Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 04, 2015 05:24PM |
fattmann
davidf01
cman8
Seems like theres something wrong there. The belts shouldnt touch the corner brackets
Thats what I thought. I checked the instructions and it all seems correct. I'm wondering if there is something I don't know about. It seems like the pulley in the upper frame is to far towards the outside
or the slider is not thick enough. Not sure what the issue is.
Might just be low quality of the slider. I have almost the opposite problem- my belt floats nearly 1/8" outside the carriage. It looks like it might just fall off at any time.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 04, 2015 06:03PM |
fattmann
davidf01
cman8
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 03:26AM |
davidf01
cman8
I think my sliders are not thick enough. Could the printed sliders be the wrongs size? This picture is the bottom pulley all the way out to try and line up with the top pulley.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 07:48AM |
SlowFoot
davidf01
cman8
I would guess that the slider is designed for other, wider, rolls (twin bearings). A washer or two between the roller and the slider should help.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 10:01AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 10:55AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 11:48AM |
cman8
Anyone here upgrade to a smoothie board? is it worth the expense? Advantages? Disadvantages?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 12:06PM |
dc42
cman8
You might also want to consider upgrading to a Duet. It is also a 32-bit board and has probably the best delta firmware of any printer electronics, e.g. it supports segmentation-free delta movement, least-squares fast delta auto calibration, and an Ethernet port with a good web interface and fast upload to the SD card.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 12:31PM |
wrangellboy
dc42
cman8
If the duet gets a US distributor I'll buy one right away. I'm a bit nervous about the qc from the knockoff and the exchange rate makes it more expensive than a smoothie x5 for me in the states...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 12:46PM |
Koenig
wrangellboy
dc42
cman8
The only one I've seen that has had a problem with the board from replikeo is thevisad, on the other hand he has had no problem with getting support/replacement.
I have a board from them and it worked out of the box, however only 3 of the four USB-lugs were soldered, which is enough, and the connector for the external 5V reg was soldered a bit low so the boards wouldn't line up properly, but that's something you're probably not going to use anyway.
$50 is a really good prize for it!
That even includes the external 5V reg you're not going to use as well.
I'd buy from them again, or I should say am going to, for my larger kossel project.
wrangellboy
... and the exchange rate makes it more expensive than a smoothie x5 for me in the states...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:08PM |
Koenig
wrangellboy
dc42
cman8
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:14PM |
wrangellboy
I forgot to mention the other holdback for me. I'd like to move to dual extruders eventually and the newer board supports that out of the box. I think with the .6 board you need the expansion module right? Mostly I think I'm just making excuses to protect my wallet
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:22PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:26PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:35PM |
The boards have an LED that is populated in this area (green circle) that lights up when you power on the nit. There is also another LED for the bed powering at the red circle. The blue circle are the fuses for the board and just about the only thing that will prevent the board from powering. There is not much on the RAMPS 1.4 to burn out.Quote
davidf01
Does anyone know how I can test my RAMPS board? I plug in the power and the light comes on the power supply but I'm not getting any indication that the RAMPS board is getting power?
I can't seem to get any reading from the stepper drivers. Is there a way to check if the RAMPS board is shot?
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:40PM |
dc42
thevisad, it sounds like you've had a bad experience with 3 boards from Replikeo, as well as being unfortunate enough to short out the fourth one. It does sound as though they are skimping on testing. Did the boards you receive have the JTAG connector populated? The boards from ReprapPro and T3P3 don't normally.
Duet 0.6 boards bought from RepRapPro come with Molex connectors, not screw terminals. I don't think the T3P3 0.8.5 Duet comes with screw terminals either, unless you want it that way. I got to specify what connectors I wanted, although I might have been given special treatment.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:52PM |
thevisad
The reprappro duet would be acceptable as the pin headers can be used with my wiring connectors, they just won't lock in place. I can always remove and replace them with the headers I have I guess.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 01:55PM |
dc42
thevisad
I believe the RepRapPro Duets come with locking Molex KK series connectors these days, same as the Replikeo boards. I think Replikeo copied it from RepRapPro. If Replikeo isn't populating the JTAG header, then I doubt they are programming it via JTAG, although it's not impossible.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 02:00PM |
thevisad
Koenig
wrangellboy
dc42
cman8
I ordered my original board from Replikeo on May 28th, it took about a month to arrive and I had an issue with the USB socket on the board. When I opened the package the socket fell in my lap and I almost lost it. I attempted to solder it back onto the board but the traces were damaged. I attempted to power the board on through the added regulator and it simply refused to work. I contacted them and they sent out a replacement the next day. The replacement worked fine for a couple of weeks and everything was good. Then during the testing phase, I accidentally shorted the replacement out and fried the board. I ordered another replacement on August 10th and paid for the expedited DHL shipping (26.56 3-5 day delivery) so I could have it in a couple of days. It arrived and when I plugged it in the unit refused to power on. I contacted them immediately and went through a couple of days of working with them to test the unit. We attempted everything we could to connect to the board and we were unable to do so. In the end they replaced it and shipped out a replacement, via 10-20 day airmail delivery. The replacement was shipped back to them a week into the shipping process because of packaging issues. They just reshipped the unit and as of yesterday it looks like it cleared customs and is on it's way.
