Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 04:59PM |
Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 05:39PM |
SJN
you can get the boat here:
[www.thingiverse.com]
All the details are in the instruction text. :-)
But it is 0.3mm layer height, and 0.6mm layer width , and 115% flow.
I use the cheapest hobbyking silver PLA.
Its designed to be printed with "spiral vase", so it is printed in one sigle strand of PLA :-)
Only one wall thick , so it is thin....and light.
Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 06:18PM |
Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 09:23PM |
hacker
SJN
Just test printed the bow for an rc boat..... Only the bottom layer is messed up because my bed is not level..... Easy fix.
Looks disgustingly perfect! What's the layer height? And how long? And what's the filament?
Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 09:32PM |
Re: Ebay SINTRON Kossel Mini full kit December 19, 2016 01:42AM |
SJN
its all in the settings....trial and error.
settings for this print , will not work as well for another object.........tick off te wrong box in the slicer, and that will mess up everything :-)
Its a real learning experiance, athat you can not prepare for realy......
Re: Ebay SINTRON Kossel Mini full kit December 20, 2016 08:07PM |
Re: Ebay SINTRON Kossel Mini full kit December 21, 2016 01:21AM |
Re: Ebay SINTRON Kossel Mini full kit December 21, 2016 02:24AM |
Re: Ebay SINTRON Kossel Mini full kit December 22, 2016 01:11PM |
Re: Ebay SINTRON Kossel Mini full kit December 25, 2016 02:16AM |
Re: Ebay SINTRON Kossel Mini full kit December 25, 2016 06:08AM |
The measurements on the effector are 38.5, 38.6 and 38.2mm
Re: Ebay SINTRON Kossel Mini full kit December 26, 2016 06:38PM |
Re: Ebay SINTRON Kossel Mini full kit December 26, 2016 06:51PM |
Re: Ebay SINTRON Kossel Mini full kit December 27, 2016 05:44AM |
Re: Ebay SINTRON Kossel Mini full kit December 28, 2016 12:44PM |
Re: Ebay SINTRON Kossel Mini full kit December 31, 2016 09:17AM |
Re: Ebay SINTRON Kossel Mini full kit December 31, 2016 10:15AM |
Re: Ebay SINTRON Kossel Mini full kit December 31, 2016 10:20AM |
Re: Ebay SINTRON Kossel Mini full kit December 31, 2016 10:29AM |
Re: Ebay SINTRON Kossel Mini full kit January 01, 2017 06:55PM |
Re: Ebay SINTRON Kossel Mini full kit January 02, 2017 02:21AM |
Sir_Death
GrAndAG
I can suggest buying solid state relay to connect heating bed via it. It will eliminate all problems with mosfet and fuse overheating.
Much cheaper (and easier) way is to just solder a wire to the Gate Signal of the internal MOSFET and place a IRF540Z external - connect Heatbed there....
Wire from RAMPS to GATE of MOSFET
"-" from Powersupply to SOURCE of MOSFET
"+" from Powersupply to Heatbed, other Wire from Heatbed to DRAIN of MOSFET
(Configuration is called "Low Side Switch")
IRF540Z does not need any cooling for up to 10Amps.. - I have no FAN blowing on it, and no Heatsink mounted.
Heatbed gets hot verry fast, IRF540 stays absolute cool, RAMPS stays cool too.
And with this config, you can easily change heatbed to 24V - just make sure "-" from both Powersupplies are connected together, and connect +24V direct to Heatbed like mentioned above...
Re: Ebay SINTRON Kossel Mini full kit January 02, 2017 05:53AM |
Re: Ebay SINTRON Kossel Mini full kit January 02, 2017 01:09PM |
GrAndAG
So, it's worth it? Do they perform well?Quote
OG
someone had vibration dampers installed and I tracked down such things from ebay to my kossel
I ended up with 8 mm silicone leg pads. That's made my printer almost silent, just weak buzzing sound from motors.
Re: Ebay SINTRON Kossel Mini full kit January 02, 2017 04:35PM |
Re: Ebay SINTRON Kossel Mini full kit January 02, 2017 11:41PM |
o_lampe
On my various Delta builds, I've used felt pieces cut in shape to dampen vibrations. Now I'm using printed TPU dampers, with the same result.
But I'm always afraid the steppers could be mounted to loose, giving me bad results on direction changes.
The best noise reduction is a silent stepper driver, like TMC2100 or RAPS128. Noise that isn't made, doesn't need to be dampened
Re: Ebay SINTRON Kossel Mini full kit January 03, 2017 04:45AM |
Re: Ebay SINTRON Kossel Mini full kit January 05, 2017 04:45PM |
Re: Ebay SINTRON Kossel Mini full kit January 09, 2017 12:24PM |
Re: Ebay SINTRON Kossel Mini full kit January 09, 2017 12:44PM |
