Re: Ebay SINTRON Kossel Mini full kit November 15, 2015 07:38AM |
I think this is indeed the problem... i tried trimming the plastic a bit, but now the hotend has a slight play in it. Not good...Quote
dc42
GrAndAG
If the effector moves without any tilt, you should have absolutely no problem even with non-vertical hot-end. Because this defect affects [X:Y] offset only, and it's constant. Which can be adjusted in Slic3r to make [0:0] point of the nozzle perfectly in center of the table if you wish. But it's absolutely not needed.
I'm sorry, I misunderstood. I don't think that tilt matters very much. I think it may be caused by the groove mount plate not being screwed tight up against the effector, so the effector is horizontal but the groove mount plate isn't.. May be there is a stray bit of plastic between them that needs to be trimmed off.
Re: Ebay SINTRON Kossel Mini full kit November 15, 2015 12:00PM |
Tha_Reaper
As an example of what i mean with overhang artefacts i'll show these 2 pictures:
Front of the object:
[www.dropbox.com]
Back of the object:
[www.dropbox.com]
you can see a lot of thick overhang issues on the back, while only a few on the front. My therory is that this is because of the tilted hotend...
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 01:28AM |
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 04:24AM |
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 04:53AM |
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 05:04AM |
MrPCatt
good point actually.... does anybody have a good cooling solution for our kits (and hotends) ? Most solutions I found either are made for different heatsink diameters or are to big overall costing way to much printspace on the edges. Or both
And does it matter having a fan blowing to the noozle? Or do I have to make sure only have the fan hitting the object itself?
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 06:06AM |
MrPCatt
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 12:02PM |
MrPCatt
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 12:18PM |
DRTak
MrPCatt
This is an exact fit for our kit. I downloaded this and use it. It works perfectly.
[www.thingiverse.com]
Remove fan. Place shroud. Put fan on shroud. screw in place. its an exact fit for our kossel.
I was having hot end cooling issues when using ABS. Now no more issues.
Re: Ebay SINTRON Kossel Mini full kit November 16, 2015 07:58PM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 02:32AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:13AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:16AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:18AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:25AM |
MrPCatt
For the object fan we now just need a really space saving solution. Or at least a solution which does not collide with one of the towers.
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:29AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:32AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:41AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:49AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:56AM |
HaGeEm
Okay, I finished calibration and did some test prints using PLA yesterday evening. I used 0.3mm layer height for the first two layers and 0.2mm for the rest. Printing speed was 20mm/s for the external perimeters and 40mm/s for the infill (20%). I set the bed temperature to 60°C and hotend temperature to 195°C for the first layers and 185°C for the rest. First 10mm cube had corners bended upwards. After cooling the PLA on the heatbed using a (handheld) fan the cube dimensions were almost perfect. Both, X and Y exactly 9.98mm. However, Z height was 10.37mm.
Could someone point out what potentially causes this problem? Is it due to overextrusion? What I observed during printing was that the higher layers were more like a smear of PLA. Although I am new to 3D printing I guess this is not intended? I think there is also a post in this thread which states that Slic3er 1.2.9 has a problem with getting the extrusion width right. However, as X and Y width were almost perfect I guess this should not be a problem?
Thanks for your help!
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:57AM |
GrAndAG
I'm printing PLA @ 195C all layers, 0.2 thickness (all layers again). 60mm/s for perimeters (70% for outer), 80-90mm/s - infill, 60mm/s - top/bottom (15-20mm/s very first layer). But I heating up the bed is very bit - to 40C.
GrAndAG
Even on default Slic3r settings (40mm/s, 200C, layer 0.3) I had my very first print (1cm cube) very decent. Could you show us yours?
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 05:59AM |
Sir_Death
Had the same Problem when printing to cold and / or to fast. - Gets even worse, the higher the printed object is ... - up to complete blockage of Hotend.
I'm printing at about 12-15mm/sec at 0,2mm Layer height and 215°C for PLA
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 06:00AM |
Sir_Death
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 06:10AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 06:11AM |
hacker
Sir_Death
Could that be that it's just too slow for your heatsink cooling? The longer filament stays near the heated area the higher the heat creeps, the more likely it is to clog? And of course the higher the object is (the longer you print) the likelier it is to finally block the hotend?
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 06:45AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 06:51AM |
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 08:30AM |
Sir_Death
Correct - printing faster gave holes in the print, and nozzle got jammed after about 3-4cm printing height.
Slowing down to 12-15mm/sec (1,3mm³/sec volumetric speed), and printing is perfect....
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 08:51AM |
hacker
Interesting… admittedly I use different hotend, but I can print PLA at about 100-120mm/s with no underextrusion at 215C…
Does your motor skip when printing faster? Could it be that it's underpowered?
12mm is the speed I use to lay the first layer of PETG…
Re: Ebay SINTRON Kossel Mini full kit November 17, 2015 09:09AM |
Sir_Death
hacker
Vref is set correctly - double-checked (it was even set to 10% more - did not get better - motor just got hotter...)
I have the same Vref on the other three Motors (X/Y/Z) no Problem with skipping there.
Hotend is simply not melting fast enough. Coldend-Fan already has a Screen to not cool the hotend. - Made it much better (was even worse before...)
