speed issues with ramps 1.4
April 24, 2012 07:50AM
Finally have everything set up and seemingly working with my 1.4ramps. However when running the ReplicatorG or Proterface software the machine runs glacially slow. I can move the x,y or z azis any distance I choose ...and it runs smooth but once i load the gcode the machine barely moves. I've tried tweeking the available commands but nothing seems to happen. Any ideas ??
thanks
VDX
Re: speed issues with ramps 1.4
April 24, 2012 08:35AM
... can you post a snippet of your G-code?
Viktor
April 24, 2012 09:19PM
Hi Viktor,
thanks for responding.Here is a bit of the gcode generated with skeinforge. I was unable to generate the code using the replicatorG software.
G90
G21
M103
M105
M106
M140 S60.0
M141 S30.0
M142 S0.0
M113 S1.0
M108 S210.0
M104 S200.0
G1 X-5.76 Y38.808 Z0.72 F60.0
M101
G1 X-5.76 Y44.712 Z0.72 F240.0
M103
G1 X-2.88 Y50.472 Z0.72 F960.0
M101
G1 X-2.88 Y33.048 Z0.72 F240.0
G1 X0.0 Y30.168 Z0.72 F240.0
G1 X0.0 Y53.352 Z0.72 F240.0
G1 X2.88 Y54.792 Z0.72 F240.0
G1 X2.88 Y28.728 Z0.72 F240.0
M103
G1 X2.88 Y23.112 Z0.72 F960.0
M101
G1 X2.88 Y7.128 Z0.72 F240.0
G1 X0.0 Y7.128 Z0.72 F240.0
G1 X0.0 Y21.672 Z0.72 F240.0
G1 X-2.88 Y21.672 Z0.72 F240.0
G1 X-2.88 Y8.568 Z0.72 F240.0
M103
G1 X5.76 Y4.248 Z0.72 F960.0
M101
G1 X5.76 Y54.792 Z0.72 F240.0
G1 X8.64 Y54.792 Z0.72 F240.0
G1 X8.64 Y-2.952 Z0.72 F240.0
G1 X11.52 Y-2.952 Z0.72 F240.0
G1 X11.52 Y54.792 Z0.72 F240.0
G1 X14.4 Y54.792 Z0.72 F240.0
G1 X14.4 Y-2.952 Z0.72 F240.0
G1 X17.28 Y-2.952 Z0.72 F240.0
G1 X17.28 Y54.792 Z0.72 F240.0
G1 X20.16 Y54.792 Z0.72 F240.0
G1 X20.16 Y-2.952 Z0.72 F240.0
G1 X23.04 Y-2.952 Z0.72 F240.0
G1 X23.04 Y54.792 Z0.72 F240.0
G1 X25.92 Y54.792 Z0.72 F240.0
G1 X25.92 Y-2.952 Z0.72 F240.0
G1 X28.8 Y-2.952 Z0.72 F240.0
G1 X28.8 Y54.792 Z0.72 F240.0
G1 X31.68 Y54.792 Z0.72 F240.0
G1 X31.68 Y-2.952 Z0.72 F240.0
G1 X34.56 Y-2.952 Z0.72 F240.0
G1 X34.56 Y54.792 Z0.72 F240.0
G1 X37.44 Y54.792 Z0.72 F240.0
G1 X37.44 Y5.688 Z0.72 F240.0
G1 X40.32 Y7.128 Z0.72 F
April 25, 2012 02:14AM
Your speed values (F#) are way too low!
What do you have set in the Speed tab?
And what factors are you using for first layer, etcetera?
And EVEN MORE IMPORTANT you don't have any E values.
You MUST TURN DIMENSION ON!
And you need a Replace.csv file to get rid of the M101, M103, and other unused gcodes.
Edited 2 time(s). Last edit at 04/25/2012 02:16AM by rhmorrison.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
