Re: Ebay SINTRON Kossel Mini full kit September 03, 2015 04:17PM |
Re: Ebay SINTRON Kossel Mini full kit September 03, 2015 06:50PM |
Re: Ebay SINTRON Kossel Mini full kit September 03, 2015 09:32PM |
Miamicraft
1. Did you use the Sintron Marlin firmeware? [www.dropbox.com]
2. Did you do the G28 (home) followed by a G29 (auto level) before printing? Sintron's software seems to be set up to handle it.
Re: Ebay SINTRON Kossel Mini full kit September 04, 2015 12:57AM |
Re: Ebay SINTRON Kossel Mini full kit September 04, 2015 02:47AM |
Re: Ebay SINTRON Kossel Mini full kit September 04, 2015 04:35AM |
Re: Ebay SINTRON Kossel Mini full kit September 04, 2015 04:57AM |
Re: Ebay SINTRON Kossel Mini full kit September 04, 2015 10:47AM |
Re: Ebay SINTRON Kossel Mini full kit September 04, 2015 11:11AM |
Re: Ebay SINTRON Kossel Mini full kit September 04, 2015 11:30AM |
o_lampe
Today I started calibrating my delta with marlin. ( not sintron, but same design )
I found all the variables are spot on, when you figure out, what they are actually asking you.
1st. the delta_smooth_rod_offset is hard to find. How do I know, where the center of the printer is? I don´t even have a smooth rod. (They are talking about the center of the v-slot rollers in modern world )
2nd. delta_effector_offset. I was ~10mm wrong at first, because I took the distance from center to one of the ball joints. WRONG, it is the distance from center to the virtual middle of two ball joints (a pair off balljoints which go to one of the carriers )
The picture I attached might be helpful, although the effector offset can still be misread.
-Olaf
Re: Ebay SINTRON Kossel Mini full kit September 05, 2015 03:22AM |
Re: Ebay SINTRON Kossel Mini full kit September 05, 2015 05:45PM |
Did that. Just got a reply that they will ship my kit with traxxas ends.Quote
nebbian
I would ask them if they can substitute the traxxas ends for the metal ball joints before buying, as the metal joints are totally unsuitable.
Re: Ebay SINTRON Kossel Mini full kit September 06, 2015 03:44AM |
Re: Ebay SINTRON Kossel Mini full kit September 06, 2015 05:05AM |
Re: Ebay SINTRON Kossel Mini full kit September 06, 2015 02:08PM |
Re: Ebay SINTRON Kossel Mini full kit September 06, 2015 09:00PM |
Re: Ebay SINTRON Kossel Mini full kit September 07, 2015 02:34AM |
Re: Ebay SINTRON Kossel Mini full kit September 07, 2015 11:11AM |
o_lampe
Can you tell us the height of your endstops? Otherwise the blind use of the file could end in a headcrash.
-Olaf
Re: Ebay SINTRON Kossel Mini full kit September 07, 2015 11:58AM |
nebbian
I'm glad they give you 5 stepper drivers in the kit, as I broke one today. The little plus-shaped piece of metal that lives on the top of the pot just flipped off, and shorted out some other components on the board. This killed the stepper driver, and seriously hurt the 5V regulator. I replaced the stepper driver with the spare in the kit, and replaced the 5V regulator on the arduino board with a spare 7805. Now we're back in business!
I'm not convinced that this system can handle the load of a heated bed. Whenever I try to heat it up the board goes a bit spastic after a while. The motors start making weird noises and stop moving, and won't respond to pronterface. The orange polyfuses, and the heating FETs get quite hot as well. I thought that this was due to the board heating up underneath the heatbed but now I'm not sure, as it showed the same problem with the board mounted outside the base. (well, mounted is being generous, it's sitting on the desk in a rats nest of wires). The bed might be over rated for the FETs. I might try rewiring it to not use so much current (or lower the duty cycle or something).
Also quite annoying is the way that you have to have pronterface in the foreground when printing. Otherwise the printer will pause after 30 seconds or so of doing something else (like typing this message).
Re: Ebay SINTRON Kossel Mini full kit September 07, 2015 02:11PM |
Re: Ebay SINTRON Kossel Mini full kit September 07, 2015 04:53PM |
Re: Ebay SINTRON Kossel Mini full kit September 07, 2015 05:00PM |
Re: Ebay SINTRON Kossel Mini full kit September 08, 2015 12:35AM |
Tha_Reaper
I still asked for the traxxas ends. Mostly because they are a lot lighter than the stock ends. As I understood from earlier conversations that reduced weight will have a positive effect on speed and quality... right?
I'm really looking forward to start tinkering... my old printer is making new horrible sounds every day. I don't know how much longer until something breaks again.
Re: Ebay SINTRON Kossel Mini full kit September 08, 2015 03:32AM |
nebbian
Re: Ebay SINTRON Kossel Mini full kit September 08, 2015 03:38AM |
o_lampe
@The_Reaper
If you want to save more weight, use carbon rods instead of the steel ones.
Sintron seems to be a bunch of morons, but at least their customer service seems better than average.
Although they use customers as guinea pigs, they improve their kits later.
-Olaf
Re: Ebay SINTRON Kossel Mini full kit September 08, 2015 04:20AM |
Tha_Reaper
o_lampe
@The_Reaper
-Olaf
In the end they refunded me 14 bucks to buy myself some traxxas ends. I guess the person that promised me that they would ship it with traxxas ends didnt realise they didnt have those or something. I'll Use those 14 bucks (as a start) to buy myself a traxxas ends+carbon rods kit from ebay.
Is there a specific length rods that i should go for?
EDIT: and not knowing the difference: are traxxas parts 5347 or 5525 the ones i should go for?
Re: Ebay SINTRON Kossel Mini full kit September 08, 2015 07:13AM |
Re: Ebay SINTRON Kossel Mini full kit September 08, 2015 10:07AM |
dc42
Sadly, most kits (including yours) use cheap Arduino/RAMPS electronics. Blown drivers, blown 5V regulators and overheating mosfets are common on that electronics. You can replace the mosfets with better ones. However, the problems you get when the heated bed has been on for a while might be due to the 12V power supply not handling the load, or a poor connection between the power supply and the RAMPS. I suggest you monitor the voltage on the 12V input terminals of the RAMPS when the bed is operating.
#define MAX_BED_POWER 128 // limits duty cycle to bed; 255=full current
Re: Ebay SINTRON Kossel Mini full kit September 08, 2015 10:17AM |
nebbian
It turns out that the heated bed draws more current than the polyfuse can handle. There is an easy fix, just reduce the duty cycle of the bed in the software:
Setting it to half power seems to work just fine, and it easily got to 60 degrees which is perfect for PLA. I'm now printing a part with no lifted corners, whereas the same model yesterday had badly lifted corners with no bed heating.
I'm happy with this solution. Much better than an underpowered bed
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 02:56AM |
