Re: Delta printer ball joints, let's talk! December 25, 2019 04:00AM |
Re: Delta printer ball joints, let's talk! December 25, 2019 06:08AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Delta printer ball joints, let's talk! May 10, 2021 11:48AM |
Re: Delta printer ball joints, let's talk! May 10, 2021 12:25PM |
Re: Delta printer ball joints, let's talk! May 10, 2021 03:47PM |
dc42
.. it's vital that the magnets don't actually touch the ball studs.
Re: Delta printer ball joints, let's talk! May 10, 2021 06:23PM |
Re: Delta printer ball joints, let's talk! May 11, 2021 01:05PM |
jcs
I use "mouse tape" on mine. It's thin adhesive teflon tape and lasts for years.
Re: Delta printer ball joints, let's talk! May 11, 2021 02:15PM |
Re: Delta printer ball joints, let's talk! May 11, 2021 02:49PM |
Re: Delta printer ball joints, let's talk! May 11, 2021 10:14PM |
Gaou
i dont have a cup . I do have some countersink magnets glueed with instant glue on my effector and on top of that there are the the balls....! i have read what you are telling me some minutes ago on the forum . Seems very right . I do not know if that's the case on mine since there is equal force in a certain diameter on the ball. You can see that in the post for the delta i ve made.
I ll look more on that tomorrow to be sure.
Re: Delta printer ball joints, let's talk! May 12, 2021 05:46AM |
Re: Delta printer ball joints, let's talk! May 12, 2021 03:08PM |
Re: Delta printer ball joints, let's talk! May 12, 2021 03:57PM |
jcs
Just for anyone that's interested, I used the same geometry as leadinglights shows except I used spherical magnets as well, instead of steel balls. Along with the aforementioned mouse tape that works fine with no shifting. Of course you have to make sure the magnetic poles are optimally aligned.
Re: Delta printer ball joints, let's talk! May 13, 2021 06:43AM |
rq3
.............................. Also, a disc magnet with a hole in it has a hole (a weak spot) in the center of its field. By placing a solid cylindrical magnet under the disc, of the same diameter and a length equal to the diameter, the hole is filled, and actually concentrates in the center. A magnetic steel ball will then stick ferociously to the countersunk disc, and will preferentially self center..........................
Re: Delta printer ball joints, let's talk! May 13, 2021 05:48PM |
rq3
Magnetically, there two issues with using a steel cup. The side of the cup stuck to the magnet gets the opposite pole induced into it. If the magnet face is, say, north, the sticking face of the steel cup is south. Of course, the other face of the cup is then north, and the ball is trying to stick to a north faced steel cup with a north faced magnet just under it. Not good. Anyone who has tried to statically levitate some magnets has seen this effect.
Re: Delta printer ball joints, let's talk! May 13, 2021 07:21PM |
jcs
rq3
I'm not sure I exactly follow what you're getting at.
The steel cup serves as a pole-piece for the cylindrical magnet due to the steel having a much higher permeability than air. This is a typical arrangement for magnetic devices. (I have some commercial experience in this area) So lets say the cylindrical magnets N pole is touching the pole piece, Then the cup end will also be N. When the S pole of the spherical magnet approaches the cup it will be very strongly attracted. Now, it is a good idea to keep the pole piece as short as possible. I didn't bother to model the magnetic flux when I first designed this and I no longer have access to the software; but I assure you this design works fine. I've been using it with no (magnetic) problems on two deltas for years. I admit when I first built it, I wasn't sure how well it would work as the arm angle increased; but as it developed that wasn't a problem.
The disadvantage of this design is that it is more difficult to make.
Re: Delta printer ball joints, let's talk! May 14, 2021 04:08AM |
Re: Delta printer ball joints, let's talk! May 14, 2021 07:30AM |
Re: Delta printer ball joints, let's talk! May 17, 2021 10:12AM |
Re: Delta printer ball joints, let's talk! May 17, 2021 06:01PM |
Re: Delta printer ball joints, let's talk! May 18, 2021 09:57AM |
