Re: Aluminum Sheet Between Heater and Glass January 29, 2016 07:09PM |
the_digital_dentist
Places like Speedy Metals and any of a dozen other on-line metals dealers will cut any size you want. My 12.5 x 12 x 1/4" plate ran about $40. Try:
[www.onlinemetals.com]
[alcobrametals.com]
[www.speedymetals.com]
Speedy Metals has a 12" x 18" x 1/4" plate for $57. If you don't want to cut it, they'll cut it to the exact size you need for a few $ more.
Search google for "cast aluminum tooling plate", "cast jig plate", etc.
Alcoa's MIC-6 spec says flatness is within 0.015" on 1/4" plate, but that's over a 36.5" x 96.5" sheet. Smaller pieces are much flatter.
Here are videos that demonstrate the level/flatness of my printer's bed along with sag/misalignment in linear guides and supporting structures, etc.:
unheated flatness test
heated bed flatness test
note: the gauge is reading in 1/100th of a mm (10 um in the rightmost digit). The heated (105C) bed flatness test may be off a bit- the longer the probe stays in contact with the heated bed plate, the more negative the readings become. I don't entirely trust the readings toward the end and think the bed is flatter than it reads. I should rerun the test going in the opposite direction to check it. Regardless of what the gauge reads, the bed is flat enough to print almost edge to edge.
I would love to see similar measurements done on the typical thin aluminum/glass/4 point leveling scheme bed.
Re: Aluminum Sheet Between Heater and Glass January 29, 2016 08:40PM |
Re: Aluminum Sheet Between Heater and Glass February 01, 2016 04:05AM |
dc42
MechaBits
I'm sold on the cast alu plate, but it is tricky here in the UK, ebay are skewing results for sure, maybe they dont want us to have the manufacturing good stuff here in the UK, for fear of what we'll make with it.
See EcoCast here: [www.aluminiumwarehouse.co.uk].
Re: Aluminum Sheet Between Heater and Glass February 01, 2016 04:45AM |
Origamib
dc42
MechaBits
Ahhh great link!! Searched for something like this for ages the other day! I'm now turned to using one of these, seems like a great idea. I was originally going to use a mk2b heater and glass set up, Will this be fine for heating up the alu plate?
also, what thickness will I want? a 10mm thick plate is only around £10-15, but will a nema 17 and belt be fine with that amount of weight?
Re: Aluminum Sheet Between Heater and Glass February 01, 2016 07:27AM |
Re: Aluminum Sheet Between Heater and Glass February 01, 2016 07:50AM |
Re: Aluminum Sheet Between Heater and Glass February 01, 2016 10:11AM |
Re: Aluminum Sheet Between Heater and Glass March 21, 2016 05:02PM |
When I used just glass and a MK2B I could get to 136c then I added the thin heat sink (heat spreader) and I couldn't make it past 105c at 24v. I had to go to 28V and increase the range in Marlin from 255 to 511 to make it to 110c.Quote
dc42
IMO for a bed that small, you might as well use 4mm glass, a thin sheet of aluminium as a heat spreader, and a PCB bed heater. I expect digital dentist would disagree. I also think a mk2b heater will be woefully underpowered for a thick aluminium bed.
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 11:46AM |
toxuin
Anyone knows a decent place to obtain a 14.5 x 14.5 inches tooling plate in Canada?.. Those mentioned above stores quote me from $180 to $350 for that! That's... not even close to $40 mentioned by digital_dentist.
And does precise thickness really matter in case I wish to use 0.8 mm nozzle? Will a plain 1/4" piece of sheet aluminum do?.. I can get it in my town for ~$30.
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 12:19PM |
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 01:21PM |
Tell you what I had some of these shops quote me a price as they are one off shops and screw them at 250-300 dollars to have 5 countersunk holes done. No, I can't do that here but going from regular aluminium to Mic6 was a 200 dollar increase in one shop, which is outrageous.Quote
the_digital_dentist
toxuin
I just bought another 12" square piece of cast tooling plate from Speedy metals for $40. It's labeled Alca 5 which I looked up and found is made in Canada.
