Re: Generation 7 Electronics Development December 04, 2011 03:52AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Finch
Re: Generation 7 Electronics Development December 11, 2011 05:36AM |
Re: Generation 7 Electronics Development December 11, 2011 07:02AM |
Finch
Re: Generation 7 Electronics Development December 11, 2011 01:33PM |
Re: Generation 7 Electronics Development December 12, 2011 04:03AM |
Finch
Re: Generation 7 Electronics Development December 12, 2011 03:36PM |
Re: Generation 7 Electronics Development December 12, 2011 08:59PM |
Finch
Re: Generation 7 Electronics Development December 13, 2011 10:23AM |
Re: Generation 7 Electronics Development December 14, 2011 03:41AM |
Should I connect CTS from USB-TTL connector to pin 2 on gen7 or should I leave it disconected.
Re: Generation 7 Electronics Development December 19, 2011 11:18PM |
Re: Generation 7 Electronics Development December 20, 2011 05:09AM |
1) When using an ATX power supply, it appears to go into a 'low-draw' standby state if a stepper doesn't turn within 3 seconds of power on and won't wake up. (*fixed* this by connecting a 12v fan)
2) Tool temp sensor reads 0 while the PSU is on. If I disconnect the ATX 20-pin and jumper for molex only (forcing the ATX PSU on with a jumper AND still using a fan to prevent sleep state, the tool temp works just fine.
Re: Generation 7 Electronics Development December 20, 2011 05:26AM |
Re: Generation 7 Electronics Development December 22, 2011 01:37PM |
Re: Generation 7 Electronics Development December 22, 2011 07:01PM |
Re: Generation 7 Electronics Development December 22, 2011 07:30PM |
Re: Generation 7 Electronics Development December 26, 2011 11:44AM |
Re: Generation 7 Electronics Development January 03, 2012 03:35AM |
Re: Generation 7 Electronics Development January 03, 2012 03:51PM |
Re: Generation 7 Electronics Development January 04, 2012 04:44AM |
Re: Generation 7 Electronics Development January 04, 2012 04:53AM |
Re: Generation 7 Electronics Development January 04, 2012 06:25AM |
Re: Generation 7 Electronics Development January 04, 2012 01:33PM |
Re: Generation 7 Electronics Development January 05, 2012 04:34PM |
Any plans to merge [Alfons3's enhancements] sometime?
Finally .. I found the problem
Re: Generation 7 Electronics Development January 23, 2012 11:31PM |
Re: Generation 7 Electronics Development January 24, 2012 05:51AM |
Re: Generation 7 Electronics Development January 24, 2012 08:21AM |
Re: Generation 7 Electronics Development January 24, 2012 10:26PM |
Re: Generation 7 Electronics Development January 25, 2012 04:44AM |
Its unclear what machine you ended using to mill your boards. Are you using a WolfStrap or some other machine?
Re: Generation 7 Electronics Development January 29, 2012 07:55PM |
Re: Generation 7 Electronics Development January 29, 2012 08:13PM |
