Re: Ebay SINTRON Kossel Mini full kit September 17, 2015 01:04PM |
Thanks. I guess i overlooked those.Quote
squall
Miamicraft posted the links on page 2 of this thread.
Here's the PDF:
https://www.dropbox.com/s/2w56ruepec5hgxo/Kossel mini instrution by sintron technology_v2.pdf
password : Sintron_Technology
I had to buy a dremel and dremel some of the parts myself as well to get them to fit nicely.
Re: Ebay SINTRON Kossel Mini full kit September 18, 2015 03:24AM |
Re: Ebay SINTRON Kossel Mini full kit September 18, 2015 05:27PM |
No problem as I have spares. |
Re: Ebay SINTRON Kossel Mini full kit September 20, 2015 06:54AM |
o_lampe
You could replace the heatbarrier with one that has a PTFE inliner.
Re: Ebay SINTRON Kossel Mini full kit September 21, 2015 05:02AM |
Re: Ebay SINTRON Kossel Mini full kit September 21, 2015 10:59AM |
In my case PTFE tube goes through heatsink down to contact heat barrier by design, even if heat barrier is not screwed enough.Quote
o_lampe
So I drilled the heatsink and pushfit connector open to 4.2mm and pushed the Bowden PTFE tube right down to the throat of the heat barrier.
Re: Ebay SINTRON Kossel Mini full kit September 22, 2015 11:28AM |
Re: Ebay SINTRON Kossel Mini full kit September 23, 2015 09:24PM |
Re: Ebay SINTRON Kossel Mini full kit September 24, 2015 04:53AM |
Re: Ebay SINTRON Kossel Mini full kit September 24, 2015 06:26PM |
Re: Ebay SINTRON Kossel Mini full kit September 25, 2015 06:50AM |
Re: Ebay SINTRON Kossel Mini full kit September 25, 2015 07:42AM |
Re: Ebay SINTRON Kossel Mini full kit September 25, 2015 11:42AM |
nebbian
I'm considering getting a different hobbed gear for my extruder, mine seems to slip a bit when printing fast.
Re: Ebay SINTRON Kossel Mini full kit September 26, 2015 10:38AM |
Re: Ebay SINTRON Kossel Mini full kit September 26, 2015 10:52AM |
Re: Ebay SINTRON Kossel Mini full kit September 27, 2015 03:32AM |
Re: Ebay SINTRON Kossel Mini full kit September 27, 2015 06:07AM |
Re: Ebay SINTRON Kossel Mini full kit September 28, 2015 02:44PM |
Re: Ebay SINTRON Kossel Mini full kit September 28, 2015 04:37PM |
Re: Ebay SINTRON Kossel Mini full kit September 28, 2015 05:27PM |
Re: Ebay SINTRON Kossel Mini full kit September 28, 2015 05:37PM |
GrAndAG
I can't understand what is correct connection of stop-ends? Is it wired properly on the picture below? Or yellow and red wires must be swapped (on RAMPS)?
[attachment 63109 stop-ends_wiring.jpg]
Re: Ebay SINTRON Kossel Mini full kit September 28, 2015 06:25PM |
Re: Ebay SINTRON Kossel Mini full kit September 28, 2015 06:46PM |
nebbian
Welcome aboard Hacker :-)
Re: Ebay SINTRON Kossel Mini full kit September 28, 2015 09:31PM |
hacker
Actually, now that I think of it I have only one question — after connecting motors according to instructions (blue-red-green-black IIRC) I had to invert steppers direction in the firmware. Is that me or is it what you also experienced?
Re: Ebay SINTRON Kossel Mini full kit September 29, 2015 12:47AM |
Re: Ebay SINTRON Kossel Mini full kit September 29, 2015 12:53AM |
Re: Ebay SINTRON Kossel Mini full kit September 29, 2015 04:24AM |
DrTak
At the final pages of the sintron pdf. Load file into pronterface. So I Put in the 10mm calibration cube file.
Re: Ebay SINTRON Kossel Mini full kit September 29, 2015 05:53AM |
nebbian
hacker
Yep. I couldn't spin my connectors around as they would only fit one way on one of the outputs (Z maybe?) that had two rows of pins. So I did it in the firmware which worked fine.
Thanks for the repetier config, I downloaded it a couple of days ago and will be trying it out soon.
). And yes, it seems to be the way connectors are wired.|
Re: Ebay SINTRON Kossel Mini full kit September 29, 2015 05:57AM |
DRTak
At the final pages of the sintron pdf. Load file into pronterface. So I Put in the 10mm calibration cube file. Heatbed is 95 deg. Extruder is 230 deg. HIT PRINT and the nozzle starts to do G28 but then the tip goes to 0, 0, 0 and shuts off the fans. It shuts it all down. The heatbed goes down in temp. The extruder goes down in temp. BUT the arduino, LCD, and Ramps are still on? I dont know what happened. I asked sintron for help and they want me to video tape what is happening. Email it to them before they respond?
Re: Ebay SINTRON Kossel Mini full kit September 29, 2015 11:43AM |