I found out that I had the wrong programmer/debugger for the SAM chips, so I ordered an Atmel-ICE to connect to the JTAG port on the boards. The original board refused responded to JTAG, but would not enter programming mode and I could only sense the voltage. This is usually an indication that the chip is not fully powered on all of the VCC lines (soldering issues). Running the board through a reflow oven had zero effect in reflowing any possible broken solder spots. The shorted replacement refused to communicate at all, indicating the chip was fried. The most recent DOA responded to the system via JTAG properly, I was able to detect the chip without issue. I was even able to program the chip and verify that the chip responded. However, the board never worked. it would not default to the firmware ip and appeared that it would not read the SD card. I verified that the board had the proper voltages all along the traces and the endstops worked properly. I can only assume that the traces are broken/ not soldered properly.
I went through a significant cost to buy wiring connectors and build all of the wires in my printer to match up with the board from Replikeo. I picked up a screen and the PanelDue from DC42 as well. So the rough cost is about 170$ right now, if I take into account the fried board, that is 250. The other boards cost more and have screw terminals which are less desirable, which is why I went with Replikeo's version. I can only assume that the PCB supplier that they are using has mediocre testing and that Replikeo is using JTAG to program these boards. That 2 of the boards had unusable USB ports indicates that they are not using this method to test/communicate with the boards. Maybe I am just unlucky and got a couple of bad boards, it happens. I have had multiple computer motherboards bad out of the box in the past. The main thing is that Replikeo has been there the entire way and supported me. They have replaced the boards and have responded without fail. Customer server from them is not an issue at all.
The smoothieboard has all of the features that Duet does and provides the same functionality with the wiring connectors I have selected to work with. While a bit more expensive it has a proven track record and it's located in the US.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 02:02PM |
thevisad
davidf01
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 02:05PM |
davidf01
Thanks thevisad, I get no LED light and the fuses seem just fine no indications that they are blown. I have no LED light and can't get a reading from the stepper drivers. Im at a loss here. Not sure what to do.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 02:15PM |
thevisad
... The smoothieboard has all of the features that Duet does and provides the same functionality...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 03:13PM |
thevisad
davidf01
You should get the LED to blink just off of the RAMPS USB connection (power) but you won't get any of the others unless you plug it into 12 v via the polarized green block. If you have a multimeter you can test for your power at the green block, make sure to connect the power properly at the block in a +-+- pattern.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 03:21PM |
wrangellboy
Koenig
wrangellboy
dc42
cman8
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 03:42PM |
dc42
thevisad
Except for the good web interface, fast file upload to SD card via Ethernet, segmentation-free delta movement, and fast least-squares auto delta calibration.
In fairness, the Smoothieboard may have features that the Duet/RepRapFirmware lacks too, although in the context of delta printers I don't know what they might be.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 03:44PM |
Koenig
wrangellboy
From what I understand it should be fairly simple to use a RAMPS-board for expansion, they are only about $5 + drivers of your choosing.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 03:47PM |
You are required to have the proper 12v rail feeding the steppers in order to get the vref right. You can connect prornterface to it and power the hotbed/end and you should see the other power lights become active.Quote
davidf01
thevisad
davidf01
Ok I get the light when I plug it into the USB but I get nothing when I plug in the power cord. In this picture you can see the light when it is plugged in to the USB but nothing when it is running on the power cord. Will I get the correct v-ref numbers if i
try to set the stepper v-ref using the USB plug instead of the power cord?
I put my multi meter on the green block and it does show 12v there.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 03:49PM |
thevisad
It has it's own web interface but it seems minimal, I really liked the latest build of the web interface for the duet. However, I am sure not much effort would be taken in migrating the web page over to the Smoothie. I might buy one just to tinker with.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level September 05, 2015 08:17PM |
