Print without PC - SD card printing...
January 16, 2015 01:49PM
Hello,
I am using RAMPS 1.4 with Arduini MEGA.
I want to print without PC. So what options are available as far as RAMPS 1.4 is considered.
I have connected diode D1 on RAMPS, but it doesn't work.
There are three pins on RAMPS VCC, 5V & PSU_ON...
Which of the above pins should I connect & from what.
Should I connect only VCC with 5v wire on ATX PSU? OR all of the three pins?
Re: Print without PC - SD card printing...
January 16, 2015 02:08PM
There are several options. Search reprap lcd smart controller on ebay for a bunch. These plug directly into the RAMPS 1.4 board and provide an interface and SD slot.
VCC is connected to the 5 volt regulator on the Arduino
5V is connected to the 5 volt bus in the area on the ramps board labelled SERVOS
If you intend to use servos, you'll need to either supply 5 volts to the 5 volts pin, or you can place a jumper on VCC<>5V to use the 5 volts from the Arduino.
PS-ON is an output that is commonly used to switch an ATX power supply on/off
I use this output to switch a relay module for G-Code control of my non-ATX power supply.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
January 16, 2015 02:17PM
If you do not want an LCD, there is also just an SD card board that plugs directly into the RAMPS. Google SDRAMPS or check here. If you do not have an LCD, your host program must be capable of starting prints from the SD card. I think pronterface does this. I'm not sure of the others
January 16, 2015 02:32PM
@Mindrealm, What do you mean by 5 volt regulator on the Arduino? I din't got you...
January 16, 2015 02:37PM
The Arduino has a voltage regulator built in that supplies 5 volts to the VCC bus on the MEGA2560. This is the same as supplied to the majority of the RAMPS 1.4 board, with exception of the servo pins. They are not connected to anything except that pin that is marked 5V. If you use servos for any reason (most common is bed leveling), you will need to either connect an external 5 volt power supply to this pin or you can use a jumper on VCC<>5V to use the same 5 volts that the arduino 'produces'...
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
January 17, 2015 12:51AM
I don't want to use any servos...
I just want to know that whether I should connect any wire from PSU to VCC on RAMPS?
January 17, 2015 11:11AM
No. You do not need to bother with the 5V or VCC pins if you are not using servos. smiling smiley
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
January 17, 2015 12:06PM
OK, I am not using servos anytime.
What I understand is that there are two options to print without PC - either connect diode D1 OR connect VCC on ramps with PSU.
Let me know if my understanding is correct.....
"Without D1 installed, or when the 12VIN is not connected, the Arduino gets its power from USB. If you want your kit powered without USB connected you need to solder in D1 OR connect VCC to your PSU."
what does this means?
I want to power the Arduino+RAMPS without USB connected...
Edited 1 time(s). Last edit at 01/17/2015 12:43PM by prashantdshinde.
January 17, 2015 12:43PM
prashantdshinde
Yes but you will still need a method to control the Printer in the form of a LCD Display with SD Card reader remember that when connecting the D1 that it must go in the right way round ie the stripe on the Diode must be at the same end as the stripe on the printing on the board.
February 23, 2015 12:51PM
Sorry, have you figured that one out? I am facing the same challenge...
February 24, 2015 07:23AM
@ Fizpok, I have removed the D1 diode.
Now switching ON/OFF PSU using M80/M81 G code.
Connect as below:
VCC on RAMPS to +5SB on PSU.(Purple color)
PS_ON on RAMPS to PS_ON on PSU(Green color).
