Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 03:00AM |
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 03:30AM |
DRTak
Right now I have a a heatsink fan on full. I only heat my hotend to 240 for PETG and it works fine. I have a 2nd thermistor on the heatsink itself and it reads 100deg C. Still hot but not that bad. The heatsink shroud is made of ABS so well below the metling point of ABS.
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 03:32AM |
GrAndAG
Hm... My heatsink is about 45C, I think. Because I can easily touch it by hand and it's definitely colder than heat-bed @ 60C. And I do not have fan shroud (I use stock mount way).Quote
DRTak
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 02:03PM |
hacker
GrAndAG
DRTak
Interesting. Maybe it's cold in your room?
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 04:08PM |
DRTak
hacker
GrAndAG
DRTak
I see all the comments and yes. I think the only reason my heastink E3d combo works is that my room is cold. Its the basement and its around 65 deg.
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 05:06PM |
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 05:33PM |
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 05:38PM |
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 06:03PM |
hacker
DRTak
hacker
GrAndAG
DRTak
But I meant GrAndAG's room. ;-) His heatsink seems to be much colder than yours?
I have tried to measure heatsink temperature by pyrometer, and got values between 27° and 36° C. It's barely noticeable that it's warm when I'm touching it by fingers.|
Re: Ebay SINTRON Kossel Mini full kit February 15, 2016 11:12PM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 02:00AM |
nebbian
Does anyone know which file I should use when printing a replacement effector?
Has anyone printed one that fits the hotend that Sintron provided?
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 02:04AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 04:24AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 07:04AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 07:18AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 07:20AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 07:48AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 08:38AM |
CrisCG
... i should lower the delta radius, but we have it as an equation in the sintron marlin firmware. so i got stuck at that, i don't know what to modify next.
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 08:55AM |
CrisCG
i tried manual calibration, using this method. I adjusted the endstops offset fot near the pillars positions. Those 3 positions where good, then when i checked the center, it was lower than it should. according to the vid, i should lower the delta radius, but we have it as an equation in the sintron marlin firmware. so i got stuck at that, i don't know what to modify next.
Is there a better method for calibration?
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 10:17AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 11:11AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 11:34AM |
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 04:32PM |
After adjusting smooth rod offset you have to re-calibrate end-stop offsets. Because actually the adjustment does not directly lower/upper effector in the center, but more likely uppers/lowers positions near towers.Quote
CrisCG
I played with the smooth rod offset, but i'm not getting it right. i measured 161.5mm. this value doesnt't work. also tried 159 to 175. no good. any suggestions?
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 04:52PM |
GrAndAG
So, actually, the very first calibration process is cyclic: adjusting end-stops - adjusting smooth rod offset - re-adjusting end-stops - re-adjusting smooth rod offset - and so on. Unless you have all 4 offsets (3 towers and center) the same. After that adjust total height to tune 0 height.
If you heed to recalibrate in future (i.e. because of re-leveling of bed), the adjusting of end-stops will be enough.
Re: Ebay SINTRON Kossel Mini full kit February 16, 2016 07:53PM |
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 06:15AM |
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 07:14AM |
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 09:19AM |
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 09:21AM |
CrisCG
Now i'm having some issues printing a first test. The printhead moves, but the PLA comes out too slow, no enough flow for the printing speed.
Also, the fan doesn't spin. Just makes a buzzing sound. Anyone else had problems with the fan?
Re: Ebay SINTRON Kossel Mini full kit February 17, 2016 10:14AM |
