Delta Printer building April 11, 2021 09:23AM |
Re: Delta Printer building April 12, 2021 02:22AM |
Re: Delta Printer building April 12, 2021 04:39AM |
dc42
See [duet3d.dozuki.com] for how to connect a thermocouple to a Duet. However, unless you want to print at very high temperatures, I recommend using a PT100, PT1000 or thermistor instead.
Re: Delta Printer building April 13, 2021 02:24AM |
Re: Delta Printer building April 13, 2021 02:55AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Delta Printer building April 13, 2021 11:39AM |
dc42
See [duet3d.dozuki.com] guys. I ll order a PT1000. Thanks bith if u
Delta Printer
Duet 0.8.5 firmware 1.19
Re: Delta Printer building May 09, 2021 05:09AM |
Re: Delta Printer building May 09, 2021 04:04PM |
Re: Delta Printer building May 11, 2021 03:41PM |
rq3
About twice a year I pop the arms off the balls, clean everything, and fill the countersink in the magnet with Teflon loaded grease.
Re: Delta Printer building May 11, 2021 10:24PM |
Gaou
rq3
so you are saying you are metal on metal, like mine ? you ve done great work with the rods for sure. i dont have the tools or the mechanical knowledge and experience to do what you did.
i got myself a print today and it seems that i have a problem with stepping or the duet calibration as i got the X and Y 35mm (what they should be) but the Z come out 43mm (instead of 35mm..)....
So first things firsts i got to solve this first....
Re: Delta Printer building May 16, 2021 02:49AM |
Re: Delta Printer building May 16, 2021 07:12AM |
Re: Delta Printer building May 16, 2021 02:30PM |
Re: Delta Printer building May 19, 2021 11:43AM |
Re: Delta Printer building May 20, 2021 04:12PM |
Gaou
Guys i need some help. My nozzle is higher on the edges of the bed than it is on the center. Is it an effector thing or is it something else on delta printers that i am not aware of ? is it possible wrong settings on the configuration file causing this ?
i do have an ir differential probe but since the tilt is big i dont know how helpfull would be to install.
Re: Delta Printer building May 22, 2021 07:51AM |
wildone
The problem you describe is relatively easy to fix.....
wildone
I use a 0.2mm first layer.
Re: Delta Printer building May 31, 2021 03:40PM |
Re: Delta Printer building September 12, 2021 06:01AM |
Re: Delta Printer building September 12, 2021 05:07PM |
Re: Delta Printer building September 13, 2021 02:51AM |
Re: Delta Printer building September 14, 2021 04:39AM |
jcs
If you try (for instance): G1 x-50 y0 z20
does it go to your left when facing the printer?
Re: Delta Printer building September 16, 2021 05:25PM |
Re: Delta Printer building September 17, 2021 05:08AM |
Re: Delta Printer building September 20, 2021 03:06AM |
dc42
@Gaou please check that you have set up your delta printer like this:
X tower on the left
Y tower on the right
Z tower at the back
Re: Delta Printer building September 20, 2021 03:15AM |
Re: Delta Printer building September 20, 2021 01:23PM |
Re: Delta Printer building September 22, 2021 02:42AM |
Re: Delta Printer building November 21, 2021 10:39AM |
Re: Delta Printer building November 22, 2021 09:28AM |
Re: Delta Printer building November 22, 2021 01:06PM |
dc42
do they all make the same noise?