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 09:22PM |
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 09:29PM |
Trust me I know my limitations and I can't cut straight nor can I drill straight so I see that Sears has lowered the price on their 12in Drill Press by ~53 dollars and with tax I will get it for about 193 dollars. From everything I have seen on that model it is a nice DP with little runout. I wish I could find out more but as we all know a DP is really made for wood but this one goes from 300rpm to almost 3100rpm. Most of the stuff I drill is under half inch (so about 12mm) and I suspect this would handle it. To counter sink a 3.5mm hole what do I buy?Quote
dintid
Seriously, right now I have a 4mm alubed (nothing fancy) and I have drilled the holes and countersunk them myself with normal electrical handdrill.. I then have 4mm boroplat on top with PrintBite on one side and PEI on the other... I do not belive it would matter if I used MIC6 or not. I have a 500w AC heater under it.
Do you Guys print directly on the Alubed, or?
Edit: forgot to ask the question my post was all about
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 09:46PM |
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 09:51PM |
I know what it looks like but I have seen different sizes and for a 3.5mm hole which size of countersink do I get? Just anything? I do know I need the metric one since metric uses 90 degree and we use 82 degrees.
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 10:07PM |
Re: Aluminum Sheet Between Heater and Glass April 23, 2016 10:11PM |
Alright, good to know as my screws are all countersunk 3mm so I need a 90 degree countersink which leaves me having to find a metric. Too bad they don't make this to fit my Dremel as I can do it with it with two stead hands but with a regular hand drill I suck at it and I have never gotten better do it either. Using a hack saw I cannot cut a strait line, or any hand saw, no matter how hard I try. I can cut straight with scissors though, lol.Quote
the_digital_dentist
The size doesn't matter as along as it is big enough. You just drill into the metal until the diameter is large enough for your screw head. You can do it with a hand drill.
Re: Aluminum Sheet Between Heater and Glass April 24, 2016 05:36AM |
I'm Danish and only use metric stuff... and I have done it using regular drills, and it Works. Problem is how the "cone" MIGHT not be smooth-sided and the screw might sit a bit ascew untill you tighten it way Down.. which it should be anyway (even with springs on it..Quote
Dark Alchemist
the_digital_dentist
edit: I went looking and look what I found - [www.mytoolstore.com.au] Now to see if I can't find that in the USA.
Re: Aluminum Sheet Between Heater and Glass April 24, 2016 07:07AM |
Re: Aluminum Sheet Between Heater and Glass April 24, 2016 06:25PM |
Dark Alchemist
the_digital_dentist
Re: Aluminum Sheet Between Heater and Glass April 24, 2016 07:04PM |
Yep, I found that last night and may just grab that. I can use my hand or a drill.Quote
llamatrails
Dark Alchemist
the_digital_dentist
Do you have a Harbor Freight nearby?
Countersink search
This one is a 90deg: 90deg countersink
Rick
Re: Aluminum Sheet Between Heater and Glass April 26, 2016 07:42PM |
Re: Aluminum Sheet Between Heater and Glass April 27, 2016 12:09PM |
Re: Aluminum Sheet Between Heater and Glass April 27, 2016 02:43PM |
Re: Aluminum Sheet Between Heater and Glass April 27, 2016 03:24PM |
Re: Aluminum Sheet Between Heater and Glass June 16, 2016 07:48AM |
Re: Aluminum Sheet Between Heater and Glass June 16, 2016 09:25AM |
Re: Aluminum Sheet Between Heater and Glass June 16, 2016 04:23PM |
Re: Aluminum Sheet Between Heater and Glass June 16, 2016 04:44PM |
Re: Aluminum Sheet Between Heater and Glass June 17, 2016 03:55AM |
the_digital_dentist
I wouldn't use less than 1/4" (6.35 mm). Maybe 8-10 mm???
My 1/4" bed heats to 105C in about 5 minutes with about 0.46 W/cm^2, about the same power density as you have available. Putting glass on it will slow things down a bit, but since your target is 60C, probably not enough to matter.
