the beard.
I may do the upgrade to the drv8825 soon, but until then I am wondering what the reasoning is behind using "189/2.25" instead of "84"? Since I have not upgraded and have noticed a similar amount of error no matter how well I calibrate or adjust, so it sounds like changing my steps per unit to 80 would help (yours is set to 160 to utilize the 1/32 stepping correct?).
Also, in your pic further up the page, you show only 2 drv8825 in your axis drives, this would make sense to me in a cartesian system but in a delta wouldn't it be better to swap all 3, since they all play an equal role in the print?
