Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 12, 2015 06:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 12, 2015 07:36PM |
paul_delta
jroever
Finally came across somebody with a Rostock Max mentioning something similar - linked to #define AXIS_RELATIVE_MODES {false, false, false, false} in Configuration_adv.h
Experimentally changed mine to #define AXIS_RELATIVE_MODES {false, false, false, true} and oh what a difference! While my prints were very precise I apparently did not get consistent feed rates which was definitely noticeable
on my translucent PLA prints. My red translucent prints now look like top grade ahi sashimi, while before they looked like, well, cheap plastic
Sounds interesting. Can you please compare the quality with retracts on/off?
Here is the Repetier author point of view:
Repetier
The default in Sprinter, Marlin and Repetier-Firmware is absolute for a simple fact - precision with small moves. Even if you output 6 digits for relative moves it doesn not really matter if the number becomes less the one step. With 400 Steps per mm the smallest relative E-distance is 0.0025 so with relative mode you can add smaller errors. Nothing spectacular if your moves are a mm or more. That only to understand why absolute is better.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 12, 2015 08:02PM |
jroever
paul_delta
jroever
Repetier
As long as rounding errors are accumulated on the slicer side there should be no difference. On the contrary - if the absolute extruder position would not be reset to zero periodically the absolute method would run out of floating point precision really soon!
I checked g codes from Slic3r with rel and abs mode and it seems abs mode re-bases zero every time a retract happens (in the sample I used about every 8-14mm).
Slic3r did insert the correct M82 or M83 codes to enable absolute or relative modes - so the question is what difference the setting in configuration_adv.h makes!?!
Right now my printer is in service mode ... might take me a while before getting to the base of this - but I will and will also provide some close up shots of the results.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 12, 2015 08:06PM |
jroever
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 12:27AM |
paul_delta
jroever
I guess it's just default mode, when M82/M83 is not provided. I saw on the forum that some slicers don't insert M82/M83. I think configuration_adv.h setting doesn't matter if slicer/firmware work with these codes correctly.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 12:27PM |
Captain_Tim
SlowFoot
I made mine 250 mm total length but my build is not finished yet.Quote
Captain_Tim
Anyone who cut their diagonal rods to be around 250mm, what was your build size? I'm almost at the part where I need to cut them, and I'm deciding if I should go with the recommended 230mm or go for a 250mm
My goal is to get a higher lowest angel on the arms to reduce the impact of build errors and also a bit larger build area. 50/50 between the two is the plan at the moment. I got a rev A kit so I will not lose much in build hight but, if I get it right, I will lose resolution when the effector is moving towards a tower.
What is your planned build area? I'd like a 210mm diameter from mine. I'm willing to sacrifice some height for that
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 12:39PM |
Koenig
SlowFoot
Captain_Tim
I'm not big on the particular math here but isn't it the other way around, you always have the worst resolution in the center of the build-plate?
My train of thought: Closer to the center small movements of the carriages (fewer steps) yields larger movements in the XY-plane than at the towers where the carriages have to move much more to move the effector same lenght as in the middle, except the carriage at the tower you are close to, but the closer you get the less that carriage affects the movement in the XY-plane (only acts as a Z-axis when the rods are perpendicular to the bed)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 12:41PM |
SlowFoot
It will depend on how good the frame come out. 210 is about max with 250 mm arms.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 09:13PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 09:22PM |
fattmann
Anyone have a write up on most efficient way of leveling the printbed with springs?
I through in springs under the three mounting points cause I was having some leveling issues. But now that I have three degrees of adjustment it's kind of daunting. I spent a good 30min going back and forth- getting one axis good, which would trash the other. I'm also wondering if people usually go with three or four spring mounting points. I feel like four would be easier as you can level it corner to corner.
So yeah, just looking for pointers I guess. Thanks again.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 09:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 10:00PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 13, 2015 10:11PM |
fattmann
Question on odd movement.
If I drop down to a Z height of 2mm, then move all the way to the screw that is directly in front of Y+, then manually drop the Z down with two clicks of the Z-1 button, there is still way more than a paper gap.
If I drop to a Z height of 0mm, which passes the paper test in the center, then manually move to the Y+ position- it scars the printbed the whole way burying thoroughly in the print bed.
Shouldn't it get to the same place regardless of method?
I think this is a fundamental problem I'm having. I will have it passing the paper test over most of the center of the bed, but will then bury depending on what I try to print.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 12:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 09:28AM |
fattmann
That works beautifully to level the bed, thanks! I ended up using a 2.5mm allen key, as I didn't have any metric drill bits, but the principle is what I needed.
As luck would have it now I'm having issues with the damn Smooth Rod Offset deal. I'll level the bed using your method, but the ends will be lower than the center. So I adjust Smooth Rod, then Z home to compensate. I assume it's just a reiterative process to get it dialed in then. But when I adjust the Smooth Rod Offset, the end points by the screws aren't even close to being equal, I'm assuming cause maths.
Will continue toying w it. I have a feeling most people don't have as many issues as I have been having... lol.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 09:40PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 09:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 09:49PM |
fattmann
Not sure on your first issue as I do not run Repetier, but the Marlin FW won't let you run the extruder motor until the hotend is up to temp to prevent binding. If it's not seeing the correct temp (cause the thermistor isn't hooked up, or the hotend isn't heating) then it won't allow the extruder to spin.
I would assume that's the same for most FW.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 09:52PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 09:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 10:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 14, 2015 11:41PM |
paul_delta
... make sure that your endstops are connected. Check their status with M119 manually switching endstops.
paul_delta
PS: Actually, you MUST calibrate vRef for drivers before switching 12v on.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 12:05AM |
Captain_Tim
Also, looking at the console on connection with the printer, it has the following two line;
Error: Format error
Resend: 13
Captain_Tim
paul_delta
Could you explain that sentence more? I am unsure of what you mean.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 12:08AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 10:40AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 10:56AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 01:11PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 01:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 01:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 02:11PM |
paul_delta
Make sure that you have all 3 jumpers installed under your driver modules on RAMPS.
